The power plug labeled 12V 120 W
Discussion in 'Prime Main Forum (2017-2022)' started by primecandidate, Jun 29, 2017.
  1. primecandidate
    52
    36
    canton, pa
    How have you been using it?
    Is there some sort of power-strip A/C inverter that can work with it?
    Or is it specifically for DC-volt RV appliances and such?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It is accessory switched 12V 10 Amp max. for DC supply to whatever.
    priuscatprimeguy likes this.
  3. primecandidate
    52
    36
    canton, pa
    I don't know what that means.
    Does it require those cigarette-lighter connectors (from the old days)?
    Does this mean you can plug in a flood light? Video projector (draws 275 watts)? PA system? (Can you see where I'm going with this?)
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    no, I don't see where you're going with this, it says 120 watts so 275 watts would blow the fuse.:confused:
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
  6. bisco
    52,398
    if you need more power, you can run an inverter off the 12v.
  7. priuscatprimeguy
    2,730
    2,640
    and how much power can you achieve off of 12 v? @bisco?
  8. Prodigyplace
    12,682
    11,833
    Central Virginia
    I know @bwilson4web had a 1000 watt inverter in one of his Prii. I think that is the maximum he recommends.
  9. bisco
    52,398
    i think that's about right. there are several threads here with pics and great write ups.
  10. Prodigyplace
    12,682
    11,833
    Central Virginia
  11. 1x1
    1x1 Member
    147
    45
    Sorry if this has been answered already - but does this 12V 120W run from the battery under the hood (used to start the vehicle), or is it running from the EV battery? If the former, does the engine compartment battery automatically get recharged from the EV battery, should it become depleted?
  12. padroo
    padroo Senior Member
    2,763
    2,252
    You can only get 12V DC from the 12 Volt Battery, the EV battery is way to high of a voltage over 200V.
    Think of the 12 volt system as the control for the high voltage system. It runs all the traditional things as a normal car except the starter. The high voltage battery starts the car.
  13. Lee Jay
    5,850
    4,036
    The 12V battery runs the 12V system including most accessories, power plugs in the car, lights, etc. It is also necessary to start the car because it is used to start the computers. With a dead 12V battery the car won't start. The high voltage (traction) battery runs the heat pump, the two drive motor/generators AND it is used to charge the 12V system. When the car is in operating mode ("READY" mode), power from the HV battery is used to run a power supply that can supply up to (we think) 100A to charge the 12V battery. The car has no "starter", just the two drive/traction motor/generators, one of which (MG1) is used to start the ICE if necessary.
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It does while you are in READY.
    I forget if it was the PIP or the Prime where it charged while the HV Battery was charging, as well.
  15. 1x1
    1x1 Member
    147
    45
    Thanks guys.
