Dreaded tire pressure light.
Discussion in 'Gen 2 Prius Main Forum' started by Fredsimm, Oct 21, 2017.
  1. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    I've searched, but still not sure. My tire light flashes for a minute or so and then stays on. Checked the tires, one low about 5 lbs. Reset the system with the button under the steering wheel. Drove 50 miles and still on. Any ideas or experiences. Some searches say sensor. I did hit a bump in a construction area. Maybe overpressure from shock?
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    You need to check the tires and add air where needed. That is what the TPMS light is telling you. After that the light may take a couple of minutes to turn off.
  3. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    TPMS sensor batteries are starting to fail. BTDT They're good for about 10 years give or take.
    Mendel Leisk and Prodigyplace like this.
  4. Prodigyplace
    11,696
    11,317
    Central Virginia
    Possible too. Since they mentioned a tire was low but did not say they added air, I thought that bore mentioning too.
  5. Mendel Leisk
    38,253
    Depending on what State you're in, you may or may not need to pass an annual inspection where a tpms light will mean a fail. That's one hurdle. The second: I believe in the States all tire shops are under the gun to install tires with functioning tpms?
  6. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    There is a TPMS reset button under the steering wheel? :coffee:
    Coopers ST likes this.
  7. Prodigyplace
    11,696
    11,317
    Central Virginia
    There is usually some way to set the TPMS when you are sure all tire pressures are correct. It is not a reset button.
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    When you say one was low 5 psi, based on what, the door sticker? If so, that makes sense because most Toyota models hold to a 15% pressure loss to set the TPMS light and it just so happens that 5 psi is almost exactly a 15% loss on 33/35psi > the pressure Toyota specs for these cars.
    Now, if you have modern higher pressure LRR tires, 28 odd psi is a WAY UNSAFELY LOW pressure. The "rule of thumb" in the tire industry (tire manufacturers that is) is that no tire should ever be inflated to LESS than 75% of the sidewall "MAX COLD", but in certain cases with lightly loaded tires pressure lower than that can be approved by the tire manufacturer, especially if speeds are low.
  9. Fredsimm
    188
    117
    Tupelo MS
    Where are the batteries?
  10. Mendel Leisk
    38,253
    Permanently installed in the sensors, ie: not replaceable. :mad:
  11. Fredsimm
    188
    117
    Tupelo MS
    Yeah, I've been searching. The units are around $150 for the set and must be programmed to the vehicle. That sucks.
  12. ChapmanF
    15,110
    Registering the sensors is easy if you've got access to Techstream. But yeah, you do have to buy them....
    -Chap
  13. Fredsimm
    188
    117
    Tupelo MS
    Is techstream a program easily accessible to the general public?
  14. Kevin_Denver
    Kevin_Denver Active Member
    581
    421
    Denver, CO
    Search the Prius Chat forums and internet for how to use a mini VCI cable, techstream, etc. You'll find the answers.
  15. Fredsimm
    188
    117
    Tupelo MS
    Thanks
  16. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    You can see this for DIY assist
    TPMS Management with Techstream | PriusChat
    Sounds like one TPMS went bad...I lost one so far at 165k miles (the dead one lasted 9.5 years at 150k)...cheapest quote I got from my tire place was $30 to replace if I supply the TPMS and program. I know from Techstream where the bad one is.
  17. gta_
    gta_ Active Member
    189
    133
    Tracy, CA
    I agree with everyone else, TPMS battery went bad. Check your local mom & pop tire shops, they can replace and reprogram them. I had to do one on mine the day I bought it and it was cheaper than $150 (not sure what prices are like in your area). Even if you get tech stream, you still have to get the sensor installed inside the tires. My local shop price included the part, install and reprogram.
  18. Kevin_Denver
    581
    421
    Denver, CO
    Cheapest option with the TPMS is to just keep driving, checking your tire pressures regularly until your current set of tires wear out. Then buy and bring a new set of TPMS sensors with you when you get the tires replaced and most tire shops will install them for free with your new tires. I probably wouldn't replace just a single sensor unless I needed to, to pass an inspection.
    gta_ and Prodigyplace like this.
  19. Mark57
    2,945
    2,735
    OK
  20. Fredsimm
    188
    117
    Tupelo MS
    Sounds like the most logical solution.
