remote windows up or down??
Discussion in 'Gen 3 Prius Technical Discussion' started by chiefs1313, Jun 13, 2010.
  1. chiefs1313
    chiefs1313 New Member
    Baltimore
    I have a 2010 prius II with the remote start, I was wondering if there is an option to program the remote to roll down the windows.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Hmm...do you really want a system that remotely starts the vehicle and rolls down the windows?
    Why don't you just call it the "Steal Me" feature.
  3. chiefs1313
    Baltimore
    no smartguy, I want the option to remotely roll down the windows. they wouldn't have the key fob, so they couldn't drive anywhere anyway.
    Stohnghost likes this.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I don't think that's available on the Prius.
    FWIW, I've owned many cars with that feature, which also opened the sunroof (and found it very useful to get the hot air out of the car before you get in), but none of them allowed you to use the remote to roll up the windows (even though that feature is available outside the US)--thank the lawyers for that. ;)
  5. chiefs1313
    Baltimore
    Thanks,
    is there a way to get that feature, independent of the remote start?
  6. stream
    2,977
    452
    Long Island, NY
    I've never heard of a way.
  7. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I am sure when a third party remote start is released that will be an option.
  8. macman408
    1,179
    367
    Just so you're aware, you don't actually need to have the fob to drive somewhere - just to turn the car on. I don't have remote start, so I don't know whether you need to do a regular start with the fob in the car - I'd assume so, though, since it's supposed to turn off after 3 minutes.
    But it's entirely possible to get in your car, start it, switch drivers at some point, drop the original driver (and key) off, and have the second driver get stuck whenever they turn the car off because they don't have the fob and can't turn the car back on.
  9. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    anyone found out if this is possible yet?
  10. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Aftermarket alarms have had this feature since the 90's. I had this feature on my 1992 Accord.
  11. MagnusAG99
    673
    521
    Norway
    some other toyotas got this feature tho, isnt it possible to maybe use another toyota that got this features relay? or some like that? if the power windows is in some sort of relay.
  12. Jeffhark1988
    Jeffhark1988 New Member
    Phoenix
    Let me chime in here there is an option and the company is California based. The software plugs into your obd port it's pretty slick
  13. MagnusAG99
    673
    521
    Norway
    really? where can people get that?
  14. FinToy
    FinToy Active Member
    145
    141
    Finland
    Just buy aftermarket alarm system and make sure the device has option to control other devices. Those "other devices" can be for example Webasto or power windows. Shouldn't be a problem for a decent installation shop to make it happen.
  15. K-Dub
    K-Dub Junior Member
    30
    Phoenix
    I bought the Carista OBD plug in hopes that it would allow window control. It doesnt. I emailed Carista and they confirmed that option is not available. At least is did get rid of the reverse gear beeping!
  16. MagnusAG99
    673
    521
    Norway
    hey dude, since u got the carista app, do u know how much the whole setup u had to buy costed?
  17. K-Dub
    K-Dub Junior Member
    30
    Phoenix
    Pretty sure it was about $40 through Amazon. There are other parameters that you can adjust with it. If you search on the web for the Carista they have a finder page that lists what options you can adjust. Worth the $40 just to make the damn backup beep stop. Now only one beep!
    MagnusAG99 likes this.
  18. orenji
    orenji Senior Member
    5,887
    3,488
    Yes there is a device that plugs into your obd2 port. It allows you to roll down and up all windows at once. I have one.
  19. MagnusAG99
    673
    521
    Norway
    the real question now is, whats it called, LOL
  20. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    For people without the remote start: The remote puts the car in ready mode (which also turns air conditioning if you have it set) but it shuts off when you open the door. Once you are in you restart the car to drive off. So, there is no possibility of driving off without the fob to restart it.
    In theory you can use it to cool the car down before getting in it but I haven't found it to be worth the bother. I won't get it on my next Prius.
