Just changed brakes, now they are sticking. HELP!!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by laser411, Sep 25, 2017.
  1. laser411
    laser411 Junior Member
    35
    NC USA
    Yeah, side shims are there and I cleaned and lubed them.
    So, I just went out and jacked the car up. Wheels can be hand turned but definitely give resistance. Pads are glazed but rubber parts are fine (thank god). Disconnected the battery and put a clamp on the caliper with pads in place and on the rotor still. The piston retracted with very little effort, just like when I did the pad change, clearly not seized as I might have actually been able to retract them by hand if I had tried. Slide pins, while I have not yet re-lubricated them, glide very smoothly. I just don't get it, could it be that when I had the abs lights on and had no power assist and had to stomp on the brakes to stop that it learned this new starting position when I cleared the codes? 20171001_141831.jpg 20171001_141845.jpg
  2. laser411
    35
    NC USA
    So here are my observations.
    -The piston retracts easily with a clamp
    -While the piston is extended and putting pressure on the brakes, when I open the brake bleeder, it just drips.
    -Also while piston extended and bleeder open, when I put pressure on the clamp, brake fluid squirts.
    -Whenever I hit the brakes and it clamps back down on the pads/rotor, it does not retract as it should
    So, I didn't think this piece of information was pertinent but I am starting to think it may be. When I was changing the brakes and had the caliper on the right side (this did not happen to the left side) flipped up, I Pressed the brakes by accident and extended the piston. It did not pop out and did not seem like it was extended fully (but it could have been). Thinking nothing of it, I just pushed it back in. Could this be cause by air in the lines? Maybe the piston did come out far enough for air to be introduced. Btw bled some of the fluid out into a container and it seems very clean.
    Now I am really hoping I can get TS working properly. Anyone else have thoughts as to why it won't connect to all of those systems? Anyone know of a known good VCI cable?
  3. ChapmanF
    19,019
    I was kind of hoping for a particular observation that might be harder to make if too many things are checked in combination. I'd have wanted to know: if one wheel is jacked up, and no one is applying brakes, and it's hard to turn, and the bleeder for that caliper is then opened, is the wheel still equally hard to turn?
    What are you using for your standard of "as it should"? On my Gen 1, a 'good' return seemed to be about 0.3 mm. Possible to see with the naked eye if testing the caliper on a well-lit bench with nothing else moving, but tough to judge without a dial indicator.
    Using 'hit the brakes' as a way to test the piston return ends up not working too well, because the braking forces are strong enough that the elasticity of aluminum and steel are in play; the caliper and bracket stretch by several times the piston return amount that's of interest, and then spring back. I found the piston return to be most easily tested on the bench using short puffs of compressed air. I think this could be done on the car (secure an upward-running clear hose on the bleeder, open the bleeder and let some fluid partly fill the hose, then apply puffs of compressed air at the end of the hose, counting on the fluid in the hose to carry the force without letting the air in the system). But I've never had a chance to test that, so for now it's just an idea I think would work. The key is to use the minimum force it takes to nudge the piston out to just kiss the surface of whatever you're using to block it, but not stretch or deform it, and measure how far it retracts from there.
    -Chap
  4. Mendel Leisk
    42,343
    A feeler gauge might help, checking that the piston retracts slightly.
  5. laser411
    35
    NC USA
    I do not have someone to help me with that unfortunately, but the piston is not retracting at all it seems. When I manually retract the piston, everything turns easily. If I hit the brake once, it will extend and seemingly not retract. Without the wheels on the car, I cannot turn it by hand. Opening the bleeder during this does not release the pressure on the rotor, but it does not seem like a lot of pressure, just enough to create more friction than desired.
  6. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Those pads got HOT, see the bluing?!!!!????!?!?!
    Assemble the calipers WITHOUT the pads and see if they slide smoothly in-out. If so, the caliper pistons are not retracting (based on your other observations, which were very good), the most likely cause is hardened piston seals or debris behind them.
