Prius traction battery replacement issues.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nick linux, Apr 5, 2017.
  1. nick linux
    nick linux New Member
    corvalllis or
    I am following a Youtube guide for replacing the hybrid battery and i have just taken off the cover to the terminals and have run into an issue. my tutorial says that after removing the electrical safety plug( orange thing on battery to pull off) that on both sets of terminals there should be zero volts where instead the ones connecting to the leads have no voltage but the others are putting out about 105 volts.is this normal and my tutorial is wrong or is there something more wrong with the battery. Inked20170404_210425_LI.jpg
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Make sure you have the orange HV safety plug removed and the 12v accessory battery unhooked.
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Ditto the above. To reiterate, no that's not normal and do not proceed until there's no voltage at those terminals. Good thing you checked.
  4. nick linux
    corvalllis or
    Yes i am sure that i have the 12v battery unplugged
  5. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    You're voltmeter has a very high impedance, at least 10 Mohm. The slightest leakage current will show voltage. You could get a banana jack and put a 1/2 w 470 kohm resistor across it to load down your meter. Or you could just not worry about it.
  6. nick linux
    corvalllis or
    How should i proceed in troubleshooting/diagnosing why this is happening.
