Do you use parking brake?
Discussion in 'Prime Main Forum (2017-2022)' started by Michael Nielsen, Feb 11, 2017.
  1. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I haven't used or needed to use a parking brake since my shifting days of yore. Never had a problem.
    Lee Jay likes this.
  2. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    I use the parking brake all the time. Old habit I guess.
    Data Daedalus likes this.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I only use it when necessary!
  4. Sandollars
    Sandollars Prius Maven
    134
    157
    SoCal
    Never use them unless the parking angle is more than 3% then I MIGHT use it
  5. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    On the few occasions I have not set the parking brake, the car moved a bit and then jolted to a stop. I didn't like that feeling. Is it resting on the transmission?
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Well, Prius doesn't really have a transmission, but park effectively puts a "pawl" in the drive line, thus preventing it from rotating.
  7. fuzzy1
    10,600
    For those of us who still regularly drive manual transmissions (no slushboxes in my household, dad's only slushbox is a diesel tractor/loader), a blanket policy to always engage that brake is still a good idea.
    But then, households still driving mostly MTs are scarce these days.
    Prius from Dad likes this.
  8. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    Thank you. that's the word I was trying to think of. Pawl. So apparently it's ok for the weight of the car to rest against the pawl? (Probably not while parked on a downslope)
  9. Lee Jay
    5,850
    4,036
    In my manual transmission car, I used the parking brake on maybe 1 in 100 times I parked. Only on grades exceeding something like 5%.
  10. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    There is no parking in neutral but i guess if you apply the parking brake then put in park it will not put as much pressure on the pawl.
  11. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    Thanks. That's what I do, as per the owner's manual. Depress foot parking brake. Then press the P button. Then power off. What can I say, I'm a "by the book" person.
  12. CharlesH
    2,797
    1,164
    Roseville, CA
    Yes, I know the software won't allow the parking pawl to engage when the car is moving. I know that it is likely not necessary. But it "feels better" to be at a complete stop using the parking brake, and then press the"Park" button. To each their own.
    sonomac likes this.
  13. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    Used it all the time on my manual 5-speed 1985 Celica GT (miss that car!).
    Other than that, only use it when on a discernible up or down slope.
    I also just power off my Prius Prime when I am going to park it. Sets it to park and powers off everything in one button push. What can I say - I'm lazy :)
  14. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Nice, my only other brand new car, besides my Prime, was a '75 Celica GT. Sweet ride! Shifting on that was like an automatic. (miss that car too)! ;)
    Pdog808 likes this.
  15. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    gen 2 video
    Lee Jay likes this.
  16. orenji
    orenji Senior Member
    5,887
    3,488
    Always use it, less stress on the transmission parking fork.
  17. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    Sl
    So...we're supposed to use chocks when changing a flat?
  18. Mendel Leisk
    41,837
    Switch it around: instead of thinking what you're supposed to do, think it through for yourself. Securely chocking fore-and-aft, the wheel diagonally across from the corner you're raising: the car (and the jack) is going to be a lot more stable. Solidly applied parking brake is a good contender too.
    I have a set of 4 (heavy) solid rubber chocks in the garage, but I keep another lightweight pair in the car.
    fuzzy1 likes this.
  19. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    do you use your blinkers? daytime running lights? AC? headlights in rain? Some people are afraid they will lose .000008 mpg. Some nuts don't even use seat belts.
    Db17 likes this.
  20. CharlesH
    2,797
    1,164
    Roseville, CA
    In California, you can get a ticket for not turning on your headlights when your windshield wipers are on.
