2004 Prius different codes for every MIL
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hanky_Bannister, Jun 23, 2017.
  1. Hanky_Bannister
    Hanky_Bannister New Member
    Northern California
    Hello everyone. I have a 2004 Prius with 208k miles. All services are current. However, I have a check engine light that pops on every day. When the codes are pulled it shows a different code every single time. The only code that stays the same is for the windshield wiper motor (it works fine). I'm stumped. Have any of you experienced this ? It's due for emissions testing (California) and I can't get current registration until this is sorted. Any help will be greatly appreciated.
  2. JC91006
    JC91006 Senior Member
    16,479
    8,397
    #1 check your gas cap
    #2 check the catalytic converter (most likely failure)
    #3 3 way coolant valve
    #2 JC91006, Jun 23, 2017
  3. bisco
    49,430
    is toyota reading the codes?
  4. Patrick Wong
    18,200
    6,472
    1. There is no fault code associated with the wiper motor.
    2. Exactly what DTC are being logged?
    3. What device is used to retrieve the codes?
    valde3 likes this.
  5. Hanky_Bannister
    Northern California
    Sorry it's been so long I've had an injury at work and am getting back up and around. One of the codes was an 1121 for the coolant switch ? The other was a very odd code for a windshield wiper motor and the other was a misfire on cylinder #3 but the car runs and operates perfect. The only thing I can see causing issue is a low 12v battery ?
  6. bisco
    49,430
    sorry to hear about your accident, glad you are better!
    what code reader are you using?
    easy to check the 12v. how old is it?
