Failing Traction Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by allo4324, May 1, 2017.
  1. allo4324
    allo4324 New Member
    DMV
    Hello,
    First post here. Hopefully this is the right place ;)
    I have the dreaded P0A80 code and know I'm due for a new traction battery at this point. I'm over 200K miles so it's had a good run. I read around some and it looks like a new pack and installation is going to run roughly $3K or more. I've seen some other write ups where a refurb pack and install at various locations runs from $700 on up.
    With that being said I'm hoping someone may know of a good shop or person in the DC metro area who can do refurb pack installs (or at least a good person/place to chat with)... Can anyone help point me in a good direction? Thanks!
  2. allo4324
    allo4324 New Member
    DMV
    Anyone???
  3. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Sorry, I don't know of any but maybe @wjtracy does (or knows someone who can recommend one).
  5. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I replaced my battery two days ago at an independent local shop. It was $2200 for a reconditioned Dorman battery. Can't help with the DC area
  6. bisco
    52,419
    have you tried google?
  7. Wilsid
    Wilsid Junior Member
    91
    I had the same thing it was one module I replaced it for $36.47 on ebay,am good to go, i also
    put 1 & 28 in the center and so on. as I see it you can save a lot of money replacing a
    module.
  8. csutton7
    csutton7 Junior Member
    Spartanburg, SC
    Did you go through the whole "balancing" act? Or just replace the cells and hope for the best?
