INCREASING A PRIUS PERFORMANCE WITH ANOTHER HV BATTERY? JUST THINKING MIGHT BE POSSIBLE
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Nov 5, 2017.
  1. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    people! I'm just wondering, if the performance of any gen2 Prius can be increased using another HV battery(increasing the voltages).
    I already understand that Toyota typically designed the Prius from bottom up, for basically for less emissions, and gasoline cost savings, with some little HP available.
    Here's what I'm thinking:
    Since a Prius electronics, or HV ECU has being configured for its current 201+...volts from the HV battery, isnt it possible,
    1)for a highlander battery, with same capacity(6.5Ah), and nominal voltage of 9.6V to be added along side the stock HV battery of the Prius, inorder to produce more torque for either of the MG 1/2?
    2) or alternatively, can I use one of a highlander pack(24modules rated at 9.6volt=230.4volts combined)?
    3) if any of the above were possible, I guess the HV wiring harnesses, ECU would have to be replaced with ones that could bear the load(current. Although, current would still be same).
    PS: Using some of the highlander battery pack(the 2* 12modules), should reduce the space the stock Prius pack occupies.
    I know incorporating electric motors on the rear wheels would also add more HP.
    I'm specific about additional batteries (whether some of the highlander, or otherwise)
    @MTL_hihy . Can you chip in some word or two, since you've worked extensively on hybrid highlanders?
    52,390
    anything is possible. :cool:
  3. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Well, bisco! You're always giving SUMMARISED ANSWERS:D. I need technical inputs from you on its workability. Remember, this is still in its IMAGINATION stage(s).
  4. bisco
    52,390
    sorry, technical is above my pay grade. skeptical is my m.o., the problem is, we have seen lot's of ideas come through here, but no one ever follows through after realizing the amount of work involved.
    for instance, we got a guy in another thread who is going to install gull wing doors and a diesel engine.:rolleyes:
    m.wynn likes this.
  5. Prodigyplace
    12,678
    11,830
    Central Virginia
    Dxta likes this.
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    What? Gull blablabla and a diesel engine?:mad::(
    m.wynn and bisco like this.
  7. Prodigyplace
    12,678
    11,830
    Central Virginia
    Thread is here.
    Gullwing Doors | PriusChat
    The DeLorean, for instance, had gullwing doors.
  8. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    The ECUs in the Prius coordinate the working of the two electric motors and ICE. The programming involved in making everything work together is very complex and likely involved a large engineering team at Toyota to make it work. It's not practical to think a single person could create new ECUs for the Prius to manage the HSD systems. Therefore the approach taken with aftermarket battery packs is to send a fake signal the ECU to make it think the battery is at ~100% and then wire a power supply connected to a large lithium ion battery wired in parallel with the existing HV battery to feed current to the system. The Prius ECUs are pretty happy to feed ~30A of current to the motors all day, until the extra battery is depleted, at which point the systems disconnect an the car behaves as normal.
    The Enginer battery systems worked like this: Enginer | Prius Plugin PHEV Conversion Kit with Lithium-Ion | Hybrid
    However with the cost of these aftermarket systems, there's no real reason to buy one today. I would just go buy a used/new plug-in Prius/Prime/Volt instead.
    jerrymildred likes this.
  9. Shane Burns
    Shane Burns Member
    94
    126
    SoCal
    I saw a video where they have a Prius with 3 yes... THREE HV batteries with the gas engine removed. Very interesting... so yes anything is possible!
  10. bisco
    52,390
    agreed!(y)
    Shane Burns likes this.
  11. bisco
    52,390
    let's see, 3 hv batteries = 3 miles, then you have to recharge them.(n)
  12. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    You were probably tagged as a realist and not an optimist throughout life I bet:whistle:.
  13. bisco
    52,390
    yep, see myself that way too. can't teach an old dog new tricks. on the plus side, i'm rarely disappointed.:cool:
    m.wynn, Data Daedalus and Raytheeagle like this.
  14. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    How’s your rotator cuff doing?
    Montgomery and bisco like this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    You probably don't see the spectacular and awesomely wondrous advantages of daylight savings time either. :ROFLMAO::D:ROFLMAO: Anything is possible but not everything is useful.
    Montgomery, m.wynn, bisco and 3 others like this.
  16. bisco
    52,390
    yeah, not a big fan of 04:30 darkness. at least you folks have an extra hour of light down there.:)
    Data Daedalus and jerrymildred like this.
  17. bisco
    52,390
    great, thank you. 5th month anniversary this week, only 7 to go!(y)
  18. Prodigyplace
    12,678
    11,830
    Central Virginia
    How are we ever going to survive when you get back to working IRL? :eek:
    bisco and jerrymildred like this.
  19. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Its a great thought but the issue is that this setup probably won't play nice (you can't just match total voltages because the ECU checks them by block, thus the Highlander pack would be the same total voltage but the blocks would mismatch) with the Prius ECU without doing some serious custom work. You'd be far better to double or triple up on Prius packs to extend your range because it would be far easier technically to make them work without getting too technical in the process. It's sort of like daisy chaining RC batteries for both charging and discharging. You would need to do regular grid charge top ups to ensure none fall behind in use but it would definitely work (although you'd need to give up some trunk space to do it).
    m.wynn and Dxta like this.
  20. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    That's y I had to wait got your inputs
