LED Turn Signal Relay/Flasher
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pauerbach, Apr 24, 2014.
  1. s2kinfinite
    s2kinfinite Junior Member
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Correct, no resistors needed after replacing flasher relay.
    s2kinfinite likes this.
  3. s2kinfinite
    Thanks again Xliderider.
  4. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I just got my relay today in the mail! That's my project for the weekend... I think I'll start with a few back pain killers right away before bending under the dash! Thanks for sharing your input!
  5. zxcvb4531
    zxcvb4531 Junior Member
    San Francisco,ca
    I would like to see the video, I cant figure out after the yellow tag wheres it at
  6. Laliga
    Laliga New Member
    Australia
    Thanks for the post. Can anyone still watch the video? It says it's private
    Air_Boss likes this.
  7. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    If I remember correctly, the flasher is directly above the steering column. I'll try to get a photo of mine when I get home.
  8. Air_Boss
    Air_Boss Senior Member
    4,205
    1,186
    New Yawk
    I recall the conclusion being the v 'flasher' is integral to the bezel PC board. There is no separate 8-pin flasher as on the hatchback. I never found one, despite busted knuckles from thrashing around up there.
  9. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    yea... I can't even find the relay.. So the video wold be great... But as u said its private by some reason
  10. thunder96
    thunder96 Junior Member
    Finally took thing fking relay off... if anyone needs help, message me...
    edthefox5, Fifen and Grit like this.
  11. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Go for the relay that does the wig wag and euro signal capabilities.
    edthefox5 likes this.
  12. Air_Boss
    4,205
    1,186
    New Yawk
    On a hatchback, not a v, right?
  13. MagnusAG99
    673
    521
    Norway
    Dont think the V has a Turn signal relay at all, its built into some circuit board in the V.
  14. Air_Boss
    4,205
    1,186
    New Yawk
    Yes, that was my conclusion 18 months ago (post #28). Just wanted to be sure.
  15. UnitJuno1
    UnitJuno1 Junior Member
    Richmond, CA
    2023 Prius Prime
    SE
    Hi All!
    I'm a 2015 Prius owner in northern california, anyone here know how to get into the flasher relay for the regular prius? any help would be greatly appreciated
    -Juno
  16. abubin
    abubin Member
    193
    92
    Malaysia
    Thanks for all the guide. It helped tremendously. Too me less than 10 min to take out the old relay and put in the new adjustable.
    Here are some pictures. Hope it helps.
    Out with the old
    In with the new and test
    Clip back to position
    It helps with my small frame. I was able to lie on the brake pedal and had easy access to the relay.
  17. abubin
    abubin Member
    193
    92
    Malaysia
    Here is a video of it. Manage to finally make a video.
    edthefox5 and ASRDogman like this.
  18. DimitrisTS
    DimitrisTS Member
    30
    49
    Thessaloniki
    Thanks for all the info! Still I have a question.
    With the oem relay if one bulb goes bad there is hyperflash as result warning you to check which light doesn't work.
    With this new led-relay is it the same? Or you just need to check from time to time.
  19. abubin
    abubin Member
    193
    92
    Malaysia
    Just tested and it doesn't hyperflash when I took off one bulb.
    edthefox5 and DimitrisTS like this.
  20. Gasketblower
    Gasketblower Junior Member
    48
    I am having issues with my Flasher and signal Lights nothing is turning on but i here the clicking sound and the fuse not blown on 2012 PRIUS V what can I do to resolve this issue?
