Price of 1st service?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by raspy, Jun 5, 2017.
  1. raspy
    raspy Senior Member
    438
    699
    London, UK
    I am curious how much you've been quoted when you've booked your 1st service. I just called my local dealer in London who said 1st service is £185 (equivalent of $239)
    51,832
    :eek: what does that include? oil & filter, tyre rotation and inspections?
  3. raspy
    raspy Senior Member
    438
    699
    London, UK
    I assume so. Are Toyota the type who charge you an extra 40 pounds simply to fill up the windscreen washer fluid?
  4. bisco
    51,832
    it's dealer by dealer, and we get everything free over here for 2 years/25k. do you have to bring it in once a year for an extended battery warranty or something?
  5. Prodigyplace
    12,526
    11,747
    Central Virginia
    The 5K mile service here is basically tire rotation & general inspections (including floor mat fit ), The 10 K adds oil & filter change.I just changed the oil and filter myself on my 2017. It is not very difficult with the correct filter wrench.
    As a plus, you know it is done correctly. I remember reading about a poor user here whose oil drain plug came loose after a dealer change and he lost all his oil :eek:
  6. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Do some shopping, it might be cheaper at a dealer outside London.
  7. Mendel Leisk
    41,295
    Maybe look in your Maintenance Booklet, and post what it is that's to be done. Otherwise it's hard to say.
  8. Prodigyplace
    12,526
    11,747
    Central Virginia
  9. bisco
    51,832
    that wouldn't be the first service, though i must say, brake fluid every 2 years/20k is interesting.
    i wonder if 'inspecting the spark plugs' requires removing them.(n)
  10. DonDNH
    1,711
    655
    Nashua, NH
    Four Touring
    Not if your mechanic is trained in laparoscopy.
    RCO, raspy and bisco like this.
  11. Mendel Leisk
    41,295
    I tried searching for the Toyota UK "service booklet" and "warranty booklet" for about 10 minutes, something that simply/concisely spells out time/distance and required maintenance, but came up with a complete blank.
    At the following link, mention of how they "love" to service your car. Also talk of "intermediate", "full" and "full plus" service. Talk about "booking a full service". There's an "essential care" pdf link, with "silver and "gold" levels (one wrench vs two). This is not some dealership drivel, this is the party line from Toyota UK.
    Servicing | MOT, Servicing and Maintenance | Toyota UK
    I'm getting the sense they've got a real cash cow, starting to appreciate @raspy 's dilemna.
    #11 Mendel Leisk, Jun 5, 2017
  12. bisco
    51,832
    two wrenches with one hand tied behind their back?
    RCO, DonDNH and Mendel Leisk like this.
  13. Prodigyplace
    12,526
    11,747
    Central Virginia
  14. Mendel Leisk
    41,295
    ^ For sure they're:
    1. Doing an oil and filter change
    And I think they are, but they say everything but:
    2. Rotating the tires.
    And I'd surmise they're doing:
    3. Visual-only inspection of brakes, just in the course of tire rotation.
    All the rest of it, the myriad "checks", is pure BS imho. What they're actually doing, should be about $60~80 US.
    raspy likes this.
  15. bisco
    51,832
    they do generally top off your fluids for 'free', which may or may not lead to overfilling certain things, or different substances being spilled into the engine bay.;)
    Prodigyplace likes this.
  16. Mendel Leisk
    41,295
    I would try to keep them the hell away from the brake fluid reservoir. A properly functioning brake systerm is one item that never needs topping up: level goes down as pads wear, and when they get replaced, comes back up to where it was at the outset. Coolant, I needed to top up both reservoirs once, after 6 years plus. Windshield washer reserivoir:, there's no way I'm going to pay a guy $100 an hour to top that off.
    When that gets old they move on, to spraying copious amounts of white grease all over the door hnges and the general vicinity.
    And after that they bleed air outa your tires, lol.
  17. Prodigyplace
    12,526
    11,747
    Central Virginia
    RCO, kithmo, raspy and 1 other person like this.
  18. Mendel Leisk
    41,295
    ^ I'd go with option A, lol. Wouldn't you just love to be a fly on the wall when they run through the check list. :whistle:
  19. Prodigyplace
    12,526
    11,747
    Central Virginia
    They can get an actual leather steering wheel in the UK.
  20. raspy
    raspy Senior Member
    438
    699
    London, UK
    I don't have one. I had to call up the service desk at the dealer and ask them about the intervals. They didn't sound THAT confident when telling me it was 10k miles/12 months, whatever comes first. I got the feeling that if I had said, "is the first service due after 500 miles, they would have just said yeah, probably.
    Yes. My experience of Lexus here in the UK is that I walked in for a simple service, and walked out with a seriously big hole in my wallet. I expect Toyota maybe similar. You should see the waiting area of my Toyota dealer. It's quite fancy, a coffee machine AND free pastries. They even offer "free" collection/delivery from home for the service.
    Thank You for doing all this research chaps. Much appreciated. So given that their hourly rate for anything is almost £180, then it sounds like the service is 30-40 minutes of work and the rest of the money on oil and filter?
    Indeed. Sadly, because it's leased from Toyota themselves, I have to get it serviced rather than do it myself.
    RCO and Prodigyplace like this.
