Extra Length: In Rear?
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, Mar 11, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Most reviews I've seen say that the extra 4 1/2 inches of length between the P.Prime and the regular Prius are all in the rear of the car for the battery. From looking at lots of pictures, it's not really clear where the extra length really is.
    If anything, it looks like the nose is longer…
    Is it for sure really an extended rear, because of the battery?
    iPhone ? Pro
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I was hoping for a superposition, but no one seems to have done that.
    thatoneraccoon likes this.
  3. mr88cet
    2,313
    1,335
    Austin, TX
    Still not super-obvious to me. I'll try again to post this picture from the KBB YouTube review (wouldn't let me earlier).
    Hmmm, still can't seem to post it; it says it's not a photograph...
    iPhone ? Pro
    #3 mr88cet, Mar 11, 2017
  4. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    I tried, but the perspective is off just enough that I can't match them up.
  5. Tideland Prius
    16,602
    It's about 1" longer in the front and 3" longer in the rear IIRC.
    Look at the bumper. These are the two closest photos I can find on the internet. The Prime is on the top and the Gen 4 is on the bottom. The Prime has that extra subtle lip to show the extra length. Even visually, you can tell that the top of the rear bumper is wider on the Prime than on the Gen 4.
    Gen 3 for me, JimboPalmer and mr88cet like this.
  6. mr88cet
    2,313
    1,335
    Austin, TX
    Good comparison. Thanks!
    iPhone ? Pro
  7. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    YYRC Looking at the Toyota website it's 1 inch in front, 3.2 inches in rear, 4.2 inches total.
    Height/Width/Length
    Prime 57.9 69.3 182.9
    Liftback 58.1 69.3 178.7
    Overhang Front/Rear
    Prime 38.4 38.2
    Liftback 37.4 35.0
    Ground clearance
    Prime 4.8
    Liftback 5.1
    mr88cet and Tideland Prius like this.
  8. Tideland Prius
    16,602
    Thanks for looking into that for me.
  9. Since2002
    936
    1,098
    Duluth, GA
    Here's a side-by-side that I made from the photos on the Toyota website.
  10. Since2002
    936
    1,098
    Duluth, GA
    Here is a superposition. The little bit of "Blue Magnetism" that you see sticking out in the front and rear is the Prime.
  11. bisco
    52,286
    on top of everything else, i need a bigger garage?
  12. mr88cet
    2,313
    1,335
    Austin, TX
    Well-done comparison!
    iPhone ? Pro
  13. mr88cet
    2,313
    1,335
    Austin, TX
    Kinda interesting that they'd add 3ish inches way down low in the rear, considering that the battery is up a bit higher than that.
    I guess the concept is that down low is as good a place as any for a crumple zone behind the battery in case you get rear-ended.
    iPhone ? Pro
  14. bisco
    52,286
    that's probably it.
  15. Trollbait
    12,653
    The extra rear length is likely more for the carbon fiber hatch than the battery.
  16. mr88cet
    2,313
    1,335
    Austin, TX
    Made of the carbon-fiber hatch. I expect its purpose is just crumple-zone space, though.
    iPhone ? Pro
  17. Trollbait
    12,653
    The hatch's rear wall is thicker than the metal one. I don't see it being a major crumple zone piece.
  18. mr88cet
    2,313
    1,335
    Austin, TX
    3 inches worth at least, it would appear... not huge, but not insignificant.
    As I recall, carbon fiber as used in Indy cars has excellent energy-absorption characters.
    iPhone ? Pro
  19. Trollbait
    12,653
    Yes, by shattering into tiny little pieces.
    If the hatch stays latched closed during an impact, it will absorb some of the energy. The heavy lifting for that is being done by the bumper, quarter panels and all that sub frame. Which are likely high strength steel.
  20. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    That hatch door is really thick. If it were steel you wouldn't be able to lift it.
    Also there is the tiny storage slot behind the battery that goes all the way across.
    Looks like they went to a lot of trouble for that tiny slot, and it adds inches.
