Back-up Bulb Fell Into Lens
Discussion in 'Prime Main Forum (2017-2022)' started by bresna, Jun 23, 2017.
  1. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I did NOT.
    HE did.
  2. Mendel Leisk
    41,334
    Be it resolved: that the dealership is blowing smoke, regarding the collision allegation?
    For?
    Against?
    The ayes have it, unanimously.
    bisco and Prius from Dad like this.
  3. bisco
    51,845
    i assume the socket is defective, or this maybe the first ever case of a socket being damaged in an accident, without the lens cracking.
    Mendel Leisk and Prius from Dad like this.
  4. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    Why don't you get something in the and crush up the bulb then like vacuum it out?
  5. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Ok. I've got it.
    1. Pump water into the lens until the bulb floats up.
    2. "Sticky stuff" on a stick to remove the bulb.
    3. Pump the water out.
    Yes, I'm kidding.
