Trailer hitch?
Discussion in 'Prime Accessories and Modifications' started by MikeDee, Nov 16, 2016.
  1. Backley
    Backley Junior Member
    Hillsboro, Oregon
    I think Draw Tite will make a receiver that will fit the Prime.
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    I had them do some checking... because something didn't seem right. They discovered a link problem, that the original number I had been provided was right all along. Phew!
    CURT 11473
    Now, if I can finally get my Prime to install it on... The expectation is next Friday.
  3. Sandollars
    Sandollars Prius Maven
    134
    157
    SoCal
    Look forward to the results!
  4. itsmejame5
    itsmejame5 New Member
    Brea, California
    cannot wait to get one of the hitch that actually fits the Prime. I considered roof rack but heard it causes wind noise, plus it's easier to mount/dismount bikes from hitch rack. please post the link when the part arrives next Friday! Thanks a lot!
  5. john1701a
    12,818
    5,303
    58
    Here's the link for the order I placed... 2017 Toyota Prius Prime Trailer Hitch | etrailer.com
    The delivered hitch is now impatiently waiting in my garage. Hopefully, I'll be getting my Prime within the next week. The hitch will be installed right away. Photos will be taken & shared. Stay tuned.
  6. bwilson4web
    16,299
    Did you order the wiring too?
  7. john1701a
    12,818
    5,303
    58
    Nope, my only use is for carrying suspended loads.
  8. itsmejame5
    Brea, California
    Thank you for providing the link for trailer hitch!!! Just placed an order. Hopefully I can receive it, install it, and post it soon.
  9. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Thank you ..needed for my motorcycle trailer....no harm done to Prime
    Merged. begin using multi quote.
    I can't see wiring ....if you come across post the link....
  10. john1701a
    12,818
    5,303
    58
    OMG! They weren't kidding when the install difficulty was listed as 10.
    It turned out nice, but that's not a recommendation I can give to anyone unwilling to really get involved. The steps are tedious & numerous. It took me 6 hours. Of course, you could always have an installer put it on.
    Stay tuned for photos.
    jaymac, bwilson4web and Toyota4Life like this.
  11. john1701a
    12,818
    5,303
    58
    Here it is:
    Notice how snug up against the bottom of the car it is, with very little actually exposed. That's really nice for minimizing aerodynamic exposure. It prevents ever bumping into it with your leg too; however, it does necessitate the purchase of an extender.
    #71 john1701a, Apr 3, 2017
  12. bwilson4web
    16,299
    Is this is job where the car should be raised on ramps?
    Do the instructions include wiring if you want to two a small trailer?
    Any significant difference between the Curt and the other?
    Thanks,
  13. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Extender? I was hoping not. How far is the end of the hitch from the bumper?
    I've got my Draw-Tite hitch, but haven't put it on yet. I was going to jack up the back of the car and put it on jackstands. I have two threaded studs that I will use as locator pins that will help in locating the hitch and bumper.
    #73 MikeDee, Apr 3, 2017
  14. bwilson4web
    16,299
    I was always going to have one because my wife's wheel chair carrier uses a 2" receiver. I'm just hoping there is enough gap for the extender-expander.
    hatcher8 likes this.
  15. john1701a
    12,818
    5,303
    58
    Draw-Tite appears to hang down about an inch lower than Curt, allowing a regular accessory to attach just fine.
    My bike-rack has a locking mechanism, so it's too thick to fit underneath. Of course, I wouldn't want to it to be close to the hatch. So, I'd use an extender anyway.
    #75 john1701a, Apr 3, 2017
  16. jaymac
    jaymac membore
    179
    57
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    The opening on the receiver of the hitch mounted to our gen 3 lift back is nearly flush with the bumper. Can you get a ball mount with that much extension stock or would that be a custom proposition ?
  17. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    What is the part # for the Draw-Tite? I know the CURT is 11473
  18. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Is it Draw-Tite 24944-- the same as the regular Prius? The directions seem fairly easy and they indicate only 45 min. to install???
  19. MikeDee
    1,580
    597
    Yes, same as regular Prius. 45 minutes? Probably a lot longer unless you have access to a lift. I'll probably be putting on my hitch this week.
    #79 MikeDee, Apr 3, 2017
  20. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Do you think it could be any quicker to install than the Curt? Maybe the directions are better?????????
