Transmission repair costs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by findlj, Aug 12, 2006.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    No way you can get a NEW tranny installed at dealer for $2k. They usually charge $4500-$6000 installed. I think slapointe was able to get the dealer to install a used tranny. Not all dealers offer used parts and/or customer supplied parts installation. YMMV.
    52,187
    i didn't realize they would do that at all.
  3. jdenenberg
    jdenenberg EE Professor
    3,947
    1,943
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My CT dealer installed a ReInVolt (now Dorman) for me.
    JeffD
  4. bisco
    52,187
    interesting, and good info for anyone facing an expensive repair. might pay to shop dealers.
  5. jdenenberg
    3,947
    1,943
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Having a long-term relationship with the service advisor and service manager makes bending the rules achievable.
    JeffD
    frodoz737 likes this.
  6. bisco
    52,187
    agreed. too bad most dealers make that impossible.
  7. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I have never seen a dealer install used parts, no one would buy new from their parts department ........but anything is possible I guess
  8. jdenenberg
    3,947
    1,943
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My CT dealer installed a rebuilt HV battery in my 2004 Prius about 3 years ago as discussed above.
    JeffD
    #28 jdenenberg, Sep 12, 2016
  9. johnjohnchu
    johnjohnchu Active Member
    212
    104
    According to a private transmission repair shop that I normally deal with, Prius' transmission is much simpler to repair than a normal transmission.
  10. jdenenberg
    3,947
    1,943
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Careful, the MGs are part of the Transmission in a Prius and the few failures that have occurred were shorted turns in the MGs. There are many salvaged Prii transmissions available at reasonable cost, so that is you best solution if you have tranny problems.
    JeffD
  11. FET
    FET New Member
    Siskiyou county
    Our 'transaxle' is out dead gone at 125k miles we are they only owners. Have been quoted the high $5k price to replace it. Know what the car at best is worth only $6,500-7,000. It uses a quart of synthetic oil between oil changes has done so since January this year. I guess we could part it out and try and sell the battery pack yes? Lithia Toyota Medford trade-in guy said he'd give us $100.00 for the car! This experience has left me without a car. The Prius has not been mistreated. It didn't get the tran fluid change --should have came with a warning label....
  12. bisco
    52,187
    sorry to hear it, this is extremely unusual. changing the oil most likely wouldn't have helped.
    why not shop around for a used tranny?
    also, it might be worth calling toyota and asking for goodwill discount.
    johnjohnchu and Mendel Leisk like this.
  13. Beachbummm
    1,160
    392
    call these people.. ask about a used tranny Luscious Garage | Hybrid Specialists
    just sell it on craigs list as is for $1800 if you don't want to invest the money, people will want the air bags, battery and cat converters but little else. and they don't want to pay for them, best to sell it as a whole unit
  14. Aristides Restituyo Jr
    Sorry Richard but, they do. My buddy just had his replaced in Virginia Beach. It first started making grinding noises, as it had dried out ball bearings; then the car would not go past 30 mph and then froze.
    He bought a used one from eBay and had some backyard Mechanic replace it for under $700. Total cost, including shipping and R/R @$1200.00
  15. dolj
    dolj Senior Member
    8,490
    4,308
    Wellington, New Zealand
    When Richard posted that back in 2006, that probably was the case. Not surprising that, 11 years later, things are changing.
    Even so, transaxle failures are still very infrequent.
  16. jdenenberg
    3,947
    1,943
    Trumbull, CT
    2020 Prius
    LE AWD-e
    And even less frequent for Prii that have had periodic ATF drain/refill maintenance. I have still never heard of a Prius transaxle failure when the ATF was kept clean.
    JeffD
  17. Mendel Leisk
    41,747
    Strange, strange, strange, that Toyota is so adamant in their stance, on transaxle fluid changes not being needed. A reversal would be a concession, "loss of face"? (n)
    Or maybe "loss of $'s"?
  18. HybridGuy04
    HybridGuy04 New Member
    This happened to me too just recently. 2004 Prius.
    nancytheprius likes this.
