Gullwing Doors
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Staley09, Nov 3, 2017.
  1. Staley09
    Staley09 New Member
    Iowa
    If I were to install gullwing doors on the passenger and drivers side, how much would that cost and where could I find the doors? Also, my future plan is to put a diesel engine in a prius, anybody willing to give me ideas to help me (this seems delusional, but I want to do it)?
  2. Staley09
    Staley09 New Member
    Iowa
    Another thing xD, does it sound so much better with holes drilled in the muffler or without a muffler?
  3. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    hahahaha, damn, you should save these posts for april 1st.
    yeah, you could totally gut the entire interior/exterior and replace all the electronics (cabin and ecu since they all talk) and engine(both ice and hybrid system) with a diesel. it would probably be cheaper and easier to build a shell that looks like a prius then to go the other way around.
    jerrymildred likes this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Putting a diesel engine in a Prius is like putting liver pate on ice cream.
    GG707 and pilotgrrl like this.
  5. Staley09
    Staley09 New Member
    Iowa
    reported xD (love it). I know it sounds ludicrous, but it's happening. Nothing is stoping me now xD.
  6. Staley09
    Staley09 New Member
    Iowa
    No, I'm actually going to do this, this is going to be an official project
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Everyone just calm down.
    Keep your thoughts to yourself unless you are helping the OP. Over the years, we've heard and seen some pretty strange Prius-related things. Stretch-Prius, anyone? Installing parts from other countries, anyone? Navi-Override, anyone? Shoot, I think someone tried to make a Prius convertible at some point.
    There are literally thousands of other threads. If you don't like this one, try one of those.
    That said, Staley, post plans and pictures. Rather than asking people what it would take, show that you're putting some effort into it. Come with armfulls of plans and schematics. If you show up empty handed, people will not take you seriously. I did one Google search for "Gullwing door retrofit" and received dozens of viable retailers. Start there, gather information, and then present your ideas.
  8. TonyPSchaefer
    14,816
    2,501
    66
  9. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    If a guy was able to put a supercharged hellcat engine in a Prius, Gullwing doors is not that bad as a project.
    Good luck.
  10. Prodigyplace
    12,716
    11,849
    Central Virginia
    If you want electric gullwing doors and room for s traditional engine, see if you can find one of these.
    Bricklin SV-1 - Wikipedia
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Regarding the engine, that's an easy one. Rip out everything under the hood bolt in a diesel engine and transmission and voila. A FWD diesel car. You will need to use a European style micro-diesel because of the limited space. The bladder may even support diesel, so it is just a matter of hacking away at the front of the car.
    Then for the doors, you're going to have to custom make them. Making doors that swing up versus out is incredibly difficult and puts tremendous forces on the roof. The Prius will crumple like aluminum foil, it's not made for that. So you will need to beef up the structure of the roof dramatically as well as change all the latches around.You'd have to get the springs, torsion bars, and struts to all fit in the roof void, so you will most likely have either a raised bump on the roof (like a higher profile) or a bump down the center of the car inside blocking your view outside and headroom.
    I own one of the few cars with gullwing doors and it is awesome. But to retrofit, nearly impossible. You'd be much better off spending a couple grand on a "lambo kit", where the doors pivot and open like the oldschool Lamborghini's.
  13. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I've never had that problem. There is a channel that runs all around the door frame and all the sitting snow or melt goes around it and to the ground. If the rain/snow/sleet is not falling vertically down, then yes it will enter but is usually much better than a "normal" car since the door provides an umbrella like fashion.
    I've had to replace the door struts twice but that's it. Not easy to balance a hundred pounds of metal above you as you try to align a strut and pin with a torsion bar right there...
  14. bisco
    52,863
    will you be using one of the vdub cheater engines, or something more refined like a dodge 6.7 liter cummins?
    this is a complete guess, but i'd have to say at least a grand to put on gull wings.
  15. Prodigyplace
    12,716
    11,849
    Central Virginia
  16. bisco
    52,863
    oh, much better without a muffler, what was i thinking?(n)
    Prodigyplace likes this.
  17. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Gullwing doors are not a common conversion for any car as they aren’t really user friendly in normal use. But if you want them you have install hinges at the top, move the latch to button and add gas strut(s) and strengthen all the locations. All of that is fabrication work requiring skills or money.
    Installing a lambo style door hinges would be a lot easier.
    Easiest way to install a diesel engine into gen 2 Prius would probably be using a Gen 1 or 2 Toyota Yaris (also called Vitz) and take 1nd-tv engine and a (manual) gearbox and lots of other components from that into a Prius. They do share some components and design and Yaris/Vitz is also available with 1nz-fe engine that has the same block as 1nz-fxe in a Prius. Of course while doing that you would ditch the hybrid system entirely and basically install the most of electrical system of Yaris/Vitz into a Prius.
    Just remove the muffler entirely as you also get weight saving when doing that.
  18. ChaseC
    ChaseC Junior Member
    If you want gullwing doors, just go out and buy a DeLorean. Will end up being cheaper and those cars are engineered specifically for the torque and forces of such doors. For reference, I read elsewhere that someone had a Prius professionally turned into a convertible. That cost $14k. Gullwing doors will be ever bit as complicated a conversion.
    jerrymildred and bisco like this.
  19. bisco
    52,863
    are you taking the weekend off? big job, no time for relaxation.;)
    jerrymildred and Raytheeagle like this.
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    True for most people, but for some people that IS relaxation.
    bisco and Raytheeagle like this.
