Mystery ball bearing and spring
Discussion in 'Gen 2 Prius Main Forum' started by Kuriti, Mar 10, 2017.
  1. Kuriti
    Kuriti Junior Member
    Raleigh, NC
    Greetings. Long time lurker, first time poster. My 2006 recently past 200k, so I decided to do the spa treatment. I replaced the ATF fluid, radiator and inverter coolant, the faulty odometer board, spark plugs and even wet sanded the headlights. Today I changed the pcv valve and the serpentine belt. While down on my back installing the bet, I found a spring and ball bearing that look suspiciously like some kind of valve. I have no idea where they came from and have no issues with the running of the car so far. I ran Toyota tech stream to clear a code leftover from the radiator coolant (forgot to clip back a plug), and everything looks normal. Does anyone recognize these two guys?[​IMG]
  2. Kuriti
    Raleigh, NC
    I should have said, I removed the air cleaner for the belt replacement
  3. dyethor
    dyethor Junior Member
    menifee ca
    2013 Prius v wagon
    From a ratchet? Flex head style or the ball detent that keeps sockets on.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    Dyethor,
    What an eye!!! I'll have to second that as a likely source, but we need to get more specific. I vote for it coming from a 3/8" extension, 3" long purchased from HF. (have some myself...)
    edthefox5 likes this.
  5. Kuriti
    Raleigh, NC
    agreed. I am starting to think it came off a tool. I will check my ratchet as several were involved.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Have not seen a Craftsman lose that ball but I bet an HF extension will.
