Fog Light Upgrade Recommendations
Discussion in 'Prius v Accessories and Modifications' started by prevee5, Nov 8, 2016.
  1. prevee5
    prevee5 Member
    121
    Monrovia, California
    As you know, the v Level 5 has fog lights as std equipment. They are halogen so the illuminated color does not match the white LED headlights.
    Is there a recommended bulb or kit available to upgrade the fogs to LED?
    Sorry if this has already been addressed. Please point me in the right direction if there's an existing thread. Thanks!
    Bmr4life likes this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Toyota: Morimoto XB LED Fogs (Oval) - Corolla Camry Highlander Tacoma LED Fog Lights from The Retrofit Source
    Less expensive option:
    High Power 15W CREE LED Projector Fog Lamps w/ DRL Lights For Toyota Lexus Scion | eBay
    Or put contrasting yellow foglight bulbs in your foglights. Yellow light gives better visibility of the road surface in rainy, foggy conditions, and IMO look great:
    These are 2500K Nokya yellow halogen bulbs in my projector foglights.
    And these are high quality projector foglights with sharp cutoffs that don't glare into other driver's eyes:
    Direct OEM Replacement Projector Fog Lamps For Toyota Scion Lexus IS GS CT LX RX | eBay
    #2 xliderider, Nov 8, 2016
  3. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    Anyone ever do this? Put LEDs in the fogs to match the factory LED headlights?
  4. Kepik
    Kepik Member
    61
    37
    Bay Area, CA
    2013 Prius v wagon
    Based on my research, because of how majority LED bulbs are designed, putting them in a fog lamp housing, isn't the best choice. LED bulbs tend to spread the beam while Halogen bulbs are more focused. I decided to go with what xliderider mentioned above, getting the Morimoto XB LEDs, which requires you to switch out the stock fog light unit and not just the bulb itself. The lumens is 5500K, so it's a nice white that should match up closely to the factory LED headlights.
