Some observations after doing my own oil change on the Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Pdog808, Jul 18, 2017.
  1. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    I guess I'm a bit old school about oil changes and new cars. With my previous ICE vehicles I've always tried to do an oil and filter change before 500 miles. I know that there will be a huge discussion/argument about this but it's just what I do :)
    Since the Prime is my first HV, I decided to go 3k miles before the first oil change due to all the EV miles I've put on the vehicle.
    NOTE: This was just an oil change - I didn't want to mess with the filter as it will be changed by Toyota for free at 10k miles.
    Things I noticed:
    1) The clearance under the front end of the Prime is extremely low (4 to 5 inches?). Lowest I've ever seen outside a vehicle that has had its suspension dropped. It's so low that my old vehicle ramps would not allow the Prime to go up without scraping the underside of the front bumper/air dam. I had to utilize a "dip" I have in my driveway to change the angle of one of the ramps in order to get the vehicle safely elevated about 4 inches. First thing I will do (before the two year maintenance is up) is find non-metallic, low angle vehicle ramps. Any suggestions would be great.
    2) 0W20 synthetic oil is like water! I'm used to 10W30 or 10W40 in all my previous vehicles. I mention this because since it is so thin, it splashes like a sonuvagon. When I removed the oil pan bolt, the oil draining into my oil catch basin splashed all over the place, including back up onto the underside of the Prime. I'm used to regular oil that has some viscosity and is more "splash proof". The only solution to this is to get the Prime elevated higher and use a lower catch basin so that any rebound oil won't come back up onto the vehicle underside. A plus to this is that you can pour in the oil as fast as you want. Near zero viscosity means nothing backs up into my funnel like "regular" oil does.
    As an aside here, I assume most know this but Walmart has the cheapest prices I've seen for 5 quart jugs of 0W20. About $23 for Mobil 1 Advanced Fuel Economy and about $25 for Valvoline Synpower. Free pickup at a Walmart near you OR free shipping for purchases over $35 (tax not included). I'm more of a Valvoline fan myself so will be stocking up a jug or two of this for future oil changes.
    3) I can verify that an oil change without changing the filter is about 4.0 quarts. Not that this will be done very often(?).
    4) Oil pan bolt washer - Well this is what jammed me up. As far as I could tell, there wasn't a washer on my oil pan bolt. I ended up having to bike over to the nearest auto parts store and get an oil pan bolt washer for a 2016 Prius (no washers for a 2017 Prius yet - at Pep Boys anyway). It's possible Toyota may have dropped the ball here.
    Wish List - an oil change bay like the ones they have at Valvoline and Jiffy Lube. Not that the wife would appreciate or understand an 8 foot trench in the garage :(
    Michael Wood, bps, EyePrime and 12 others like this.
    52,337
    my dad built a pit in his garage. it was his home away from home.
  3. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    Forgot to add - you can heat up the engine oil quickly by putting the Prime in park and setting it to Charge Mode (need to be less than 80% charge). Pretty sure everyone knows this though.
    Only need to run the engine a few minutes as the low (or "no") viscosity oil doesn't need to get very warm to flow freely.
    snead_c and HPrimeAdvanced like this.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Is it possible the washer was stuck on the oil pan? I've seen this before on Prius, and had to use a hammer and flat screwdriver to bust it loose. But, you would have noticed this when you replaced the bolt with the new washer, yes?
    HPrimeAdvanced and Mendel Leisk like this.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Did you have to remove any of the aerodynamic panels on the bottom? That's what I'm worried about because I hate trying to remove those little button clips that hold them up.
    I've never EVER heated up an engine for an oil change. In fact, I let them cool to avoid the possibility of getting hot oil on my hands. I just have a little patience in waiting for the oil to drain. I've also always found ramps to be way more trouble than they're worth. A floor jack and jack stands take up way less space and take no more time to use.
    I think it would be better to change the filter early and leave the oil than the other way around. What you're trying to do is account for the possibility of a higher level of particulates in a brand new engine, and that's what the filter removes until it gets full of them. A new filter will clean dirty oil.
  6. douglasjre
    douglasjre Senior Member
    2,202
    736
    Null, NL
    I found if u let it sit overnight and drain it cold u get an extra qt out. It amazes me that this much settles overnight. Is it all in the head/variable valve train? I haven't done a hot oil change since I realized this
    deadmoney33 and HPrimeAdvanced like this.
  7. Mendel Leisk
    41,850
    Would 2x10 squares (or similar) just ahead of the ramps help, not sure.
