Toyota Prius Gen3 Problem
Discussion in 'Gen 3 Prius Main Forum' started by Comet168, Jun 27, 2017.
  1. Comet168
    Comet168 Junior Member
    Punggol
    My car is experiencing all dashboard warning light comes with beeping sound resulting in brake losing in effectiveness and needs to press really hard when I am driving.
    Go back to service centre and they say no fault in it. Anyone can advise me?
    iPhone ?
  2. ChapmanF
    18,458
    The brake computer is telling you it knows of a problem. When you read the trouble codes from that computer, they'll indicate what the problem is. You can post them here. Lots of posts already on how to read them, if you search.
    -Chap
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Welcome. There are faults, or you wouldn't have the indicator lights. Go to a shop that can read all the Prius fault codes or else get your own code reader (which is a good thing to have, generally). There are lots of threads here about Mini VCI, Carrista, and others.
  4. ChapmanF
    18,458
    Conveniently, codes from the brake computer can also be read by counting light blinks without any reader tool (but with a short piece of skinny wire). Plenty of posts to search up about that too.
    Not all computers in the car can be read that way, but the brake computer can.
    -Chap
  5. bisco
    52,286
    how many km on her? any work done recently? you might need an actuator.
  6. ChapmanF
    18,458
    I'd let him pull the codes first before starting the scary talk. Gen 2 had a pretty all-in-one actuator design, but Gen 3 has more of a separation of parts.
    -Chap
  7. Mendel Leisk
    41,826
    That can't be Toyota service department? Or can it?
  8. Comet168
    Punggol
    The mileage is around 430,000km. The warning lights automatically goes off when I switch off the engine. There is no fault code found.
    Only worried that the car will lose it brake effectiveness when I am driving in highway.
  9. bisco
    52,286
    what are you reading the codes with? you need prius aware scanner.
  10. Comet168
    Punggol
    they are using Techstream code reader to check.
    iPhone ?
  11. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Dumb question but the battery level gauge in the dash is for the traction battery not the 12V battery right? Why does the gas engine come on when the traction battery depletes? Isn't the 12V battery the one responsible for powering the AC and other accessories?
  12. jerrymildred
    11,517
    14,157
    Tampa, FL
    Yes, the battery gauge in the dash is for the traction battery.
    Basically, the ICE comes on when the traction battery depletes in order to "un-deplete" the traction battery.
    No, all the 12V battery does is power the computers and close the relays that connect the traction battery to the rest of the vehicle. (Unless you are sitting in the car in ACC mode (two presses of the power button without depressing the brake pedal) listening to the radio and running the air conditioner. You will have a dead 12V battery in just a few minutes that way.) In ready mode, the traction battery powers almost everything.
  13. Mendel Leisk
    41,826
    Think of the 12 volt battery as the "middle man": it's ultimately the source of all things 12 volt, but it's charge is almost completely dependent on the engine running, either indirectly, or more roundabout, via charging from the hybrid battery.
  14. bisco
    52,286
    as has been said above, if you got dash lights, there are codes. if they are using tech stream, a part of the puzzle is missing.
    m.wynn likes this.
  15. Mendel Leisk
    41,826
    Who is "they"? Dealership? Or?
  16. Comet168
    Punggol
    Toyota workshop
    iPhone ?
