New member
Discussion in 'Gen 2 Prius Main Forum' started by pTomic, May 22, 2017.
  1. pTomic
    pTomic New Member
    Serbia
    Hello. My name is pTomic, and I live in Serbia, Europe. :) I get some offer to buy used Prius, manufactured 2007. I'm think that is second generation. :D On which problem I need to pay attention ? Seller said that batteries are good, and that car mileage is about 175K Km (~108K miles).
    Thank you in advance for your time and effort.
  2. Prodigyplace
    12,520
    11,740
    Central Virginia
    Welcome to PriusChat.
    I am sure some experienced Gen 2 owners and former Gen 2 owners will be coming soon to add advice.
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    One issue is the reliability of a ten-year-old chemical battery. The car you're looking at has relatively low usage, but the battery is not mechanical rotating device. Its life depends on factors such as number and depth of charge cycles and storage temperature, which are unknown. Replacements often cost more than the market value of the car. It may be a minor risk statistically, but you should be aware of it.
    An experienced Prius driver can sense the health of the battery during a test drive. And test equipment is available for the home mechanic, but again it takes some experience.
    Other factors are common to any ten-year-old car.
    #3 andrewclaus, May 22, 2017
    jerrymildred likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Basically, what Andrew said. And welcome!
    My wife's 2007 has about 118,000 miles (190,000 km). It has no issues at all. But air conditioning, power brakes, HV battery, are future possibilities.
  5. Prodigyplace
    12,520
    11,740
    Central Virginia
    Do you guys think a grid charger / conditioning system would be a good investment for the OP?
  6. jerrymildred
    11,517
    14,147
    Tampa, FL
    Absolutely. Unless there's a place he can take it to to have it done. It is a little expensive for my income level. We got one because we had two Prii to maintain.
  7. JC91006
    JC91006 Senior Member
    16,759
    8,562
    The new batteries in Europe are half the price compared to USA. Just buy new when needed
  8. bisco
    51,801
    welcome!
    the thing with an old car is having a good repair shoppe, because anything can go wrong at any time. in the case of prius, it must be a well qualified hybrid repair shoppe, unless you are a very capable diy'er.
    all the best!(y)
  9. dolj
    dolj Senior Member
    8,407
    4,281
    Wellington, New Zealand
    How did you come to that conclusion? Prices I've seen quoted looked on par with US.
  10. JC91006
    16,759
    8,562
    Actually in the UK. My father in law asked recently and it's £1150 for a new battery and £250 labor to install
  11. dolj
    dolj Senior Member
    8,407
    4,281
    Wow, that is a good deal, last one I saw was around £1700 + labour. Is it a sign of things to come? I'd be over the moon if I could get that sort of price in NZ equivalent; NZ$1983.80 + NZ$431.26 = NZ$2415.06.
    May be they forgot to add the VAT?
  12. pTomic
    pTomic New Member
    Serbia
    One more question, what if I want to get a new coded keys? Because I'm not sure if the seller gives me all keys? I know that if you have Mercedes you can ask them (dealer) to get you new set of coded keys, for reasonable price (50-60€, $55-$70).
    iPad ?
  13. Prodigyplace
    12,520
    11,740
    Central Virginia
    The Prius has 2 types of keys. There is the electronic key fob and each fob has a traditional mechanical key for use if the electronic fob has issues. You should have received 2 fobs each with a mechanical key that fits your car locks.
    The fobs are electronically paired to the car, usually with the dealer Techstream software. If you only received one fob they can unpair the other one. I know the mechanical keys are coded but I think they only come with a fob.
  14. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
  15. Prodigyplace
    12,520
    11,740
    Central Virginia
    Welcome for sure!
    I got too involved in answering your question.
  16. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    Check the headlight leveling sensor. It's in the back driver's side wheel well. The thing corrodes and costs a ton to replace and is a hassle to repair.
    I would remove it from the car and open it up to check the springs for corrosion.
    That's the only thing that went bad on my 2nd generation Prius with ~118k miles
    pTomic likes this.
  17. pTomic
    pTomic New Member
    Serbia
    I'm still looking for some good Prius that will fit my budget. :)
    One more question: Can mileage on odometer be changed ? Something like it's passed 250K miles and odometer shows 125K ?
    Sorry if I bother you.
    iPhone ?