    Also, @FuelMiser probably right: the Toyo washer has some sorta coating, and it tends to glue onto the oil pan. His technique is the way to go. Back out the bolt a turn or two, then tap the washer loose with screwdriver and hammer. Then continue removing the bolt, with the washer. There's probably two washers on there now.
    HPrimeAdvanced and Mark57 like this.
  8. Washingtonian
    Washingtonian Senior Member
    726
    621
    So how clean was the oil that you drained from the car? And a question: Does anyone know if the free oil change provided by Toyota includes synthetic oil?
    HPrimeAdvanced likes this.
  9. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Yes, the Primes use synthetic oil.
  10. DavidA
    2,345
    1,821
    Chicago western burbs
    My dealer mechanic rep told me last week, when describing the free visits over the next two years, how they now only use synth 0W20 in most all the new cars past 2015. I mentioned that when the time comes (3K miles) for the first change and filter, that I would bring in my own MobilOne 0W20 5-qt jug if there was any possibility that 5W20 might find it's way into my car instead, if only by accident. He stared at me and told me that no way does that happen anymore (implying it had). I really hope he was right.
    HPrimeAdvanced and CoastRider like this.
  11. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I'm sceptical that the dealer uses the oil that I supply to them rather than using the vat oil that's readily available.
  12. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    From what I've read here and experienced, oil changes for the Prime are every 10k miles. There have been a few that have had it done at 5k. There has been a lot of debate on when to do oil changes if you use mostly EV.
  13. Mendel Leisk
    41,850
    I buy bulk Toyota 0W20 synth. Guess it comes from a "vat". Never any problems, very clean, basically the same stuff you can get bottled.
    Ed the fox may be along shortly, to explain otherwise.
    m.wynn and bisco like this.
  14. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    I've wondered about that. I don't have any proof, of course. For many years I always supplied my own store-bought oil. Now I've decided to just let the dealer put in whatever they use. You gotta hope they know it requires 0W-20... ! I'll tell the service writer to specify that on the paperwork.
  15. DavidA
    2,345
    1,821
    Oh, I know. Just want to get the "metal shavings and gunk" out of the filter on a new engine. Following that, it will be every 10K. Just an old school thing to do with every new car. Might not be needed early like that, but since they're changing it for free and giving me oil and a filter, I figure why not? Can't hurt and just might help.
  16. Mark57
    2,945
    2,740
    OK
    Agree with @Mendel Leisk above.
    I'd bet you could get a couple of short scrap 2x8 blocks and cut them into a "pre-ramp" cheat to get the front end coming up sooner. You might need to make them up to 12" long to get it moving up sooner so as not to contact your current ramps. I've been using the plastic Davric Magnum 16000 ramps on my 2010 Prius with good clearance. Can't test on my ordered 2017 until it arrives. I also use them with my 4Runner and our low Camry hybrid. Nice no skid ramps. They are 36" long and the incline bevel is 22" of the 36".
    I just found a video that shows the concept I'm referring to but he does it differently than I would, but you get the idea.
    #16 Mark57, Jul 19, 2017
    Tips, benagi, KrPtNk and 3 others like this.
  17. Trollbait
    12,662
    The measured viscosity of 0w20 oil, even hot, is far from that of water.;)
    As to cold vs hot changes, I preferred doing hot on the belief that the particles haven't had time to settle onto the bottom of the pan and stay there during the drain.
  18. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I like it. Perhaps I just found a secondary income via Etsy and/or Priuschat Shop.
    Mark57 likes this.
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    BTW, when shopping for oil, you might try your Toyota dealer. Mine charged $3.95 per quart. They didn't have the 5 quart jugs, but I was happy to get 5 quarts of Toyota 0W20 for $20. Filter was cheaper than Amazon, too.
  20. CoastRider
    305
    397
    That's a great price. I just returned from the nearest dealer parts dept, and their price is $7.19 per Qt! (0W-20) They don't sell the big jugs, or the "bulk" oil that Mendel buys.
    I'm curious, I wonder who makes the "Toyota brand oil" in the mystery black bottle...? And what brand of oil is in the big "vats" that the service mechanics draw from? One dealer told me that they just order bulk oil from the lowest bidder each month. He didn't know what company supplies it. Whatever it is, I'm sure it's Ok.
    (Walmart has the best price on Mobil 1, jug or individual bottles. It's cheaper than the $7.19 the parts dept is asking for that "mystery oil.")
    #20 CoastRider, Jul 19, 2017
    Merkey, snead_c and jerrymildred like this.
