Trying to get back into the Prius Family
Discussion in 'Gen 2 Prius Main Forum' started by AVOID92X, Jul 27, 2017.
  1. AVOID92X
    AVOID92X Junior Member
    24
    We bought an 08 new and drove the heck out of it before we got rid of it after 5 years.
    Now I'm shopping for a used Gen 2 on the cheap. I was thinking of something in the 150-175k mileage range, but after reading the 200k posts, it looks like 2/3 of the batteries were replaced shortly before 200k. Starting to think that may not be a wise move
    Anyone able to provide some advise/ recommendations on what to look for when checking out Gen 2s?
  2. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    The most important factor for high mileage cars is the maintenance and repairs that were done on them. If you find a car that's regularly been maintained, it's likely to last a lot longer than one that hasn't.
    A few problems to look for: repeated headlight changes in repair history, low oil level, battery level graphic moving quickly between empty and full and back again, flickering of either the digital instrument display or the multi-function display, clogged battery fan, low voltage on 12v battery, sticky melted plastic on either the dashboard or the rear hatch handle, as well as basic things like rust
    AVOID92X and srellim234 like this.
  3. MilkyWay
    MilkyWay Active Member
    823
    359
    MI
    Depends what your long-term goals are....If you buy one with 175K miles you should hope to go 2 years and dump it....or just in the back of your mind hope to get 2 maintenance-free years out of it....But, if you are expecting it to go to 270K miles and last 10 years without problems...and you get mad when in 2 years something happens...then it won't be for you....All about how realistic your expectations are!
    I bought a 2007 with 201,000 miles (now approaching 205,000 miles) and all I had to do was put a 12V battery in it. Love the thing and has zero issues but I can just tell reselling it will be tough...I got it at the dealers auction and they seem to obsess over these things...they usually start at $1000 and then the dealers bid them way up. It ended up going for around $2600 but it needed a $200 12V battery....So I have about $3000 into it and I feel like it would be hard just to get a little under $3000 back....I usually keep my cars for a little less than 1 year and then upgrade to a better car or lower mileage car but if I can't get close to $3000 then I'll just keep it!
    Also, we must be reading different places on the 200K mile club because everytime I see a person post they not only say they are on original hybrid battery --- they usually say they are on original 12V and brakes as well. I rarely read about the hybrid battery going bad on this forum.
  4. AVOID92X
    24
    I'm really looking at your first option ... about 2 years and maybe 30k.
    I have a deposit on the new Tesla, and I'm going to ride out my wait in the Prius.
    Prices on these things are all over the place. I see some in the $3k range, plenty in the $4k range. I guess it will depend on my level of "risk" :D
    @ MovingRightAlong
    Good info on the battery rapidly charging/ discharging.
    Any way to easily check the 12v battery voltage?
  5. Mendel Leisk
    42,364
    Bring along a digital multimeter. For a more in-depth assessment, Solar BA5 is good, entry-level battery tester. The multimeter you can connect at the under-hood jump point, for convenience. The Solar you want to directly to the battery posts.
  6. rjparker
    11,125
    6,980
    Check Craigslist and find a one owner gen 2 with 125k or less for maybe $5k.
  7. rjparker
    11,125
    6,980
    By the way replacing the HV battery is somewhat equivalent, pricewise to a transmission on most cars because of the cottage industry reconditioning or selling new for $1,000 to $2,500. Then resale becomes much easier for a high mileage model, or better yet, drive it for another 5 years. Those prices are maybe one to five car payments. The Houston company in this link will meet a customer almost anywhere in Texas and will swap it in one hour. Pricing | Hometown Hybrids
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    :confused: Time to do some more reading. For example, the battery repair thread is now 4 years old and nearly 100 pages/2,000 posts long.
    Time can be more of a factor than miles. In fact, low mileage cars can see earlier failures. If you're looking at 05-06's, it's almost a guarantee you'll need one or its already be addressed with usually a rebuilt.
  9. Moving Right Along
    739
    596
    In the 200,000 & 299,999 mile threads, approximately 15% of respondents said they had replaced their traction batteries, if I remember correctly (I went through each one and compared to total respondents a month or two ago). So that's roughly a 1 in 7 chance the average Prius will need a traction battery replacement in 200,000 miles
    MilkyWay likes this.
  10. fotomoto
    5,639
    3,815
    So. Texas
    Ahh, but look at the times of those postings. That thread is 8 years old. Not suggesting you do the leg work but one would need to find all those cars today (many have been sold long ago) to see the original batteries are still holding up. Most of those owners were highway bandits racking up incredible miles very quickly and are no longer active members here.
  11. AVOID92X
    24
    Plenty of good points here. THanks all!
    About to go look at a pretty loaded 05 with 85k. Asking $5k. Will not pay that much, but will check it out
  12. Moving Right Along
    739
    596
    I've compared all data I could find on Prius battery failures from here, Consumer Reports, and user data from True Delta. Battery failure rates as an overall tendency seem to be at or around zero for roughly the first 10 years and/or 100,000 miles, and then increase to between 3-15%, with higher rates for 1st gen vehicles and higher failure rates here compared to True Delta statistics.
    It's definitely an area where the people and companies that know most of the information (Toyota, their dealerships, and independent hybrid specialty shops) don't share that information with the general public and as a result, there is inherently going to be some guesswork involved. But with that said, I've gathered as much public-available information as I could find, and 3-15% battery failure rates for older or higher-mileage Prii seems to be an appropriate range based on everything I've seen.
    I can also say that to the best of my knowledge the statistics I found represent failures of original traction batteries and not remanufactured replacements, which anecdotally from threads around this forum seem to fail at substantially higher rates and quite a bit faster.
    Overall, I think Toyota is predominantly justified in saying the traction battery lasts "for the life of the vehicle," but they did not count on so many people wanting to keep their Prius longer than the average amount of time and number of miles.
    MilkyWay, AVOID92X and fotomoto like this.
  13. AVOID92X
    24
    Very good stuff here, thanks ...
    What are you considering as "higher mileage" for the 3-15%? Regardless, that sounds like good odds :)
  14. Moving Right Along
    739
    596
    Since Prius batteries very rarely fail before 10 years or 100,000 miles, "older or higher mileage" in this case means more than 10 years and/or more than 100,000 miles. I graphed out battery failures from True Delta data a few months ago. The top graph shows number of failed batteries on the left axis and mileage (x10,000) on the bottom axis. And the bottom chart shows failure rate percentage on the left axis and model year (+2000) on the bottom axis.
    dolj, MilkyWay and AVOID92X like this.
  15. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Sitting parked and idle is the killer of batteries, heat shortens their life as well, but you have a better chance with a higher mileage "daily driver" than a low mileage garage queen - really!
    A really good Gen2 will run you $4k-$6k around here, that will be primo condition, leather, no HIDs and Touring with a supreme history. May have up to 200k on it as well. You can get "decent" cars with a clean history that were daily drivers for a family, but are not "clean" as in detailed or shiny, for like $2k. We did the ~$2k option and are prepared to fix or replace the pack if necessary. These truly are GREAT cars.
    Data Daedalus and MilkyWay like this.
  16. AVOID92X
    24
    Thanks.
    The 2005 I checked out was a bust. Based on checking out the '05, I realized I need an '06+ for the backup camera and better display.
    Still on the hunt
  17. swamprt5000
    swamprt5000 Junior Member
    Reno, NV
    $2k? Jesus. I need to get out to Texas. It's a struggle in northern California...
  18. 05PreeUs
    1,097
    565
    MSP
    Motivated sellers + minor defects + trained technician = Good $$
