What Did You Do To Your Gen II Today?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by romad, Oct 26, 2014.
  1. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Installed a 34 inch LED light bar behind the billet lower grille: Prius.jpg PriusOn.jpg
    Wired up to the factory fogs through a 40 amp relay. Stupid bright, now I can see the kamikaze rabbits in the morning.
    Justdidit likes this.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    put ice blue led bulbs in my fog lights; much brighter than the oem bulbs. we'll see if they start strobeing or simply quit in a few weeks like all the cheap ebay bulbs usually do.
  3. gatoman39
    gatoman39 Junior Member
    Netherlands
    So this happened today... E43B6019-AC77-4C03-8EE0-A34E940A0B0F.JPG 42B681B2-4E96-43D2-88BC-142477A5275E.JPG
    ZFL, Prius Gang, Justdidit and 2 others like this.
  4. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Nice! I'd be tempted to add window deflectors, plus remove the poor excuse for rear windee-wiper! (just the arm/blade so that it can easily be re-installed for annual state-inspection) ...just sayin' :rolleyes:
  5. gta_
    gta_ Active Member
    189
    134
    Tracy, CA
    Didn't do it myself, but got the windows tinted this morning.
    TheBigD and offib like this.
  6. 69shovlhed
    2,170
    748
    Delaware
    looking good! now de-badge the hatch.
    gta_ likes this.
  7. a1rjumpman23
    a1rjumpman23 Junior Member
    75
  8. gta_
    gta_ Active Member
    189
    134
    Tracy, CA
    Already planning on it :D
    40% front, 15% rear.
  9. offib
    offib Member
    162
    95
    Dublin
    Four Touring
    Recently passed 150,000 miles, and roughly 1000 miles ago, I was suffering from severe problems that many might've suggested was battery failure.
    In the end - I found out that whoever most recently serviced my car and cleaned the fan forgot to plug in the battery fan. The pack overheated after 40 mins of driving and the computers slowly reducing its use - to the point the car couldn't accelerate right or overtake at all. It caused all kinds of lights and problems and eventually hazardous driving.
    Now, lights are gone, drive quality is improved and average consumption has improved up by ~10 mpg, and that's with spirited/busy driving quite often with passengers and stuff. On my own, I could get up to 80 mpg on some journeys.. It's also pulling in EV mode in places I never thought possible.
    #189 offib, May 31, 2017
    jerrymildred likes this.
  10. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    I took 8 years and 100,000 miles off my wife's battery. Yesterday I replaced the traction battery in my wife's '07 with the cells from a '15 with 18,000 miles. Todd at @TampaPrius.com had put the cells and other parts into a gen 2 battery case and I did the battery swap in a few hours. Reason was a bad cell in the old battery and lots of corrosion throughout making and individual cell replacement look like a low possibility of long term success. This setup gives me all "new" cells that were out of the same battery. The car is amazing now! I took it for a 30 minute test drive this morning. Some 55 mph, some stop and go, some 50 mph steady, some 30 mph residential. I'm a happy camper now! IMG_6061.JPG
    ZFL, peecee, dolj and 2 others like this.
  11. peecee
    peecee Member
    67
    39
    Annapolis, MD
    That sounds like exactly what I'd like to do. I've heard that it's a possibility. Is this a normal Toyota dealer job? How long was the car down for? Was there a ballpark to the price? Did you obtain the batteries, or did the dealer find them for you? Did you post up the process in a thread here, or just this post? Thanks for letting us know how to extend the life of the Prius!
  12. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    No corporate Toyota dealer would ever do something like this, though I did read about one installing a Dorman battery once o_O
    Everything was handled by Todd ( @TampaPrius.com ) aka Home - Tampa Hybrids Inc.
    Here is the thread : Augh!! P3000, P0A80, P3021, C1259 on an '07 | PriusChat
  13. jerrymildred
    11,518
    14,124
    Tampa, FL
    Thanks, SFO. You beat me to it. If you check Todd's web site, you'll see that he specializes in Prius and also is branching into others now as well as battery only like the 1st gen Leaf. Todd also buys totaled cars and makes them available for repairs if someone doesn't way to buy new parts.
