How to check fuel pressure
Discussion in 'Generation 1 Prius Discussion' started by scottauch, May 24, 2017.
  1. scottauch
    scottauch Junior Member
    Duclos, Quebec
    2001 Prius
    I
    I'm getting more or less daily 3190 insufficient power codes, where the engine stalls out, and the usual Christmas tree of lights on the dash. Is there a straightforward way to check fuel pressure? Alldata shows an adaptor needed, plus some t-fittings, etc. Does anyone have a source / part no / name for the adaptor to tap into the fuel rail? Or is there a gauge available with the correct fitting?
    Thanks,
    Scott
  2. ChapmanF
    18,516
    Even the Toyota manual itself (page SF-6) just has you go buy an extra fuel tube and cannibalize the connector off the end, and then cobble something together with this, this, this, and this.
    -Chap
    GreenTea&SaltWater likes this.
  3. scottauch
    Duclos, Quebec
    2001 Prius
    I
    Thanks. I should be able to bodge something together. The crooks at Toyota Canada want $160 plus tax for that hose.....
  4. ChapmanF
    18,516
    Yowch! The same one that's online in the US for under $60?
    -Chap
  5. scottauch
    Duclos, Quebec
    2001 Prius
    I
    Yup. Might order it from the States if I can't find a knock-off version here (which isn't looking too promising so far).
  6. Johog
    Johog Junior Member
    2001 Prius
    What about a fuel tube from a junk yard. They most likely just cut the line anyway so it could be cheap.
  7. Patrick Wong
    18,210
    6,512
    Have you tried cleaning the throttle body and throttle plate, and the mass air flow sensor. What is the condition of the iridium spark plugs?
  8. scottauch
    Duclos, Quebec
    2001 Prius
    I
    Good Idea. I'll ask around
  9. scottauch
    Duclos, Quebec
    2001 Prius
    I
    Did the throttle body clean and replaced the plugs, with no improvement. That's why I'm on to the fuel pressure. I have been getting a couple of codes about vacuum problems the last few days. Something else to hunt down....
  10. Patrick Wong
    18,210
    6,512
    I suggest you check:
    1. Air cleaner housing clamp to throttle body.
    2. Throttle body gasket to intake manifold.
    3. Loose PCV hose, engine oil cap, or dipstick.
    4. Crack in intake manifold or air cleaner housing
  11. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    There's literally not a single other post anywhere on checking fuel pressure. Isn't this as simple as removing the windshield wiper cowl and then Ying into the fuel line coming into the back of the fuel rail? Or is it so simple that nobody ever asks?
  12. ChapmanF
    18,516
    Yes, it's "exactly that simple", and you find out how simple "exactly that simple" is as soon as you go to Y into that fuel line. When you'd like to see a list of the parts to make that possible, see post #2.
    ronlewis likes this.
  13. ronlewis
    ronlewis Active Member
    1,028
    202
    texas
    2001 Prius
    dang, using a zombie thread for no reason. Make me read all that old stuff. smh
