Seized transaxle after swapping
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ThulsaDoom, Mar 26, 2017.
  1. ThulsaDoom
    ThulsaDoom New Member
    Hello all,
    I changed the transaxle on my 05 Prius yesterday.
    After putting everything back together, while the car was still on jack stands, I started the engine. The ICE starts and idles fine.
    I put the car in drive and slowly lift my foot from the brake pedal...the passenger side wheel begins spinning, but the driver's side doesn't spin...It jerks, there are loud clunk noises and the engine begins to stall... As though something is seized.
    With the car idling in park, I can manually spin the wheels. Spinning one wheel by hand causes the other wheel to spin in the opposite direction.
    I double checked all my connections and I also swapped the parking lock mechanism from my original transaxle to no avail.
    Should I get another transaxle?
  2. JC91006
    JC91006 Senior Member
    16,496
    8,406
    Turn the traction control off by putting the car in inspection mode.
    With traction control engaged, your car will do what you're describing
    m.wynn, ILuvMyPriusToo and edthefox5 like this.
  3. ThulsaDoom
    Thanks for the reply!
    I did that, now it turns but still isn't right. I shot a video, but I can't post a proper link yet.
    ://goo.gl/photos/5Q1L1s8CpAtry5Yu5
    Copy and paste the text above, but type in https in front please.
  4. JC91006
    16,496
    8,406
    Why don't you set it down and drive it?
    edthefox5 likes this.
  5. ThulsaDoom
    Do you think the noise may go away if I do?
  6. JC91006
    16,496
    8,406
    I don't know but you already have it installed, drive it and see what happens
  7. ThulsaDoom
    That's a good point. I won't be able to do it until tomorrow afternoon. I'll report back then. Thanks very much for your help!
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    Nice one JC freakin' spot on as usual.
    m.wynn likes this.
  9. ThulsaDoom
    Ok, just finished a five mile test drive.
    The noise from the video is non existent and the car ran normal
    Thanks very much JC, I really appreciate it!
