Maintenance cost
Discussion in 'Gen 3 Prius Main Forum' started by H.S., Jul 5, 2017.
  1. Mendel Leisk
    41,828
    Here's Honda's Shop Manual Front Disc Brake Inspection and Replacement instruction. Very specific and concise, a good reference for mechanics or DIY'rs.
    Robert Holt and Raytheeagle like this.
  2. Currahee
    Currahee Member
    103
    34
    CT
    Interesting, looks like they use the same double shim setup as Toyota.
  3. ChapmanF
    18,458
    Really, on the ears? I'm not signed into techinfo at the moment, but I have a very convincing (false??) memory that the manual did not call for any grease there whatsoever.
    -Chap
  4. Mendel Leisk
    41,828
    Here's Honda's Shop Manual instruction, for front disc
    Yeah you're right: Toyota just indicates "disk brake grease", both sides of inner shim. Guess I was thinking of Honda.
  5. Currahee
    Currahee Member
    103
    34
    CT
    They only call for lube where the pad meets the shim and between the shims. Plus the boots and pins officially get their stupid expensive lithium grease. I guess you can also clean and lube the caliper surface where it touches the shims and under the clips but not hardware itself as that will attract a lot of dirt and serve no purpose.
  6. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I'm going to switch to 5W30 as soon as I've used my last jug of 0W20. I think I still have three left.
    #66 Rebound, Jul 9, 2017
    Raytheeagle likes this.
  7. bisco
    52,292
    can't any of you cali folks find the o/p a cheap dealer in the venice area?
  8. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Ummm.... no they don't. Lithium grease is the wrong grease for the pins and boots because it is mineral oil based and will cause the rubber boots to swell, interfering with the free movement of the pins and causing the brakes to drag resulting in heat buildup, lower MPG, and increased rotor and pad wear. The boots and pins require synthetic grease.
    NutzAboutBolts likes this.
  9. Currahee
    Currahee Member
    103
    34
    CT
    It's right in the repair manual, but I would also recommend silicone grease.
  10. Tommy T.
    Tommy T. Junior Member
    Willcox, AZ
    Then go back to that dealer and demand a refund for all that unnecessary work and when they tell you "No way" tell them you are going to lodge a complaint with the Better Business Bureau. And then you will share how they have screwed you on all current social media, Facebook, YouTube, etc plus all current local media including TV, radio, news papers, and magazines. Might change their minds.
  11. Tommy T.
    Willcox, AZ
    0W20 is called for in our owners manual and it is on oil filler cap.
  12. JC91006
    JC91006 Senior Member
    16,815
    8,596
    2006 rx400h?
  13. NavyLCDR
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Just do not confuse what is in the manual with this:
    That is the WRONG grease.
  14. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I use the same dealership, but I learned long ago to just say, do the factory recommended service only. You allowed yourself to be upsold stuff you did not need. With me, they don't get away with this crap.
    Lightning Racer and CoastRider like this.
  15. Rebound
    3,996
    2,645
    Portland, OR
    We've all been taken by mechanics at one point or another. It's one reason why many of us do this work ourselves. The other reason is to ensure the work is done properly
  16. Mendel Leisk
    41,828
    Sil-Glyde Brake Lubricant is one relatively cheap, readily available (at least in North America), safe/effective caliper pin lube. And for pad to shim to caliper contact point something like Permatex Anti-Seize Compound is good.
