Brakes
Discussion in 'Gen 2 Prius Main Forum' started by orlandocfa, Jun 27, 2017.
  1. orlandocfa
    orlandocfa Junior Member
    San Tan Valley, Az
    I'm going to have my brakes done. I want to make sure I don't set the brake pump off. Is disconnecting the little 12 volt battery in the back enough or do I need to pull those ABS fuses from under the hood as well.
    Sean
    49,397
    the 12v is enough. who is doing them?
  3. sthomasaz
    sthomasaz Junior Member
    Scottsdale Az
    A shade tree guy that fixes my wifes truck for us.
  4. Mendel Leisk
    38,653
    Caution him to pump the brake pedal several times before reconnecting the 12 volt: you don't want the car detecting excess brake pedal at first start up.
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Make SURE he does not compress the caliper pistons without opening the bleeder screw FIRST. Forcing old brake fluid BACKWARDS thru the system is a very risky proposition that could be incredibly costly to correct.
  6. Mendel Leisk
    38,653
    Wouldn't hurt, I guess. I've never done that, never seen it recommended in shop manuals. As long you do periodic brake fluid changes shouldn't be a problem.
    m.wynn likes this.
  7. 05PreeUs
    1,097
    563
    MSP
    That statement is the qualifier!
