How to remove white steering wheel cover
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Mario-V, Feb 18, 2017.
  1. Mario-V
    Mario-V New Member
    Belgium
    How can i safely remove (without damaging) the white cover from the steering wheel (not the button-row)?
    I want to wrap this with a 3D carbon look plastic and reinstall afterwards.
    Is it simply pull and click for reinstalling ? Or must i pull on a special place .........
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    I know some people have masked the steering wheel and used Plastidip to color that area black. I believe there are kits with other colors available in Japan, so the documentation must be available somewhere, assuming the US wheel is the same. I know some ountries have a leather wrapped wheel, for instance.
  3. Mario-V
    Mario-V New Member
    Belgium
    Thanks for the info .... but i don't want to paint or spray paint in the car .... i rather do it outside .....
    I found a company that have black shells for the white cover off the shifter but no cover for the steering wheel.
  4. Prodigyplace
    11,696
    11,318
    Central Virginia
  5. Mario-V
    Mario-V New Member
    Belgium
    Thanks for the link but i can't read Japanese (i think it's Japanese). I don't have any clou where to click for ordering the parts.
  6. Prodigyplace
    11,696
    11,318
    Central Virginia
    The first translated link might help. I do not speak Japanese either. I belioeve there are some Gen 3 users that can get JDM parts from Japan. Maybe they can help.
    Or, this may be it. stylemarket | Rakuten Global Market: Black panel set SY-P11/ console tray interior panel instrument panel dress-up decoration custom black for exclusive use of the YAC (yak) 50 system prius
    From the translated link:
    Features
    • ● Designed exclusively for fitting the interior.
    • ● Console panel · Console tray panel · Shift panel · Handle panel 4 point set.
    • ● Easy installation just paste with double-sided tape.
    • ● Refresh interior decoration with chic black luster, directing luxury.
    ※ E grade car can not be installed.
    * It can not be installed simultaneously with SY - P8.
    ※ Simultaneous installation with SY-P9 is not possible.
    Part number: SY-P11
    Item name: 50 series Prius black panel set Package size: H180 × W550 × D250 (mm)
    Color: Black
    JAN: 4979969010718
    Price: Open price (manufacturer's suggested retail price, tax excluded)
    #6 Prodigyplace, Feb 19, 2017
    RCO likes this.
  7. bobthejedi
    bobthejedi Active Member
    137
    153
    SF Bay Area
    Mario-V, I sent you a PM, it seems that its screwed on and you have to remove the entire steering wheel, I found these two pics of a salvage yard pull of the piece, it would be easiest to wait for a third party part
    GreenJuice, Prodigyplace and RCO like this.
  8. Mario-V
    Mario-V New Member
    Belgium
    Thanks for the info .... i ordered the pieces i want.
    Greetings
  9. bobthejedi
    137
    153
    SF Bay Area
    Hi Mario, where did you end up ordering as it sounds like you did not want to go the DIY route, keep in mind some of the japan stuff is for right hand drive
    RCO likes this.
  10. Prodigyplace
    11,696
    11,318
    Central Virginia
    The buttons on the wheel are different in Japan, for instance.
    RCO likes this.
  11. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    For those interested in purchasing Prius accessories from Japan, I suggest googling for Rakuten. The site will do the JPY to USD conversion for you.
    RCO likes this.
  12. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
    Have you or anyone else had experience using that service? I'm interested in buying a couple things.
  13. pilotgrrl
    891
    1,796
    Chicagoan in TX
    I just ordered some side moldings. It's not entirely clear if they will fit, but they are less than $60 USD, so I thought I'd take a change. Google Suzuki Motors Rakuten. They are listed as door edge protectors, and they come in white, silver, black, red Maika metallic, blue, and dark blue. I got silver ones.
    krmcg and CoolPrius like this.
  14. dml996
    dml996 Junior Member
    Spartanburg, South Carolina
    Has anyone figured out how to remove the steering wheel yet? I can only find posts related to 3rd gen and before... 4th gen appears to be different, there is a removable panel on the right side by the cruise control but i dont see a clip or anything on the other side to be able to release the air bag cover.... Anyone had success?
  15. Prodigyplace
    11,696
    11,318
    Central Virginia
    I expect @sfv41901 and his crew at Hybrid Pit may have ideas...
  16. bobthejedi
    137
    153
    SF Bay Area
    I Think I have the TIS diagrams, but its pretty involved for something that involves airbags
    Check out this link if you're just interested in bottom garish
    Car Steering Wheel Panel Garnish Cover Trim for Toyota Prius Xw50 2015-2017 | eBay
    Black Steering Wheel Appliqué | Page 2 | PriusChat
  17. dml996
    I worked it out. There are 3 holes on the back side of the wheel that you have to insert a flat head screwdriver into, inside are spring clips that when compressed will release the airbag.
    After the airbag is removed you can access all of the inner components of the steering wheel including trim pieces etc.
  18. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    What's under the white trim, would it look ok with it removed altogether, or does it cover some unsightly part of the wheel ?
  19. dml996
    it covers the frame of the wheel
  20. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    A professional wrapper could wrap the white pieces in place. I would assume the cost would be less than $100.
