Oil change frequency?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by chiefofsages, Feb 15, 2017.
  1. chiefofsages
    chiefofsages New Member
    I've been trying to find some information about how often the Prime needs an oil change, but so far the only things I can find are for the 1st gen PIP. I have read that with the Chevy Volt, it's only changed as needed and some people can last up to two years due to their massive use of electric-only driving.
    Is the Prime a "change your oil every x miles" or more of a "change it when it tells you to"? Hypothetically, my entire work commute should be handled in EV, so the engine shouldn't really even be used for most daily traveling. But is the car going to tell me otherwise?
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    From an earlier thread, I'm attempting to convince myself for-sure that a P.Prime in EV mode does not crank over the engine, the point being that if it's motionless, not much point in changing the oil. As yet, I'm not 100% convinced.
    That thread left saying that EV mode drives the wheels via MG2 driving forward, MG1 driving backward, and the engine pegged at a standstill against the new sprag clutch. However, it appears that MG1, which is all I can think of that could push the engine against the sprag clutch, is only engaged under high-torque situations. If MG2 is driving and MG1 has not being driven, then I can't think of anything that would prevent the engine from moving, and thus requiring lubrication.
  3. Mendel Leisk
    41,826
    Are you wondering what Toyota's saying? You can download the Warranty and Maintenance Booklet, from Toyota Tech Info, in the Manuals section. Believe it's yearly or 10,000 miles, the usual.
    dalcon95 and priuscatprimeguy like this.
  4. mr88cet
    2,313
    1,335
    Austin, TX
    Despite my efforts to understand this question though, the truth probably is that I'll just do oil changes right on schedule even if it turns out to be only marginally necessary. I'm having difficulties getting too upset about paying $30 (or whatever) oil change after spending $30K on a car...
    jerrymildred likes this.
  5. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    The Warranty booklet states 6 months or 5,000 miles, which ever is first.
  6. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    The Warranty Book, suggests servicing the vehicle every 6 months, or 5,000 miles to check the drivers floor mat, fluids, wiper blades, rotate the tires and inspect the brakes. Oil changes are noted at 12 months or 10,000 miles for standard maintenance and 6/5,000 for special conditions
  7. bisco
    52,286
    12 months or 10,000 miles as mendel and vtbigdog state above, same as all gen 3 and 4 prius. many of us plug in owners have endeavored to ascertain empirical evidence that reduced operation of the engine would allow for longer intervals. but all we have are opinions and 'what other manufacturers are doing'. no one has done the hard oil testing to my knowledge.
  8. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Here is my plan; my round trip to work and home is a total of 7 miles, so I'll spend most of my time driving EV only. So I'll do the 10k changes and keep an eye on the oil.
    When I go on a road trip, where I rack up miles on the ice, I'll change it by no later than 5k
    I plan on keeping one of them little notebooks and using trip B to keep track of the little trips on ICE.
  9. VTBIGDOG
    211
    146
    Just driving the car, even racking up miles as you stated, does not necessarily qualify as unusual conditions. I think you would still be good with 12/10,000 unless you are doing a lot of idling, or stop and go driving. Of course, changing every 5,000 provides peace of mind.
    thatoneraccoon likes this.
  10. thatoneraccoon
    201
    146
    Ohio
    Yeah it's more peace of mind and personal preference.
    Although they say can go 10k, I never go past 5k on my oil changes. So far I've racked up many cars over 200k and as high as 400k and never had any oil related problems.
  11. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Toyota should have put an hour meter on the engine and set the oil change interval by the hours of operation. They didn't. Oh well....
  12. Mendel Leisk
    41,826
    Maybe you guys are all "mileage governs", but anyway: keep in mind the maintenance schedule is mile OR months.
    irishthriller likes this.
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I like that idea. I wonder if I can find a used John Deere hour meter to hook up. ;)
  14. SubPrius
    SubPrius Junior Member
    31
    How would you determine when to change the oil from total hours of engine runtime?
    Another method might be to record the number of gallons at each fill-up. Then multiply each fill-up by 50 (your estimated average MPG), and add that to the total number of gasoline miles. And use that total to determine when to change the oil.
    Here's a Prime question: Is the Prime gas gauge any more accurate than the Gen 1 and Gen 3 gas gauges?
    Or do Prime drivers use one of the trip ODOs as a gas gauge?
    How many trip ODOs does the Prime have?
    Can the maintenance reminder light be reconfigured to come on at a mileage OTHER than 5000?
    If so, can the light be reconfigured to come at a mileage that the driver sets?
  15. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    That's a pretty good idea when I think about it. By tracking the number of gallons and estimating the average MPG under ICE power, it should be possible to extrapolate when you've driven 10,000 ICE miles.
  16. bwilson4web
    16,330
    Corrected for the tire error, it is (has been) dead on accurate for our Gen1, Gen-3, and this Gen-5.
    IMHO, if the engine runs, there should be a late Spring and Fall change to get rid of the acidic water from combustion by-products.
    There also needs to be an early, accelerated change at 2-5k miles to flush the assembly and manufacturing debris. Both the engine and transmission.
    Insighter likes this.
  17. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    The cars computer should track for you, and use tachometer hours for the oil change interval, same as small engine aircraft.
    Miles makes very little sense IMHO.
  18. mr88cet
    2,313
    1,335
    Austin, TX
    I was thinking the other day that it might be even simpler than that, given that the goal is to change the oil every 5000 miles of engine usage:
    Zero out one of your trip counters after each oil change (or when you first get the car ... actually they probably start at zero, but anyway!).
    If I recall correctly from one of Optimus Prime's YouTube videos, it remembers MPG, in addition to #miles, for each trip counter (true?). If so, then miles/MPG = #gallons burnt.
    Toyota's apparent target seems to be on the order of 5000miles/50MPG = 100 gallons (round numbers).
    Soooo... all you have to do is look for when that trip counter's #miles hits 100 times its #MPG. When it does, take it in for an oil change!
    I think I thunk that out correctly, again assuming that I'm remembering correct about the ODO's trip meters maintaining MPG in addition to miles...
    iPhone ? Pro
    YPizza likes this.
  19. mr88cet
    2,313
    1,335
    Austin, TX
    Ah, a potential complication to that just popped into mind: I gather that the MPG readouts on the dash "peg out" at 199MPG.
    iPhone ? Pro
  20. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    We have already paid for the "free" 2 year/25,000 miles maintenance. I will take mine in every 6 months and get my "free" oil change and tire rotation for those 2 years (I don't drive 12,500 miles per year). I don't care how much the engine actually ran - maintenance schedule for warranty coverage is based upon the odometer, not engine miles. At least that is what my service department says.
