EV & ECO indicator lights
Discussion in 'Gen 3 Prius Technical Discussion' started by solana35, Jul 11, 2017.
  1. solana35
    solana35 Junior Member
    New York, USA
    2015 Prius Two:
    I am clear that if I want a boost when passing someone I can press the PWR Mode button, and the green Power Mode Indicator lights up on the Instrument Panel to signal the car is in that mode.
    I am also clear that if I want to drive exclusively on the battery, say, in parking lots, I can press the EV Mode button and the green EV Drive Mode indicator on the Instrument Panel and the EV indicator on the Hybrid System Indicator both light up.
    But why is the EV indicator on the Hybrid System Indicator sometimes already lit up, even if I'm going over 25 mph? What is the difference between the EV indicator on the Hybrid System Indicator being lit up alone and its being lit up at the same time as the green EV Drive Mode indicator on the Instrument Panel?
    Also, when I would press the ECO mode button? The ECO Driving Indicator Light is on pretty much all the time on the Hybrid System Indicator. What would it mean if the green ECO Mode indicator on the Instrument Panel were lit up at the same time as the ECO Driving Indicator Light on the Hybrid System Indicator?
    Finally, I'm very confused about the terminology. It looks like the buttons we press on the Instrument Panel are called:
    -EV Drive Mode Indicator
    -ECO Mode indicator
    -Power Mode indicator
    It would be easier if they called these EV Mode Button, ECO Mode Button, and Power Mode Button.
    The lights on the Hybrid System Indicator are called:
    -EV Indicator
    -ECO Driving Indicator Light
    It would be easier if they called these EV Indicator and ECO Indicator.
    Does my confusion about the terminology reveal that I'm not understanding something about how this function works?
    Thank you!
  2. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    First: you don't get an extra boost (as in: more power) with PWR mode. It only changes throttle response. That's also why you would use ECO, pressing the throttle to the same depth in ECO mode will produce less acceleration than in PWR mode. But full throttle in both modes is the same.
    With the "EV indicator on the Hybrid System Indicator", do you mean the ECO indicator as in the attached picture? That lights up when the HSI bar is below half of the indicator (the darker green part) and indicates you are driving more economical than when you are using the right half of the indicator.
    As for your confusion: I call the buttons buttons, not indicators. In my manual they are called like "Button PWR MODE" (translated). And are you really confused by something being called "ECO Driving Indicator Light" as opposed to "ECO Indicator"?
  3. b100
    b100 Member
    139
    72
    Netherlands
    If it shows EV in your HSI that means that you are in EV mode, so your engine is shut then.
  4. Zulat
    Zulat New Member
    Portland Oregon
    Did they answer your question Solana?
    solana35 likes this.
  5. solana35
    New York, USA
    Thank you for following up, Zulat. No, they didn't.
    I've been trying to get clearer on what, exactly my question is. I'm not entirely sure how to frame it, and I think there may be multiple questions. Maybe I'll start with this:
    If the ECO Driving Indicator Light (the leaf-shaped light) is on on the HSI, when/why would I want to press the ECO Mode indicator button?
  6. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    First, remove "ECO Mode indicator button" from your vocabulary. The button is a button; it indicates nothing. The indicator is on the instrument display. Two totally separate (but related) objects. Like a switch and a light.
    Second, you press the eco button to put the car in ECO mode. This remaps the throttle response from the normal linear response to one that is more gentle at low throttle and then ramps up more steeply as you press closer to full throttle. Power mode does the opposite. Also, ECO mode modifies the air conditioning to use less power.
    The indicator light near your speedometer indicates the mode you have selected with the button. If you're in ECO mode, it says so. If you're in PWR mode, it says so. And if you're in normal mode, it says nothing.
    The indicator over on the hsi, shown by @Maarten28, shows if the car is running in an economical fashion. Is the engine in its most efficient rpm range, engine vacuum in a good range, and so on? It has to do with how you use your right foot, not what buttons you push with your fingers. It's the indicator that will help you maximize fuel economy. The one by the speedometer just reminds you which throttle response map you have selected.
    Hope this is clear enough.
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The HSI indicates what mode the car is in. The car will always choose what mode it thinks it is best to be in. You can override or tell the car what mode you prefer to be in by pressing the buttons.
    For example, if you prefer to use EV, it will stay in electric mode. If you exceed the speed or push on the accelerator for EV, the car will go out of EV mode. You can drive EV mode in ECO and PWR mode as well. The difference in those two modes is, that the car is more willing to leave EV mode.
    Why would you want to press the ECO button? That's telling the car you prefer to be in ECO mode at all times. The car will oblige when it can. The HSI will tell you when it succeeds.
  8. jerrymildred
    11,491
    14,100
    Tampa, FL
    Why would you not want to press the ECO button? You still have all the acceleration you would have in Normal or Power; it's just easier to keep a steady throttle opening over rough roads. Floor it and the response is the same either way.
    As for EV vs HV mode, the only reason I ever wanted EV in my pre-PiP days was just to move it a short distance without the engine starting. Otherwise, I let the computer do its job. In fact, I installed a button for that very purpose.) Overriding the computer almost always gives worse mileage. There is energy lost to heat in using the battery and again in recharging it, so it's best to not run it down unnecessarily.
    From the PiP owner's manual. I imagine the regular hatchback is pretty similar.
