"B" is for......
Discussion in 'Fred's House of Pancakes' started by ♡myPeeus, Apr 5, 2017.
  1. ♡myPeeus
    ♡myPeeus Junior Member
    61
    57
    US
    Okay can someone please explain the "B", gear on a 08' Prius? People whom don't own one of our beauty's and tell me that you should not use that gear on the highway,? The dealer whom I purchased the car didnt exactly explain it, but I use it when I am in the city. Can you use it while on the freeway or is it for city traffic only?
    Confused In a Hurricane of talk.
    Any input would be awesome!
  2. Noobprius
    Noobprius Junior Member
    43
    US
    It is motor braking. It slows down the car faster than normal coasting. Look at the manual for more information.
    RCO and ♡myPeeus like this.
  3. bisco
    52,369
    it's intent is similar to low on an automatic transmission. it uses engine braking on seriously long mountainous downhills. saves your friction brakes.
    living in new england, i have never used it in 13 years.
    HPrimeAdvanced, RCO and ♡myPeeus like this.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You use B from the top on long steep downhills (about 600 foot vertical drop or more) to keep the battery and disc/drum brakes cooler. This is the same way you would use L in another car.
    You always get lower MPG in B, but if the hill is long and steep enough, MPG is not everything.
    #4 JimboPalmer, Apr 5, 2017
    ♡myPeeus, valde3 and WilDavis like this.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I use "B" for "stealth" braking! (Think about it! :cautious::whistle:)
  6. bisco
    52,369
    wouldn't that be sb?:cool:
    HPrimeAdvanced and ♡myPeeus like this.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    For those times you WANT to be rear ended!
  8. Mendel Leisk
    41,880
    This is the only time I use it:
    Any flatland or short hill application is a waste of time, and bad for mpg.
    ♡myPeeus likes this.
  9. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    P.S. Most all of these "forums" have a search function.......which allows you to see all of the previous discussion of common questions.
    This is one of those questions that has been discussed MANY times before on here.
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Toyota was too honest to call it L, since it is not a lower gear, but if they had, we would get WAY less discussion about it. It legally fulfills the purpose of an L gear.
    ♡myPeeus, WilDavis and wrprice like this.
  11. WilDavis
    2,493
    2,155
    49
    ...or for when my inquisitive followers want a really close-up view of what I'm carrying in the boot! "B" = "BUMP" | "BOOT" | "BUM" | "BANG" :eek:;)
    RCO, ♡myPeeus and bisco like this.
  12. bisco
    52,369
    if we didn't have people asking the same questions over and over, we'd be out of B = business.
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I just never want my car to get hit, that may be a difference in attitude.
    ♡myPeeus and WilDavis like this.
  14. ♡myPeeus
    61
    57
    US
    I apologize if I doubled up on this discussion, I am a new member to this "Prius " application and had no idea how many times it had been discussed. I apologize
    MERGED
    Thanks everyone! I am glad my questioned was answered. I have used it going down the canyon when the grade of the hill is very steep, it saves your brakes. I have been mislead by the dealer in this case and went on my instinct about it from just how the vehicle responds when it is in that gear and it reminded me of a "Jake brake", installed on semi trucks engines. But subtract the darn noise.
    I appreciate you all for clearing this up and even the funny answers! :) xxx
    HPrimeAdvanced and Mendel Leisk like this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Afraid not. In stealth mode the S is obscured without the use of smoke or mirrors.
    MERGED...
    FWIW, I'd disagree with the B mode being bad for mpg when descending any hill. You would only be coasting with no ICE, or braking with regeneration. For example example, a recent road diversion puts me on a long winding decent with a 20 mph limit which is busy with mixed traffic including juggernauts. Using B I still have to use the brakes and notice that regeneration increases then, just like in D. And the friction brakes come on too when needed.
  16. Mendel Leisk
    41,880
    It could be you're noticing the greater engine breaking, misidentifying it as regen. AFAIK, B mode's express purpose is to reduce regen, with the engine-brake tactic, thus to delay having a "fully sated" battery, and the car dumping all the braking task on the friction brakes.
    If this happens when you've still got miles of steep downhill still to come, you could well overheat the brakes.
    But the common denominator of such scenarios is it's long downhills; a local up-and-down hill, you're better served just using the brakes. Simpler too.
    One thing: all of this is just lore, cobbled together on PriusChat and a few others. Toyota's woefully quiet on the subject: a terse sentence or two, which leaves owners "talking among themselves".
    #16 Mendel Leisk, Apr 6, 2017
  17. WilDavis
    2,493
    2,155
    49
    I vote for this one! :rolleyes:
  18. FA6
    FA6 Member
    45
    150
    The best use of B:
    You are going, say 100mph and zip by a cop that was hiding on the other side of the hill.
    Ouch:eek:!!!! If you slam on your brakes, the cop would, by seeing your brake lights come on, know that his radar gun was NOT malfunctioning and that Prius (!) was in fact going the indicated 100mph that his gun recorded!
    BUT, if you go into B (Stealth Bomber:cool:) mode, you slow down without giving away your panic braking to the perplexed cop:unsure:, who now bangs his radar gun on the palm of his left hand and shoots at you again, showing the accurate (and proper) 75mph that any proper Prius can and should achieve when pushed to its puny limits:LOL:.
    He sighs with relief as his mind confirms his preconceived notions about the Prius:rolleyes:.
    You go out of Stealth Bomber mode and bomb the next uphill:sneaky:.
    ♡myPeeus and HPrimeAdvanced like this.
  19. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Gosh, that's REALLY steep. I'm amazed that even the B function can cope. I'd never try to drive down a hill that steep. You must be insane!
    And how do you make it back up the hill? No car could get up there, apart from maybe a Land Rover with a winch. Bits of it are beyond vertical!
    Oh, wait.... Is this picture taken from above?
    That's OK then.
  20. Trollbait
    12,672
    It is possible to pull up the elevation changes of a route in line graph form in the Googel Earth app.
    RCO likes this.
