Red Triangle, ABS Lights, Hybrid Battery Not Charging
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ChesterPri, May 25, 2017.
  1. ChesterPri
    ChesterPri New Member
    Austin, TX
    I need some help with my 2006 Prius that won't start anymore. It has 61k miles on it. When trying to start, it shows "There is a problem with the transmission lock mechanism." Many have suggested a 12v battery replacement and that did not work for me. All cells in the hybrid battery are sufficient voltage as well. The red triangle was turned on by the dealer when they did some "rerouting of wiring" to the front struts. The last time the car turned on, the hybrid battery was not recharging from braking or the ICE. Any suggestions to help this sad lil car?
    #1 ChesterPri, May 25, 2017
  2. JC91006
    JC91006 Senior Member
    16,825
    8,600
    if the dealer broke it, they should fix it
  3. ChapmanF
    18,486
    All I can suggest is to read the trouble codes from the transmission control ECU (and any others that may be reporting codes), look those up in the repair manual, follow to the linked pages with the steps for troubleshooting and repair, and do those. It works amazingly often.
    -Chap
    ChesterPri likes this.
  4. ChesterPri
    Austin, TX
    They should, but they're 100% convinced it's a bad hybrid battery... which it's not, but they're not very friendly nor knowledgeable there.
  5. JC91006
    16,825
    8,600
    they must have provided you with the car's codes?
  6. windstrings
    6,280
    378
    Central Texas
    Go to another dealer.
  7. bisco
    52,337
    why would they have to reroute wiring? i've never heard of that.
    windstrings and jerrymildred like this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Did you take it to a Toyota dealer??!! I think I'd be in touch with corporate. AND going to a dealer who might know what they are doing. I had to do that with an air conditioner many years ago. Every two weeks, the car vented its freon into the cabin, even after five times in the shop.
