Beep to Find your Car in Parking Lot?
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Sep 27, 2017.
  1. stevepea
    stevepea Senior Member
    535
    581
    Unless I'm missing something(?), it seems the Prime doesn't have an option on the remote control key for your car to beep/honk so you know where it is in case you forgot where you parked it in a large parking lot. There's the "panic" button for when someone is trying to steal your car according to the manual, which I assume makes a super-loud crazy sound (I haven't tried it), but is there anything just to have your car honk briefly to help you find it without scaring everyone in the parking lot? On the Honda Civics, if you press the "LOCK" button a couple times while it's already locked, it would honk the horn just a bit so you could easily find your car.
    Anything like this for the Prime? Or is your only choice the "panic" button?
  2. fuzzy1
    10,479
    Does it beep again when you hit Lock, even when the car was previously locked?
    On my older generation Prius, the limitation is the radio range of the fob, not the audio range of the beep.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    When I unlock my 2012 v it beeps twice and flashes the parking lights, when I lock it back it beeps once and flashes the parking lights. I can do this over and over finding my car. The panic button honks the horn and flashes lights until you find your fob and turn it off. (I have never deliberately used the panic feature)
    "Operation signals
    Doors:
    A buzzer sounds and the emergency flashers flash to indicate that the doors have been locked/unlocked. (Locked: Once; Unlocked: Twice)"
    https://www.toyota.com/t3Portal/document/om-s/OM47A88U/pdf/OM47A88U.pdf Page 268
    "Panic mode
    When [speaker] is pressed for longer than about one second, an alarm will sound intermittently and the vehicle lights will
    flash to deter any person from trying to break into or damage your vehicle.
    To stop the alarm, press any button on the electronic key."
    Page 263
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I've only used the "panic' button once when I saw a group of interested observers closely examining my registration plates on my 2009 Gen II just after I changed to the "vanity plates" now on the car. It was in broad daylight, and I was glad to discover that they were merely curious about the meaning of the word (they were obviously not from the south west UK! :rolleyes:)
  5. krushmoto
    krushmoto Member
    65
    44
    US
    On my Hyundai if you got the panic fit a quick second it would honk and flash lights a few times. To activate the panic you would hold the button. Haven't tried on my Prime but I thought it would be similar.
    Nexus 6P ?
  6. krushmoto
    krushmoto Member
    65
    44
    US
    Damn spell correct
    Nexus 6P ?
  7. Trollbait
    12,543
    I think most cars do this, but might be something you or the dealer has to set on or off.
  8. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    For my Citroen I just double click the lock button after it already locked. It doesn’t make a sound but the lights go mental for 10 seconds or so.
    iPhone ?
    HPrimeAdvanced likes this.
  9. bisco
    51,994
    toyota doesn't honk. just a quiet beep and lights flash. i think you can hit the panic button for a quick horn, then hit it again to stop it. give it a try and let me know.
    stevepea likes this.
  10. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    Apple Maps on the iPhone will pinpoint your car's location if it was linked to the car via bluetooth...
  11. stevepea
    535
    581
    Next time if I can't find my car in a giant lot, I will indeed try the Panic button and see how it works... Hopefully it can be switched off quickly.
  12. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    I just use bread crumbs.
  13. What if the gulls eat 'em? :)
  14. huskers
    2,544
    2,487
    Nebraska
    Then I wander around like a lost child.
  15. Trollbait
    12,543
    Until the wolves arrive.
    In central NJ, the parking lots that get sea gulls hanging out were once wetlands.
  16. huskers
    2,544
    2,487
    Nebraska
    It is a dog (wolf) eat dog (wolf) world out there.
  17. stevepea
    535
    581
    Used the red panic button for the first time the other day just to try it out. I remembered where my car was, but it was a giant parking lot with no one really around, so I thought I'd give it a try. It is loud, but not "call the war department" loud. Which means it's a viable option if you park and don't remember where it is (though I wouldn't do it more than you have to, for it still is annoying). Only thing is, I didn't test the range (how far away it might work with a new fob) because I knew where the car was and was relatively close.
    Well, it works (at least not too far away) if you need to find your car in a sea of cars... though that would be one idea for a later model to improve upon (allow it to honk slightly like the Hondas do)...
  18. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Or shoot up a flare
    huskers likes this.
