Do windows and/or windshield have UVA and UVB protection?
Discussion in 'Gen 4 Prius Main Forum' started by Chippingawayatlife, Aug 1, 2017.
  1. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    I heard that regular glass protects against UVB pretty well. What about UVA? Any known percentages and sources?
  2. Elektroingenieur
    2,515
    3,284
    Three Touring
    Toyota’s New Car Features book (NM3200U, available by subscription to techinfo.toyota.com) says some of the glass is of a “UV Cut” type:
    • Front Fix Window Glass
    • Front Door Glass Sub-assembly
    • Rear Door Glass Sub-assembly
    • Rear Quarter Window Glass
    • Back Door Glass
    The “UV Cut” designation, which is not explained further, is not shown for the Windshield Glass, Sliding Roof Glass (if present), or Back Window Glass.
    I couldn’t find any other discussion of UV transmission in Toyota’s publications for the fourth-generation Prius. If you need more information, I’d suggest contacting Toyota through their website or by letter to ask.
    Chippingawayatlife likes this.
  3. Chippingawayatlife
    159
    116
    San jose
    Thanks! I submitted an email
  4. bisco
    51,948
    i'll be interested to read their response.
    pilotgrrl likes this.
  5. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    I'd be interested in their response to why so many Gen 4 and Prime windshields keep cracking.:eek:
    I doubt there's much UVA/UVB protection in the factory glass. I went and added my own. :)
  6. Chippingawayatlife
    159
    116
    San jose
    Those look pretty dark. Are they 20 or 30% all around? It seems so expensive to tint in the bay area, California. If they don't offer protection, I'm planning on tinting only the rear side windows for the expected baby:).
    And of course I'll report back if/when I hear from Toyota.
  7. bisco
    51,948
    don't tell me that, i thought there were federal requirements for windshields.
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Do some Internet searching.
    Plain window glass passes almost NO UVB or UVC.
    My 30 second search found that the blocking of UVA isn't as good.......but that A isn't as big a problem either.
    I'm pretty sure that spending more than 30 seconds on a search will give you the answer you need.
  9. davids45
    davids45 Active Member
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day,
    I'd agree with Sam S.'s post.
    Window glass generally has a significant iron content (the ferric ion is the UV absorber giving glass a yellowish tint because it absorbs blue as well as UV, the ferrous ion is more of a near IR absorber giving a blue tint because of its red light absorbance - together they combine to give commercial glass a greenish hue - if there is nothing else added by the glassmaker to decolourise the glass). In a thick section (edge-on), window glass looks green.
    So the short wavelength UV (C and B) won't get through at the thickness of most windows, so no sun-tan inside the car :( .
    From memory, UV-A is less of a biological problem and would still be absorbed to some extent by the thickness of car window glass, certainly more than with no glass in the way. Again, inside the car is not a place to get a sun-tan :( . Eye damage is maybe a slight risk with life-time prolonged exposure to UV-A but a negligible one compared to simply being outside in summer with no sun-glasses. Drive with polarised UV-rated sunglasses - no UV of any wavelength and no glare from reflections off the road or dash.
    I don't know if you can find transmission spectra for window glass on any window-glass manufacturers' sites (try Pilkington?). Such spectra would show how much UV and even blue light is absorbed by the glass - thickness is an important variable in this, of course. Window glass is usually about 3mm thick.
    David S.
  10. Chippingawayatlife
    159
    116
    San jose
    From listening to a podcast, they were saying that UVA was basically for aging and UVB was for burning. This isn't exactly what it means, but it is a way for me to remember. UVA had something to do with collagen damaging, which probably sounds worse than it actually is. You also bring up a good point about sunglasses. I will have to get a pair for my wife, who wears glasses. Actually, I just realized how bad that sounded because it won't work. :( Also, I had no idea that thickness of the glass had to do with how much you've he gets in the car. That's good to know
    RCO likes this.
  11. Chippingawayatlife
    159
    116
    San jose
    Toyota's response for the 2016 Prius in US. It doesn't seem like they show much pertaining UV other than "UV cut", which I don't understand.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I could be mistaken, but think that means 'cut out' rather than 'cut down,' but you're right. It is, unlike the glass, not perfectly clear.
    Chippingawayatlife and bisco like this.
  13. davids45
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day,
    I agree with RCO that it was intended to read 'cut out' or 'cut off' - maybe an expression 'lost' in the translation.
    The values in the table make sense given they're for 'laymen' not nit-picking glass technologists or physicists.
    The transmission (the light that gets to you into the cabin) is what's left after about 10% is reflected back at the air/glass interfaces and what's absorbed in the the glass, and to a minor extent absorbed by the very thin polymer film between the two glass sheets of the laminated windscreen.
    The side and rear windows are just mono-layers of glass. These windows should be of tempered glass, heat treated to shatter into little bits if broken, not sharp slivers like normal domestic window glass. The stress 'islands' or zones produced by tempering often show as greyish patches up if you're wearing polaroid-type sunglasses and looking through them, say, in your rear-view mirror.
    David S.
    RCO and Chippingawayatlife like this.
  14. bisco
    51,948
    a bit of googling shows 99% cut, cuts out 99% of uv rays. but nothing scientific, and toyota doesn't give a percentage in that chart.
    priusrust, RCO and Chippingawayatlife like this.
  15. Tideland Prius
    16,559
    Here's the 2010 Prius for reference. There was more details back then but if you wanted rough numbers (cause I'm sure it's different for the Gen 4), here they are
    quantumy, bisco, RCO and 1 other person like this.
  16. Chippingawayatlife
    159
    116
    San jose
    Wow. There's so much more detail in the 2010. I wonder if much would have changed. The UV cut rates are at about 90%+, does that mean it's enough to not need worrying about?
    RCO likes this.
  17. Sam Spade
    2,036
    1,023
    2017 Prius c
    Yes. But "worry thresholds" are a very personal thing.
    Continue to worry if you wish. :)
    A.Liece and RCO like this.
  18. bisco
    51,948
    check with your dermatologist.
    quantumy and RCO like this.
  19. Tideland Prius
    16,559
    ^ what those two said. I'm not a dermatologist so I can't comment on that lol. Or perhaps a paediatrician
  20. quantumy
    quantumy Member
    55
    37
    So helpful!!! I wonder what "UV" means, UV-A or UV-B, or...?
    What's interesting is this study from 2016 that looked at 29 cars from 15 manufacturers of varying ages, price range, car types, etc. and they reported the actual %UV-A reduction. 2014 Prius measured 96% UV-A blockage of front windshield and 79% UV-A blockage of front side windows... much less than the specified 100% / 91%. Guess I'm getting my windows tinted!
    full article here
    Moronical and Smaug1 like this.