  9. solana35
    New York, USA
    Thank you for the very clear explanation in your last 3 paragraphs, jerrymildred. Very much appreciated!
    About this paragraph, I agree completely:
    The OM is confusing and inconsistent. A switch/button is a switch/button and a light/indicator is a light/indicator! They call everything an indicator. And the words "drive" and "driving" should be omitted altogether.
    jerrymildred likes this.
  10. solana35
    New York, USA
    Thank you so much, mmmodem. This is really helpful and clear.
    I've been experimenting, in an effort to figure it out myself, and came to a tentative conclusion that, while the HSI indicator shows that I'm driving in ECO mode most of the time, my pressing the ECO button seems to be one more gradation of economical/ecological (whichever ECO stands for). Your descriptions of my "overriding" and the car "obliging when it can" align with what I've noticed when experimenting, so that's good!
    I had been entertaining the idea that they provide the buttons to give people with busy minds (like me) something to do ;)
    #10 solana35, Jul 24, 2017
    mmmodem likes this.
  11. solana35
    New York, USA
    Interesting, jerrymildred.
    I experimented this past week as I tried to answer my own question and I don't know if it's my imagination or if it's really a thing, but when I push the ECO button, the car does seem to have less power on hills than when I don't. Even slight inclines.
    Conversely, when I push the Power button, the car seems to have more power going up hills than without any buttons depressed. I understood from the first person who responded to this thread that my thinking was wrong about the Power button providing more power. But it does say in the OM that that's why we'd engage the Power button. So that discrepancy about the Power button is the only remaining piece of confusion I have.
    I do get about a half mile more per gallon if I drive it around having deliberately put it in ECO mode (from 52.7 to 53.2 MPG on avg.), so however it works, I'm going to leave ECO mode engaged at all times except when I specifically want it in EV or Power modes.
  12. FuelMiser
    FuelMiser Senior Member
    1,270
    861
    Monument, CO
    In the Gen 4, there are the same three modes (Eco, Normal, Pwr), but the consensus is the engineers made the "feel" of Normal mode of Gen 4 equivalent to the feel of the Gen 3 in Power mode. Having both cars, I can say the Gen 4 is definitely "peppier" off the line with the same throttle input, and I understand its basically the mapping of the accelerator pedal. It boils down to personal preference, what you get used to and what you want the car to feel like. There is no right or wrong answer as to when to use the Mode buttons.
  13. jerrymildred
    11,491
    14,100
    Tampa, FL
    Check the picture on post #7 on this thread:
    EV-ECO-PWR and NONE ? | PriusChat
    Note that at zero accelerator position (foot off the gas), the throttle is closed in all modes. At maximum accelerator position (floored), the throttle is wide open in all modes. The differences are at partial accelerator positions.
    This gives the perception of quicker throttle response in PWR mode at the expense of less fine control of the throttle opening at lower pedal pressures and more sluggish response in ECO. But in any mode, WOT demands all the power the car has.
    The Gen 4 may have totally different throttle maps, but it also has more actual horse power to work with, just as Gen 3 has more than Gen 2.
    More info in this thread:
    Gen3 Power Mode | PriusChat
    Edit to add: By all means, continue to experiment. It's fun and helps you get a feel for the car. Just don't cone to any conclusions too quickly. There are so many variables that it's easy to think that condition A led to result B not knowing that condition X was there and had more influence.
    #13 jerrymildred, Jul 24, 2017
  14. solana35
    New York, USA
    Thanks, FuelMiser!
  15. solana35
    New York, USA
    Thanks for that really helpful chart, jerrymildred, and the link to the other thread. They both clarify a lot for me, and make sense. I'm glad to know there are reasons for what I'm feeling with my right foot :)
    That's a really good point about delaying conclusions!
  16. solana35
    New York, USA
    I live on a steep and curvy road, and my house is about 2/10 of a mile up the hill. I'm a little worried about making it up the hill in snow, especially since I have owned Subarus for the past 25 years. I had been thinking I'd need to put it in PWR mode before I hit the hill so I can get up enough speed to keep going. I'm thinking more power sooner would be good. Would you agree? (I also plan on getting snow tires, which I never did with the Subarus).
  17. jerrymildred
    11,491
    14,100
    Tampa, FL
    I don't think it will matter much. If anything, ECO should be better because it's easier to modulate the throttle more precisely. Remember, the electric part of you power train has 100% torque at zero rpm. Either way, the traction control will keep you from spinning the tires. As long as the snow isn't too deep to plow through, I hear the Prius does great. I even saw video of one guy who had to turn around and get his Jeep because the snow was so deep that it slid up over the Prius' windshield and blocked his view. Traction was not a problem. But the snow tires are a good idea.
  18. mmmodem
    2,732
    1,703
    Bay Area, CA
    I found the Prius above average for driving in snow versus other FWD vehicles I've owned. I agree with Jerry that PWR mode won't make much of a difference and ECO might be better for control.
    solana35 and jerrymildred like this.
  19. Maarten28
    414
    224
    Netherlands
    PWR mode does nothing to give you more power. It only changes the throttle response: in ECO you have to depress the throttle deeper to get the same response than in PWR. This image explains it a bit:
  20. solana35
    New York, USA
    That's good to hear, jerrymildred and mmmodem. Thanks!
