Funnel for adding oil to a 3G Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kc410, Mar 25, 2017.
  1. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    In another thread funnels were mentioned in changing oil in the transmission. This reminded me I had forgotten to post a pic of my homemade funnel to add oil to the Prius engine - it is the top half of a quart, glass cleaner spray bottle. Its the perfect size to sit in the limited space of the Prius.
    52,390
    ingenious!(y)
  3. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    That grey serrated plastic cover lifts straight up. You should remove it before adding the oil to protect against spills and keep it nice looking.
  4. Mendel Leisk
    41,903
    There's a part of me that wants to just ditch that cover. :sneaky:
    Trivia: the offical name for that piece is "NO. 2 CYLINDER HEAD COVER". It took me a long time, to cotton onto what that actually was. And whatever happened to it's NO. 1 counterpart; guess we'll never know.
    #4 Mendel Leisk, Mar 26, 2017
    m.wynn likes this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Just looked it up. Japanese write top to bottom, right to left. Probably means cylinder head cover of #2 cylinder, whatever that means as well......
  6. Former Member 68813
    3,524
    983
    US
    i didn't know people were as cheap as myself. I make my disposable funnels from tops of soda bottles.
    kc410 likes this.
  7. OptimusPriustus
    OptimusPriustus Active Member
    335
    142
    Finland
    I decided to treat myself and bought this premium funnel. There’s a twistlock valve at the tip (the blue section), lid etc. Comes with transparent hose with plug. Not sure if i ever need the hose.
    ASRDogman likes this.
  8. ASRDogman
    ASRDogman Senior Member
    7,821
    3,983
    That's pretty nifty! I'm sure it will work nicely for you.
    I have one that almost screws into the filler, it holds enough to pour 4.5 quarts
    in without spilling.
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Baby that cap. I’ve been using that for years, the cap will discolor and get loose. Great for measuring though, at least while you have the cap. (I tend to lose them somehow)…
  10. Mendel Leisk
    41,903
    @Ragingfit (in his videos) was using a cut off top of a motor oil bottle, the neck offset similar to above pic. Not sure what brand, but it might have even had threads that match the oil filler cap.
  11. OptimusPriustus
    335
    142
    Finland
    I’m thinking to add some string to avoid loosing it. Hope somebody at Flo Tools is reading this
    jzchen likes this.
  12. Mr. F
    Mr. F Active Member
    389
    263
    Washington
    Directly underneath the (plastic) No. 2 cylinder head cover is the (Aluminum, No. 1) cylinder head cover assembly.
    From a Smashing Magazine article:
    The plastic vanity cover would be listed in a catalog as Cover, Cylinder Head, No. 2, and elsewhere, unfurled right-to-left (like translating Yoda-speak), it would be the No. 2 Cylinder Head Cover. The parts catalog version is clearer as it unambiguously tells you it is the cover, [for the] cylinder head, [and is] the second of its kind. Using this notation would help sort parts by function when arranged alphabetically. In a printed list, all gaskets would appear together, as would all nuts, clips, manifolds, coolers, and covers.
    The unfurled version could say a few different things depending upon where you imagine the commas originally were (Head Cover, No. 2 Cylinder; Cover, No. 2 Cylinder Head; Cover, Head, No. 2 Cylinder; etc.), but not all of these will make sense.
  13. Rebound
    3,996
    2,645
    Portland, OR
    My advice to anyone changing the oil on a Prius is always remove the plastic beauty cover before adding oil. It is quite difficult to clean oil from it, especially if it “cooks” on from the high engine temps. If you spill a little on the valve cover instead, no big deal; it will be covered.
  14. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    Hey that's what I use to refill transmission fluid in our Prius and, a few weeks ago, was very helpful to refill the fluid in my rear differential in my AWD Prius. (NO room down there to work and I hate those pumps.) My funnel has a pretty long hose attached to it.
  15. ASRDogman
    7,821
    3,983
    Just cut a plastic water bottle in half. Fits right in and no spill.
  16. ChapmanF
    18,547
    And if that one really said "No. 1 Cylinder Head Cover", Encyclopedia Brown would know it was a forgery.
  17. CR94
    CR94 Senior Member
    2,749
    1,205
    Northwestern S.C.
    A small regular (non-offset) funnel works best for me if I leave the "plastic beauty cover" on. The funnel must tilt forward to clear the cowl, and the plastic cover nicely prevents it from tilting too far and falling out. That way, it's stable, so I don't have to hold it in place.
  18. Mendel Leisk
    41,903
    I use a medium sized, non-offset funnel, with the cover off. Jammed in the fill hole and against edge of cowl, it “works”. Looks awkward but meh. Maybe if I’m browsing in an automotive store I’ll pick up an offset funnel sometime; it would be an improvement.
  19. CR94
    CR94 Senior Member
    2,749
    1,205
    Northwestern S.C.
    That may be about the same thing I do, with a tilted plain funnel wedged between cowl and the edge of the opening in the plastic cover. It "works" well, as long as I don't try to pour too fast.
    Depending on circumstances, the top half a 1-quart oil bottle can be a useful offset funnel. I doubt it would be as stable as the round funnel in that spot..
  20. ASRDogman
    7,821
    3,983
    Easy inexpensive funnel
    jzchen likes this.