  7. ChapmanF
    19,019
    All of the piston-return checking I've ever done, I've done in blessed solitude. What way would you check it where another person's help would be needed?
    Do you know whether the calipers are original? Have you changed either one at any point in this thread? (Apologies if you've already said, I haven't re-read the whole thread just now.)
    If they are original, and have not been through the mill of a cheap 3rd-party remanufacturer, it might be worth changing out the rubber kit and then measuring the piston return again to see if they have come back to life.
    Here are a couple of pictures of measuring piston return:
    A dial indicator from Harbor Freight, eBay, etc. is cheap, and the only other prop is some block or blocks of hard stuff (I used a couple nylon blocks I had around, but it doesn't matter) about as thick as the rotors with pads, with a hole drilled through for the dial indicator stem to rest on the piston.
    The trick is not to apply a lot of force during the test (a brake caliper makes it easy to apply a lot of force!). The point is not to test how much the blocks will squish or the caliper will stretch, but only to gently extend the piston to where it lightly taps the blocks, then note how far it relaxes. A gentle puff of air into the caliper from a bike pump is easily enough.
    A couple years ago, a poster discovered his phenolic pistons had swollen (rebuilding the caliper, after getting them out, they wouldn't go back in). That doesn't seem to be your issue, as you make it sound as if they move easily, but another thing to watch for. Pistons aren't included in the rubber kit, might add another $16 or so if needed, if I remember right.
    The big auto stores sell complete 3rd-party remanufactured calipers, but the last one of those I tried had zero piston return right out of the box. :mad:
    -Chap
    Edit: the pictures above show the magnetic dial indicator base stuck right to the caliper, which was easy for Gen 1 because those calipers are cast iron. Naturally, it won't stick like that to an aluminum Gen 2 caliper, so a little more setup would be needed.
  8. laser411
    35
    NC USA
    The caliper slides fine, and yeah, the pads got hot because they were sticking and I drove like 40 miles with them putting pressure on the rotors. again, I need to reiterate that these brakes were 100% working as intended right up until I swapped out the pads. Now, both sides (driver and passenger) are sticking. rubber seals aren't hardened (still very rubbery), slide pins in great condition and lubed now, piston has no deformities or rust, piston retracts easily using a c-clamp with very little effort. The breaks were not sticking or acting weird at all before the brake job.
    Not sure how I will pull that setup off if it's not metallic but I will see what I can pull off. They are the original calipers and this is the first brake replacement this car has had and it's at 120k. I only changed them because the tire place said they were getting thin, and they were. Otherwise I had no indication they were wearing thin as my brakes were working flawlessly which is why I feel strongly that something went wrong when I did the brakes. Not to mention the same issue happening on both sides. Is it possible that enough air got into the line that would cause the piston to still be able to extend but not retract? What about the valves? is there a way that they could let pressure onto the brakes but not release them, basically acting like one way valves?
    Btw, got TS working, was indeed a bad cable. although I still can't to active tests as it errors out, but at.east I can connect to the abs system. is there anything I can use to help diagnose in there?
  9. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    I am of the belief, not powering down the system correctly and bleeding the system is the cause of your misery.
    Air might have been introduced
    How did you bleed the front calipers? The Prius requires Techstream and a specific sequence.
    How much did you bleed? The systems has ~1 gal of brake fluid (per Galaxee).
    New pads are 10mm to wear indicator. Minimum required thickness is 1mm to wear indicator.
    So how much material was left?
    Lets say 3mm to wear indicator. 10mm - 3mm = 7mm of pad material used over 120K miles.
    120,000miles/7mm ≈ 17,143miles per mm of pad material used.
    2 mm more to go = 17,143miles/mm x 2mm ≈ 34,286miles left in the pads.​
    Yes, you screwed the pooch.
    Yes.
    STOP applying pre-ABS and ABS brake bleeding procedure to the Prius. The Prius is a different beast.
    Look at the braking diagram, by expanding the image. Do you see how many valves there are? Valves that are computer controlled. You have already pissed the system off bleeding it incorrectly, and it has not forgiven you. To properly bleed the brakes, you need Techstream, and you need to follow the service manual procedure on bleeding. Acquire a working miniVCI cable and get a temporary subscription to Toyota TIS, the OFFICIAL service manual. $15 for a 2 day subscription.
    Toyota - New Subscription
  10. 05PreeUs
    1,097
    565
    MSP
    Umm, unless you disassembled the calipers, you have not inspected the caliper piston seals. What is shown in your photos are the piston DUST BOOTS and their only job in life is to keep the road grime out of the caliper bore and off the external piston surfaces.
  11. laser411
    35
    NC USA
    When I originally changed the pads, I did not bleed them, I just pressed the piston back in. I did not power down the system though. If that is the cause of my misery, how can I fix it? I have TS working now
    The passenger side was just at the wear indicator and the driver side had a little to go before the wear indicator. I'm very easy on the brakes and regen brake whenever I can. When I was checking out what might be holding the piston extended, I cracked the bleeder valve with a hose connected (filled with brake fluid) to see if it was under pressure and it wasn't. So you think bleeding it with TS will fix my problem?
    Did not know that was just the dust guard. What are the chances those seals give up on both sides at the same time and after I changed the brakes?
    Thank you all for your input and help thus far. I've learned a lot of things I did not know about the brakes on our prius's. I don't have the money to spend at the stealership, so this is extremely helpful. I just wish I had read up before doing this, I just had no clue that the process was different :-/. Lesson learned.
  12. 05PreeUs
    1,097
    565
    MSP
    Chances are high, but not 100%.
    The "school of hard knocks" offers a superior educational experience, she is also VERY costly. Knowledge costs a LOT, wisdom even more ;)
  13. exstudent
    2,214
    905
    Torrance, CA
    The factory service manual lists specific steps to, power down the system, before working on the brakes. Are you sure you have the Toyota service manual?
    As you now know, you can NOT do that on a Prius. The factory service manual lists specific steps to bleed each wheel. Techstream is REQUIRED, because the software tells the Prius brakes to open close the appropriate valves, for a bleed procedure, at a specified wheel.
    Again, are you sure you have the factory service manual? The procedure is clearly listed. If your service manual is not from Toyota, or second best from Helms, donate your Chilton/Haynes to your local library, along with your OBD2 reader.
    Yes, that is my belief.
    Dot 3 brake fluid is cheap. Remember, Galaxee (former member and Toyota Master Mechanic), says the system has ~1 gallon of fluid. WrongMart (WalMart) has Dot3 brakefluid for $4.93/quart (4 quarts = 1 gallon) or $14.67/gallon. Dispose of the old brake fluid responsibly.
    The Toyota service manual also recommends connecting a charger to the 12V battery if working on the car ACC or IG-ON for prolonged periods. Best to use a smart charger that has an AGM setting (4.2Amp max charge rate).
    #53 exstudent, Oct 3, 2017
  14. Mendel Leisk
    42,343
    With third gen, there is a specific procedure in the Repair Manual, for bleeding the brakes without Techstream. It requires the car to be "on" but not "ready" (ie: push start button twice without foot on brake). You then do a chicken dance, which puts the car in "invalid mode", and can bleed away. Not sure if there's something similar in second gen, don't have documents on that.
    One gotcha: wherever they say "select Neutral" in the chicken dance, you need to depress brake pedal first, in order to do that.
  15. laser411
    35
    NC USA
    I don't have any service manual, and as for the bleeding, I was doing what post #2 was asking for diagnostic. I had a hose filled with brake fluid as to not introduce air. This was just to see if pressure was causing the piston to stay extended (which it wasn't).
    Is there a service manual hosted somewhere? I am running low on funds and my car above and beyond the brakes, also needs a 12v battery :/ . It's amazing how our car uses the hybrid battery to supplement the 12v system and start the engine. Been running 2 cells down for a while now. Our batteries are expensive.
  16. ChapmanF
    19,019
    There's a test I sometimes do for brake drag, drive for 15 minutes or so on a clear road (no traffic or need to use brakes), turn off into a big empty parking lot (without using the brakes) and come to a stop without using the brakes (just B mode, then R at the last moment, then stab the brake just at the speed=0 moment, no rotor heating).
    I can vouch that on good, flawless Prius brakes, you can feel the rotors at that point and they'll be stone cold. (Even using the brakes a little to stop at the end of the test will invalidate it by making them noticeably warm.)
    I only mention that because, if that isn't a test you had run before you did the brakes, you might not know for sure they were flawless. We know they weren't dragging anything like they were after your work, but perhaps they had already begun to just a bit, and would not have felt completely cold after such a test.
    Reasonable to wonder about, but I don't think it's so uncommon as to rule anything out.
    I'm not sure I remember reading anything you did that would have allowed air in to begin with. I do think it is possible that an air bubble could result in residual pressure at the piston. But you should notice that when cracking the bleeder (either a pressurized air bubble poots out, or a little fluid geyser). It sounds like you've now done that, and did not observe that result. So I don't know how much money I'd put on air being the problem.
    It's not even necessary for them to act like one way valves. Depending on which valves, one simply sticking open would have that effect, because there is a pumped-up accumulator of 2000 psi brake fluid on the other side. That's exactly the worry at the center of the never-force-grotty-old-fluid-backwards-through-ABS school of thought: a little particle of grot getting stuck in a valve, holding it slightly open.
    But, presumably, you'd have noticed that too, when you tried the crack-the-bleeder test (in fact, that's what I intended to be finding out, when I suggested that test). Had a valve been open with the accumulator on the other side, you might even have seen, not a quick geyser of fluid, but a sustained one. Sounds like that isn't what you saw.
    There is another phenomenon (not one I've seen myself, but have seen reported) where the rubber portions of brake lines can begin to delaminate on the inside, forming a sort of internal rubber flap. Forcing fluid backward when pressing in the piston can fold the flap, and make a sort of pressure-retaining valve out of it. Sounds like a freak, almost incredible occurrence, but not hard to find reports of on the internets.
    At this point, I don't think simple loss of piston-seal return performance has been ruled out yet. My approach would be to stay calm and not get too caught up in worries about more complicated and expensive things, before following up that possibility.
    I'm with 05 here; the "piston seals" we're talking about are concealed inside the caliper bores, where you don't see them without taking the pistons out. (This, of course, is a procedure that definitely calls for bleeding afterward.)
    Not sure I'm on board with that. :) It may be possible to confuse the Prius computers, but they aren't spiteful things you can piss off and that hold grudges. Also, if you confuse them, generally you can retrieve codes that will tell you what they are confused about. They don't sit there nursing their grudges in secret and plotting against you. And from the brake computer, you can read codes either with Techstream or without, using a simple jumper wire and counting light blinks. You've got Techstream and finally made it connect; did it show any brake codes?
    Stepping further back, I'm not so much on board with the fingerpointing; I don't think any of us knows enough yet about your problem to be saying "oh, yes, X is what's happening, and it's because of Y stupid thing you did." We can all do that later, after finding out why it is that your brakes drag. ;)
    I would concur with exstudent that $15 at techinfo is a small sum of money very well spent, and a lot of great information is there at your fingertips. I would just say it that way, with less of the suggestion that you're being punished for your sins of not reading it.
    Tough to say, but it wouldn't shock me. Again, they might have been marginal already (as you probably didn't do a cold-rotors-after-15-min-drive test just before doing the work, we just don't know). Also, for the last n thousand miles, the seals have been riding on about the same little area of the pistons, but when you press the pistons in, (a) you sort of flex the seals backward in their grooves, and (b) they end up resting against a different region of the piston that they haven't touched since the car's earliest days. If that makes them lose their piston-retracting spirit, so be it ... the rubber kit's only about $21, one kit does both sides.
    It's true that many recommend an occasional complete change of the brake fluid—for a view that treats it as less urgent, see hobbit's brake fluid writeup (a bit more than halfway down that page). But a full change is a different operation from bleeding to get rid of some incidental peripheral air bubble. Maybe you'll feel like doing a full change someday down the road, but right now you're probably more interested in just having brakes that don't drag.
    For the record, I think it's Galaxee's DH who's the Toyota Master Mechanic, but I do miss her great, informatively-written summaries of his master mechanicky exploits.
    Caution here ... I tried that mode in my third gen, and I think I'll never do it again. I think there are two ways to get into something called "ECB invalid" mode: one without Techstream (as in the excerpt Mendel posted), and one if you do have Techstream (you can just tell it, hey, go into ECB invalid mode). I think the time I tried it, I just used Techstream, and perhaps that has a slightly different effect. Anyway, if you go into invalid mode the way I did, it sets a code C1451, on purpose. This code will drive you crazy, because it is nonvolatile (unhooking the battery will not clear it, and nor will the jumper/brake pedal dance that clears other brake codes), and the fortune that goes with it ("Motor Drive Permission Malfunction") tells you flat-out nothing, and only one procedure executed in Techstream will get rid of it, as far as I know. It's the closest thing I've seen to a disproof of my claim that the Prius computers aren't spiteful. :)
    But maybe that's only a third-gen thing, and maybe getting into the mode with the pedal dance instead of Techstream doesn't set the same code, anyway.
    -Chap
    #56 ChapmanF, Oct 3, 2017
  17. Mendel Leisk
    42,343
    I used a couple of pints when I changed brake fluid on our 3rd gen, pretty sure I changed it all. OTOH: I couldn't find a stat as to how much fluid there actually is in the system.
  18. exstudent
    2,214
    905
    Torrance, CA
    You can try the Italians. Download at your own risk.
    Documentazione Tecnica - Technical Documentation | Hybrid Synergy Forum
    $15 is a small price to pay to get authentic materials from the source, malware free. Unfortunately today, Toyota no longer makes the download available as PDF. You have to convert CHM files into PDF files. This person figured out a way to do that.
    Toyota TIS download tips | PriusChat
    Huh?
    The HV Battery seems to last 8-10years. Few get less than 8 years. Most get 8-10. Lucky ones get 10+ years. A new HV Battery may cost $2210 from a Toyota dealer who sells online, if they are willing to sell to you. 2007 Toyota Prius Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
    $2210/10years = $221/year = $4.25/week = $0.61/day
    You may hopefully come to see that $2210 is not so expensive when you amortize the cost over the usual life span (assuming 10 years).
  19. exstudent
    2,214
    905
    Torrance, CA
    Recall the sequence of events.
    Prior to changing front pads, brakes were operating correctly. Once front brakes were replaced, misery ensued.
    Cause/Effect
    Cause
    • Did not follow manufactures procedure on changing the front brakes.
    • Bleed brakes w/o Techstream; it is possible to do w/o Techstream, but a sane person would not attempt that misery.
    • Post #42, depressed brake pedal, causing right front caliper piston to extend (possibly enough to allow air to enter).
    • Unable to read codes that were initially present due to incompatible OBD2 reader.
    • Drove vehicle with front brakes engaged, superheating the font pads. If front caliper seals turn out to be bad, this might be the root cause. Remember, prior to front pad change, brakes operated correctly and the seals were likely intact and operational.
    Effect
    • OP (Original Poster) is likely miserable right now. (opinion)
    • OP does not have a safe car to drive. (fact)
    OP can make the decision to try a complete brake system flush, ~$15 for 1 gallon of Dot3 or goto caliper piston seals (sold as caliper overhaul kit, $30.22/ea; qty 2 needed due to right and left sides), and 2 quarts of Dot3 ($4.93/quart) for front Left and Right. 2007 Toyota Prius Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
  20. laser411
    35
    NC USA
    I'm going to do the full flush this weekend. I'm going to try that first as I'm very nervous about pulling the piston completely out. I have never done a caliper rebuild so it's out of my comfort zone. Then again, once this went awry I was out of my comfort zone. How does the dust boot come off and then how do I get the piston out?