    We've probably all seen threads here about members replacing cells only to have other cells fail soon afterward. Or maybe even the "new" cell because it isn't really new or because it's not a good enough match to the others. Todd found that, on top of that, there is often a lot of corrosion in the battery wires and crimp connectors. Both the current carrying wires and the communication wires turn black WAY back under the insulation and inside the crimp connectors. So he sells replacement wiring harnesses too.
    And he has started taking all the cells out of totaled Gen 3 cars and retrofitting them to the battery cases for Gen 2. He sells the whole thing ready to put in your car, or he'll do it for you. How much it costs will depend on how new you want the cells to be and how much work you want to do yourself. You can get one with cells from a '15, a '14, and so on. His phone number is on the web site SFO gave you if you want to call him.
    I've accessed the battery before when installing Prolong grid chargers, so I'm pretty quick at getting to it. I was a little more deliberate when it came to actually taking it out since this is dealing with some potentially dangerous voltages. The only hard part is actually horsing it out the back of the car. Easier with two people. I got it out myself, but I'm fairly strong for an old fart and I laid a piece of plywood over the spare tire well to make it easier and protect the wires I'd have to move it over. Here are links to three videos (parts 1, 2, & 3) showing how to replace the battery. The videos and the tear down manual I used show to remove the rear seat bench. I don't know why. I just removed the seat backs and had no problems at all. Maybe that's just to keep the seat clean?
    TheBigD and ZFL like this.
  14. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    Day before yesterday- Had the 120k service done, new serpentine belt and 12v battery installed. Turns out trans fluid WAS changed at 90k before we bought the car so I skipped that.
    Today- had the wiring harness for the Prolong battery conditioning system installed. I'll start the actual conditioning process a week from Monday (on the 12th).
    ZFL, offib and jerrymildred like this.
  15. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Yesterday I gave my prius a little cosmetic face lift. I finally situated some 4 sided LED bulbs in the headlight. Still need to do some fine tuning because the headlight assemblies are aftermarket and have an extra adjustment not on the OEM ones. I put in the brightest lumen LEDs in my fog lights I still don't think they are bright enough. BUT after all the screwing around putting aftermarket fogs into an aftermarket bumper I am done for now. I put a shinny bolt on billet on, and a hood protector. Now I am looking to do inverter, transmission and radiator flush because I don't know what has been done before I got it with 188,000. Now it has 237,000. I included a few pics.
    ZFL likes this.
  16. TheMole
    TheMole Junior Member
    25
    17
    SoCal
    The paint on my rear door handles were cracking/fading so I decided to install some chrome covers. Fitment isn't perfect, but can't complain for $13 on ebay. I added some additional 3m tape for reinforcement so they don't come flying off on the road.
    IMG_20170613_183734.jpg IMG_20170613_183753.jpg IMG_20170613_183801.jpg IMG_20170613_183807.jpg
  17. gta_
    gta_ Active Member
    189
    134
    Tracy, CA
    Did an oil change and tire rotation over the weekend. Pulled off my rear badges on lunch today (cause it's that hot lol), just need to use some adhesive remover when I get home to get the rest of the old tape off.
    Now I count the days until this heat wave is over, so I can install the Rear Sway Bar, Front Strut Bar and Midbrace I got from Justdidit's for sale post. Also need to check the HV Fan, to see if it needs cleaning since I've never done it since I got the car and have no idea what the previous owner used to transport lol.
    ZFL and Justdidit like this.
  18. 69shovlhed
    2,170
    748
    Delaware
    I found a rodents nest next to the hv battery when I cleaned my fan. you might want to check it soon.
    gta_ likes this.
  19. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    Those actually look really nice on your car! I'm not a big chrome fan, but it flows well
  20. TheMole
    25
    17
    SoCal
    Thanks! I'm not a chrome fan either, but didn't think it would stand out too much on a silver car. I was thinking of getting the black chrome ones, but couldn't find any that had 2 front handles with smart key button holes. Someone should make some pre-painted covers for these cars as the fading/cracking seems common.
    Zaklax92 likes this.
