So groceries don't fit in the Prime cargo area?
Discussion in 'Prime Main Forum (2017-2022)' started by Lee Jay, Apr 27, 2017.
  1. bisco
    52,390
    you've finally figured out who the designers were targeting.:p
    ruby and Trollbait like this.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Probably because it was the first time she ever saw one. I had the same thing happen with my CMax and Nissan Cube as I was one of the first to own one of those in my neck of the woods. Now? Never get a second look in either the Energi or Gen 2. Old hat.
  3. Tideland Prius
    16,619
    No idea. I was just speculating on the modular platform theory. I have no information that it is true.
    It could very well be what you theorised earlier - they went with a smaller pack, TMS said "nope, won't sell in the US". TMC went back with a bigger battery that would fit the target EPA miles (I assume there was some negotiation btwn TMC and TMS as to AER and physical battery size) and the Prime is the compromise they went with.
    Perhaps with the smaller battery, the Prime would've fit 5 but because of the "last minute" change to increase AER, they had to compromise on that to hit the efficiency target?
    We'll never know cause Toyota will never divulge on the details but it also gets you thinking as to how the manufacturers operate (or at least you think they would) when they design a car for a particular market. (the engineering part, not the marketing part where they include/exclude features/specs)
  4. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Don't undersell Toyota's ability to take advantage of the flexibility their design offers.
    Other automakers are simply stuck when the market changes.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Why did or does The Prius have anything BUT a great reputation for cargo capacity?
    I kinda love hatchbacks for that very reality. I expect they can hold a lot.
    My 2013 Prius was great in that regard.
    My only very, very slight annoyance, was the horizontal nature of the glass on the hatch, means you have to be aware of the height of anything you are putting underneath that area. But once you get a feel for how high you can go? It's was great.
    My Honda Fit has a more vertical hatch, but without folding the seats down, less automatic space in the back, more akin to a Prius c, size.
    It would be interesting (At least to me) to do a cargo battle between a Prius and Honda Fit with the seats down, and see who could hold the most. I actually think the Prius would win, but it would be close. The Magic Seats on a Honda Fit would give it the edge, I would guess over a Prius c.
  6. Tideland Prius
    16,619
    The Fit can fit a lot for a small car (closest competitor would be the Toyota Ractis but will still lose because it lacks Honda's Magic Seats)
    To be fair, it's still one of the more usable PHEVs. The other being the C-Max Energi.
    Again, I think the width helps (e.g. it can fit a golf club set without folding down the seat). The others (Volt, Ioniq) rely on depth to get the same volume.
  7. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    I assume Toyota knew for a long time they had to go with 8 kwhr battery for CARB credits/CA HOV.
    We had articles to that effect a long time ago that PiP1 was not cutting it for CARB.
    Toyota were probably between a rock and a hard place, feeling from a style view point, they had to make Gen4 more sedan-like, really takes quite a bit of rear space away. The chasis was really made to fit Japan 4WD Gen4 option and Prime solar option, not so much to hide the Prime battery for the US market. They must have felt Prime would sell adequately with the reduced cargo space. Demand seems solid.
    #47 wjtracy, May 1, 2017
    heiwa and drysider like this.
  8. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    When heading out to buy all those groceries, why not leave the cargo cover at home? Or remove it and lay it lengthwise in the cargo space? Why not fold the rear seat backs down? You got everything in, but it seems like you did it the hard way.
    Do people really find the cargo cover useful? I never have.
    Prius from Dad likes this.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    First thing I do with all new cars is take the stupid cargo cover out and set it in the garage to only return when the vehicle gets sold.
  10. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I wasn't at home, I was at work and didn't have any place to leave it.
    Because then everything has to sit on top of it.
    If everything fits without doing that, it's better not to because the stuff is better contained. It doesn't slide around when going around corners and it doesn't fly up in a panic braking situation.
    I do, but rarely.
  11. Mendel Leisk
    41,901
    Will the cover stow somewhere in the car? Third gen had a spot, under the hatch floor.
  12. Lee Jay
    5,850
    4,036
    Yes, but it stows in the same slot that you can use to store the charging cable. They don't fit simultaneously and I had the charging cable in there at the time.
    Removing the cargo cover doesn't really add any space for smaller items like groceries. It certainly helps with large items.
  13. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I used it maybe once in the 7 years that I have owned a Prius. I thought it made my car look like there was something valuable under it, and since there is nothing of value, I figure I should advertise that fact. :)
  14. Mendel Leisk
    41,901
    Is it still white coloured? Kinda good for transporting ice cream home.
  15. fuzzy1
    10,603
    I don't want to establish a pattern of it being closed only when something valuable is under it. Keep it closed nearly all the time, to keep them guessing, keep their yield low, and encourage them to find a different career.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I always keep my cover in place unless it's in the way. It doesn't say you're hiding anything any more than a tonneau cover on a pickup truck. It just tidies things up a bit. And it shades the battery increasing the delay before it gets as hot as the rest of the car. That's kind of a big deal down here.
  17. Tideland Prius
    16,619
    Mine's almost always pulled closed. I'd rather the tonneau cover discolour than the carpets (due to sun) since the cover can be retracted. Plus, the albedo is a touch higher than the carpet itself.... so maybe it helps reflect more light back? I do not know lol.
    But it's more of "it's closed whether I have something inside or not"
  18. bisco
    52,390
    in 3 pri, i have never used the tonneau cover. it's just one more thing to mess around with every time i'm in and out of the hatch, which is a lot. maybe theft isn't as big a concern around here. the new owners get a brand new one stowed away for posterity.
  19. Lee Jay
    5,850
    4,036
    One of the reasons I like floor space more than vertical space, and one reason I rarely use the cover. E500_16471.jpg
  20. bisco
    52,390
    sure, but try putting a harrier in there.:cool:
