Behold! I tell you of a mystery…
Discussion in 'Gen 2 Prius Technical Discussion' started by WilDavis, Oct 11, 2017.
  1. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …not quite on the biblical scale normally associated with that introduction, but still mighty strange to me. This afternoon I decided to experiment with my SKS fobs to see how effective their operating range is, and one of the experiments was to place the fob in a static-bag, and check to see if the car and fob could see each other (well, according to what I've read here-abouts the fob should be screened, right?) WRONG!!! I tried putting the fob in one, then two, then three anti-static bags (see picture), and the communication wasn't compromised in the slightest! :eek: o_O :confused::confused::confused:
    What gives? Anyone understand why I'm confuserated, and prepared to help out this ignoramus? Thanks in advance!!! :)
    Sod it! The stoopid system won't let me upload a file! @Danny, what the hell is going on????
    51,791
    maybe the system is in an anti static bag.:p
    Slider2732 and WilDavis like this.
  3. ChapmanF
    18,006
    Maybe the answer will have something to do with anti-static bags being made slightly conductive (enough to drain off large static charges that could zap electronics that you store inside them), but not really conductive enough to qualify as Faraday cages. You might repeat the experiment with your fob wrapped in aluminium foil, or in a metal cookie tin with a tight-fitting cover, and report if those results are different.
    -Chap
  4. WilDavis
    2,493
    2,155
    49
    Ah, you mean just like the foil I wrap my hat in? …good idea! o_O:eek::rolleyes:
  5. WilDavis
    2,493
    2,155
    49
    Thanks, Chap! Nice one! I dug out an old baccy tin, and just tried it, and it worked like a charm!
    (…still can't upload files though! :confused::confused:o_O)
    (…tries again!)
    Hallelujah! It works! :D
    #5 WilDavis, Oct 11, 2017
    Raytheeagle likes this.
  6. ChapmanF
    18,006
    Solved in a moment, in the twinkling of an eye ....
    WilDavis likes this.
  7. WilDavis
    2,493
    2,155
    49
    …well, I think I must have been changed! (…well, there's a lot of it about, y'know! ;) )
  8. ChapmanF
    18,006
    I think you're putting me on.
  9. WilDavis
    2,493
    2,155
    49
  10. Mendel Leisk
    41,234
    Static bags just protect against static, don't shield radio transmissions? I do know carefully wrapping my fob in a double layer of aluminum foil did the trick.
    (@Danny no longer auto-completes as you type it, btw. Which I think equals Danny has left the building?)
  11. WilDavis
    2,493
    2,155
    49
    …carefully wrapped in aluminium foil, no doubt! :cautious:o_O:rolleyes:;)
  12. RRxing
    RRxing Senior Member
    2,542
    1,817
    NEPA
    Tin foil or an EZ-Pass RF shielded bag will work.
    Somewhat off topic - I like the feature (on both my 2017 Prius and 2016 RAV4 (non-hybrid)) where you can conserve your fob battery by turning off the transmitter. Hold down the Lock button and press the Unlock button twice on the fob - the LED flashes twice, then twice again. If you try to open the car door now it won't work. A nice feature.
    Oh - how to turn the transmitter back on? Just one press on the fob's Lock or Unlock button does it.
  13. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    That would be really handy as mine sits in the drawer 350 days of the year.
  14. RRxing
    2,542
    1,817
    NEPA
    That's what I do with my spare...
  15. WilDavis
    2,493
    2,155
    49
    …well, just for shyts n' grins I tried it using the EZ-Pass RF shielded baggy which my replacement transponder arrived in, but unfortunately it had no discernible effect.
    Here's how I tested it:
    1) I left the unshielded FOB inside the car (on the driver's seat) and tried to lock the door (using the button on the driver's arm rest). The locks would operate, but when I closed the door, the doors would unlock)
    2) I tried (1) but with the FOB inside the EZ-Pass RF shielded baggy - The locks would operate, but when I closed the door, the doors would unlock!
    3) I tried (1) but with the FOB inside the baccy-tin (see threads passim^^^^^^^^) - The locks would operate and stay locked when I closed the door.
    Hooray for Balkan Sobranie! :)
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    It was recently revealed to me that my understanding of the communication between the Fob and the vehicle was fundamentally flawed.
    So I hesitate to comment. But really fear of being wrong, has never stopped me before.....
    All I can say, is years ago I experimented with the foil wrapped fob and the fob in a metal Altoids tin, and I could never get it to NOT communicate.
    It always seemed to work.
    Just for kicks, I keep my back-up fob wrapped in aluminum foil and stored in an altoids tin, but last time I experimented with it? It didn't really help.
  17. RRxing
    2,542
    1,817
    NEPA
    I was planning on testing it some day :rolleyes:, but now that I can just turn the transponder off (see #12)...
    Thanks for putting another urban legend to bed...
