Hybrid Battery Won't Charge Pass Halfway Poor MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Vince9022, Feb 7, 2017.
  1. Vince9022
    Vince9022 Junior Member
    Louisiana
    I have a 2007 Prius with 137,000 Miles. I was getting 45-50 MPG then around November/December my mileage dropped to 32-34 MPG. I thought it was cause of winter but here in Louisiana it's 77 degrees today. I changed spark plugs to no effect. I checked 12v aux battery and it tested fine. Where I live they're no hills just road bridges. If I get on the Interstate and drive 65 mph Hybrid Battery drops to 1 purple bar and works harder to go over normal bridges. The MPG drops to about 20-23. The Hybrid Battery never charges more than 4-5 Bars and that's only local driving. I also have a 2005 Prius and the MPG is 42-48 MPG and has closer to 6-7 Bar range. I'm not sure if the Hybrid Battery going out since no Triangle,check Engine light ever came on. A guy at Greentec Auto(Hybrid Battery Replacement) told me maybe it's a dead cell but since it's not throwing a code don't do an expensive replacement without being 100% sure. I'm just afraid to take my car out and get stuck on highway somewhere.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Bummer! If it was mine, I get the HV battery checked out. It does sound like one or more bad cells. But you don't know for sure what's going on till you test it out.
  3. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Vince9022 and Deogratias like this.
  4. 07and08prius
    07and08prius Junior Member
    US
    My wife's 07 battery was just replaced by Toyota, 2 weeks before the warranty expired. She said her mpg dropped into the low 30s for about two weeks before it threw a code. We've had it back for a week and it drives like new. 1486923731823.jpg
    Vince9022 likes this.
  5. Vince9022
    Louisiana
    I'm Still driving mine and avoiding the Interstate because I no power to go 65+ mph. I feel caught in purgatory.
  6. bisco
    52,286
    might be the perfect time for a grid charger, if you plan to hang onto it. see post #3.
    jerrymildred likes this.
  7. melshot
    melshot Junior Member
    Denver, CO
    Ok could someone tell me about the grid charger? My 2005 Prius is getting about 42 MPG. I've noticed a big drop in MPG after CO Clean Air emissions made me put a new gas cap on the car just to pass emissions. Could there be a link? The car does have 172,000 on it btw.
  8. JC91006
    JC91006 Senior Member
    16,815
    8,596
    The gas cap shouldn't matter, but you can always put back the old one
    melshot likes this.
  9. melshot
    Denver, CO
    Unfortunately I threw it away of course
  10. melshot
    Denver, CO
    Ok tell me. How do you get the HV battery checked out? And I've read on this forum before that you can get your HV battery replaced with a recharged battery (so like a used battery?). How much do those run and how do I find a mechanic that will install it? My regular mechanic won't even change the oil in my car because of the HV battery.
  11. jerrymildred
    11,517
    14,157
    Tampa, FL
    Either take it to a Toyota dealer, to a shop that specializes in hybrids, or diy with a mini vcs and techstream software or a wireless obdii reader and Torque Pro (Android) or Engine Link (iOS). There are countless threads here about these tools. I use the Mini VCS and Techstream, but also have Engine Link on my phone for quick & dirty easy stuff. With either of the smartphone options, you'll need to get the PIDs installed, which is a bit of a pain.
    I would never take a Prius to a mechanic that doesn't know how to work on them. Actually, I almost never let anyone else mess with my car.
    A used, rebuilt battery is way less than a new one, of course. But it is likely to only last a few weeks or months depending on the quality of the parts and the skill & diligence of the rebuilder. The best option, imho, short of a new battery, is a nearly new used battery taken intact from a wreck. My wife's '07 has the cells from a 2015 that have been transplanted into a gen 2 battery case. I bought it all set up and ready to go and replaced it myself. Not hard at all.
    Raytheeagle and JC91006 like this.
  12. JC91006
    16,815
    8,596
    The hv battery is a maintenance free item, you don't have to do anything with it. Just drive the car and the car will let you know if there's something wrong in the form of warning lights.
    Don't fix it if it's not broken. Many times if you blindly go to shops to fix a non issue, they'll end up breaking your car
  13. Prodigyplace
    12,629
    11,808
    Central Virginia
    @jeff652 from Hybrid Automotive is quite active here.
    This system is their best option, IMHO.
    ProlongĀ® Deluxe Reconditioning Package - Hybrid Automotive
    Here is a less expensive, but more labor intensive option.
    ProlongĀ® Value Reconditioning Package - Hybrid Automotive
    melshot, Raytheeagle and jerrymildred like this.
