Design Flaw for windshield
Discussion in 'Gen 4 Prius Main Forum' started by Skip50, Jun 8, 2017.
  1. Skip50
    Skip50 New Member
    Des Moines IA
    Three Touring
    We purchased a 2017 Prius 3 touring late December 2016 in the following 5 months we had 3 cracked windshields from rock chips that went immediately to a long crack. The last chip (in May 2017) was delayed for repair because there were 9 replacement windshields back ordered. I would guess there were more than 9 broken windshields since all suppliers in our area had no inventory. This is our 3rd prius and we had no problems with any of them. In every other way, the 2017 is a great car however, I am wondering if the windshield is now made with thinner glass or the new aerodynamics is creating a air channel to hit the windshield.
    Does anyone else have this same problem?
    Would a bug deflector create a different aerodynamic that would alleviate this problem?
  2. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I have heard of many with cracked windshields but I have not had that issue myself at 18K so far (fingers crossed). On my last car (toyota matrix) I went thru 3 windshields, but that was with 12 years of use and 290K of miles
  3. Tideland Prius
    16,621
    Well the windshield is more upright than the last two generations.... could that be it?
    wrprice likes this.
  4. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    The new Prius is not just a redesign - but a completely new platform where re-use is minimal.
    The chassis is totally new - which means that there might be cases in which the windshield is under non predicted stresses that with a stone hit can cause quickly a crack. Moreover, I would expect an out of factory windshield replacement to be a perfectly placed as the original one.
    So only time will tell - either it is a design flaw of the chassis and the windshield mount that causes excessive stresses, or you are really unlucky with stones hitting your windshield...
    RCO likes this.
  5. Prodigyplace
    12,678
    11,830
    Central Virginia
    I mentioned in another thread that my wife had our 2017 in a hail storm near the edge of a tornado that blew the car sideways across a two lane road. She was surprised the windshield survived. When washing the car last weekend we noticed some small pits in the windshield and a few minor hail dents.
    Does the 2017 have a stronger windshield? That might explain why they were out of stock for a while.
  6. pakitt
    2,173
    1,313
    Colorado
    It might - I wouldn't be surprised if they made a new stronger but thinner design to save weight. Stronger to torsion and pressures from the chassis, not from stones chipping it...
    RCO and Prodigyplace like this.
  7. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Thank you, Skip50. I agree the car has an inferior windshield wrt cracking. Two weeks ago a rock hit mine and it shattered. I contacted Toyota, and posted on another windshield thread here at priuschat. Toyota agreed with me and helped cover the cost but I took a fair amount of ribbing here.
    Ive owned 3 prius', been driving almost forty years and never had a windshield shatter. I think the wide tires on my four tourIng are kicking rocks up over the fender onto the hood. I heard a pebble hit the windshield today. Now I'm paranoid! It's my understanding the glass is a heat reflecting thin dual pane with poly laminate between, lightweight. i would like to know the specifics. Tideland Prius can you fill us in?
  8. Prodigyplace
    12,678
    11,830
    Central Virginia
    I remember reading that the Eco had a special heat reflecting windshield. Perhaps Eco and higher have this but my Trim Two has a stronger windshield without the heat reflecting quality.
    'LectroFuel likes this.
  9. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    But what really sucks about the windshield cracking is the camera calibration. It takes a few hours for them to calibrate the camera after the windshield replacement.(n) I wish the dealer could replace the windshield and recalibrate the camera in one visit.
    RCO likes this.
  10. 'LectroFuel
    880
    673
    I was just thinking that. Do trims above the two eco have the UV resistant windshield? Maybe the 2016s had defective windshields.
  11. Montana Prius Owner
    Montana Prius Owner New Member
    Montana
    Four Touring
  12. tucatz
    501
    417
    Manzanita, Oregon
    Four Touring
  13. joey185
    joey185 Junior Member
    24
    Oregon
    Four Touring
    Mine just broke. First window I have ever broken. Toyota says it will be over a month because they are back ordered. They also mentioned the recalibration. :(
    tucatz likes this.
  14. Prodigyplace
    12,678
    11,830
    Central Virginia
    Did you trade in your 2012 PiP? You may need to update your profile.
    davebernier and bisco like this.
  15. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    About a month ago while in Texas, My 2016 Prius was hit by a rock and made a small star. Less than 1/2 inch across. By the next day, three cracks appeared and within 24 hours had spread all the way across the windshield.
    Took it to the dealer.It took a couple of weeks to get a replacement windshield in. They used safelite to install and the camera had to be reprogrammed. All toll took 2 days to complete.
    It semms like there it undue pressure on the windshield that would make it crack that way.
  16. Prodigyplace
    12,678
    11,830
    Central Virginia
    I wonder if either they improved the windshield for 2017 or the Trim Two has a less fragile design.
    I know they said the Eco had a heat blocking windshield. All the failed ones I have heard of so far appear to be 2016 Trim 3, 3T, 4, 4T. Perhaps they have this "improved" windshield material too :(
  17. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    THREE cracked windshields on a 2017 model? In only 5 months? So now BOTH the '16 AND the '17 have windshield flaws? If true, Toyota sure went cheap!
    I'm about ready to go back to driving a pickup truck!
    "We purchased a 2017 Prius 3 touring late December 2016 in the following 5 months we had 3 cracked windshields from rock chips that went immediately to a long crack."
    #17 CoastRider, Jul 12, 2017
  18. Mendel Leisk
    41,903
    There may be some service bulletin, authorizing them to do gratis replacements. Maybe they're getting a lot of this?
    I would think technically it's an insurance claim, the rock hitting the windshield, but seems like they are playing nice to placate?
  19. CoastRider
    305
    397
    This is really disappointing to keep reading about all these windshields/windscreens cracking. I mentioned this to the service advisor at the dealer, asked him if he's seen broken windshields on the 2016 Prius. "Not one", he replied. (Obviously, he doesn't read Prius Chat! :))
  20. CoastRider
    305
    397
    I don't believe it's a "design flaw" at all. The Toyota engineers are too smart for that. They've been making the Prius for 18 years??? I just think it's a simple case of going CHEAP, using thinner and lighter glass in an attempt to to cut weight any way they could, and improve mpg. Cheap glass. Thats my opinion, and I'm sticking with it! :)
    Feeling grumpy this morning... Where did I put that bottle of Jim Beam?!
