"An unexpected database error occurred. Please try again later."
Discussion in 'PriusChat Website Questions' started by davidtm, Apr 27, 2017.
  1. davidtm
    davidtm Member
    180
    TJ'ville
    This has been happening lately. Any ideas?
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Ideas ?
    Yes, a search should turn up a LOT of them.
    Alas, the owner seems unable or unwilling to fix the problem.
    It goes in streaks, probably depending on the server load at the time.
    Just live with it; it's been going on for a L O N G time.
    davidtm likes this.
  3. bisco
    52,849
    yep, i'm getting them again as well. patience is the watchword.:cool:
  4. Sam Spade
    2,036
    1,024
    2017 Prius c
    Also should have stated more clearly:
    Just try again, whatever you were doing.
    Often it will work a few seconds later.
    If it fails several times in a row, just come back later.
    RCO likes this.
  5. davidtm
    davidtm Member
    180
    TJ'ville
    Thanks, all!
    SM-T530NU ?
  6. 4md
    4md Member
    97
    55
    Sofia, BG
    I also experience this cut-outs, they're almost permanent between 8:00 to 16:00 UTC. When trying to refresh the forum in this time period and the error is not displayed, sometimes the CSS is not loaded.
    RCO and Mendel Leisk like this.
  7. bisco
    52,849
    can it be fixed remotely? don't we have any hackers here?
    Kevin_Denver likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Yeah, it happens to me.
    But when I see "Try Again Later" I mentally substitute "Get A Life Loser" and take it as motivation to get up and do something different.
    So I've found it helpful.
  9. 4md
    4md Member
    97
    55
    Sofia, BG
    :ROFLMAO::ROFLMAO::ROFLMAO:
    #9 4md, Jul 20, 2017
    RCO likes this.
  10. bisco
    52,849
    did all the graphics change?
  11. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Ok, so it's not my computer. I have been having the same problem lately.
    "An unexpected database error occurred. Please try again later." error message appears constantly freezing the screen. Refreshing the page several times usually fix the problem, but it is very annoying. :(
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I did some reading. Seems to be a common issue with XenForo. Could be an issue with InnoDB. Could be simply a hard drive partition is full on the server. Could be a shared hosting problem and it needs to be moved to VPS hosting. Can't tell without CPanel access.
