Prius 4th Gen Heater
Discussion in 'Gen 4 Prius Main Forum' started by Denis Wiseman, Oct 29, 2017.
Tags:
  1. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    You can actually configure whether AC is switched on and off automatically by Auto in the head unit or with Techstream, FWIW.
    Mendel Leisk and RCO like this.
  2. Mendel Leisk
    41,811
    That's good to know. Too bad it's not user configurable though. I suppose it's a "volatile" setting, ie: a battery disconnect would wipe it? I'm up on memory savers, but perdiodically want a truly comatose car, say for DIY brake work.
    RCO likes this.
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    My Canadian 3rd gen will turn on the A/C light every time I select "Auto". It may or may not run the compressor. It will run it if I'm asking for cooling (set temp is lower than ambient by more than about 2 deg C). It will run the compressor as well when defrost is selected (it talks about this in the owners manual). It will not run the compressor if the set temp is more than 2 deg C higher than ambient. The two degree part is discussed in the owners manual, basically saying the operation is erratic when ambient is within 2 degrees of the set temp. Erratic as in not fully predictable whether you will get heating or cooling.
    Remember, "Air Conditioning" is NOT "cooling", it's heating -AND- cooling -AND- filtering in Prius speak.
    The part that often catches me is if I select "Front Defrost" I can't cancel it by turning the system "OFF". I have to actually press the "Front Defrost" button again to turn it off.
    I suspect the gen IV is similar. It's a Toyota thing. ;)
    RCO likes this.
  4. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    "In the head unit" means it is user configurable through vehicle setup.
  5. Tideland Prius
    16,597
    The Gen 2 will turn on A/C if you hit AUTO
    The Gen 3 doesn't (but according to @David Beale , the Gen 3.5 does?)
    I can't remember what happens on the Gen 4. The manual appears to make it seem like the default setting is off.
  6. Prodigyplace
    12,625
    11,807
    Central Virginia
    The defaults for those are just the opposite on my 2017 Trim Two. It is interesting that the owner can change the outside air setting but not the AC one. Column 3 means TechStream.
    Tideland Prius likes this.
  7. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    I'm 99% sure that thing is wrong, too - I want to say that mine defaulted to that (but maybe I changed it with Techstream), and that I could change it through the head unit. I'll have to check...
  8. Tideland Prius
    16,597
    So the A/C light comes on (if it's off) when you press AUTO in the Gen 4 as the default setting?
    RCO likes this.
  9. Prodigyplace
    12,625
    11,807
    Central Virginia
    Correct. I am not sure I have ever used the AC button.
    Tideland Prius and RCO like this.
  10. Mendel Leisk
    41,811
    Maybe from 2012 model year onwards? Again, my 2010 does not do this.
  11. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Yes.
    Tideland Prius, RCO and Mendel Leisk like this.
  12. Mendel Leisk
    41,811
    So, contrary to the Owner's Manual, it is owner settable? Excellent. (y)
  13. RonMc5
    RonMc5 Member
    89
    73
    Santee
    I think there are actually 2 answers here, depending on whether you have a Prius or a Prius Prime. I believe the regular G4 Prius works pretty much as it has since at least G2. In the Prime however and since it works for extended periods (25 miles or so in NORMAL weather) it operates the Air Conditioner (Heat Pump) pretty much backwards. Picture you AC in when it is cooling the car. Low pressure coolant goes into the heat exchanger core inside the car and absorbs heat, it is pumped back out and the pumping further heats the coolant it then goes to another heat exchanger outside the car (usually in front of the engine's and/or inverter's radiators*) and heats up the outside air and cooling it back off. On the way back in it goes through a valve to reduce it's pressure making it ready once again to absorb heat from inside the car. All of that is like almost everyone else's AC works. (Most are driven by belts from the engine). In the Prime (and perhaps regular Prii) it is driven by an electric pump. Now what happens if you reverse this procedure? You heat the inside of the car and cool off the outside air. Now IF the engine is running, it will use the hot engine coolant to heat the car just like everyone is used to.
    *I peeked under the hood, but without removing some decorative (top) and aero covers (bottom) I can't EZly determine what's what. I believe I did locate the electric heat pump behind the right bumper and under the right fender.
    A "bit" more complex than that in your average car. :) This is just a schematic view. Alas I was unable to find an "in place" component view. I do have some pictures of the car with the front bumper (yes, all three parts) off. I will see if I find one or more that illuminate the situation.
  14. RonMc5
    RonMc5 Member
    89
    73
    Santee
    At the center of the pic below you can see a hose coming out of what I believe to be the electric AC pump. I don't know what all the bits are, but you can also see a hose going into what I believe to be the radiator in front of the other two to cool the hot refrigerant that returned from inside the car.
    #34 RonMc5, Nov 3, 2017
  15. Tideland Prius
    16,597
    Thanks.
    Yeah possibly. Can confirm. My 2010 acts like @Mendel Leisk 's
  16. RonMc5
    RonMc5 Member
    89
    73
    Santee
    The pic below is just a little further toward the center of the car from the previous pic.
  17. David Beale
    5,963
    1,989
    Edmonton Alberta
    The hot refrigerant comes from the pump - compress it to liquid, cool it, let it expand in the "other" rad. in the cabin, absorbing heat.
    You would probably be correct in "heat pump" operation though.
    RCO likes this.
  18. artie
    artie Member
    232
    65
    san diego
    get in the car, turn on the car, wait a few minutes or less, than manually turn the fan all the way up...heats and cools like a real car.
  19. Prodigyplace
    12,625
    11,807
    Central Virginia
    My car is real but a hybrid. I believe Prime and some other models have a heat pump so there is heat independent of coolant temperature.
    I know my air conditioning can cool even in EV mode so my Hybrid is superior to a gas powered car.
    #39 Prodigyplace, Nov 6, 2017
    RCO likes this.
  20. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    Carista settings for Heater & A/C
    Temperature dial calibration
    -2°C / -1°C / *NORMAL* / +1°C / +2°C
    Ambient temperature calibration
    -3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
    A/C ECO mode
    *ENABLED* / DISABLED
    Auto-increase blower speed when front defroster is on
    *YES* / NO
    Auto-turn on recirculate mode when A/C is on
    *YES* / NO
    Deactivate front defroster when AUTO button pressed
    *YES* / NO
    Open vents to outside air when ignition is turned off
    *YES* / NO
    Fan speed reaches its target…
    SLOWLY / *NORMALLY* / FAST
    RCO likes this.
