Another blown head gasket.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by leeb18c, Sep 7, 2017.
  1. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    My experience with our interference, 3mz Sienna is that cam/crank correlation codes (P0016 in this case) set very easily, a good thing of course. An idler bearing had gone wobbly and the belt was walking it's way into the timing cover and had literally shaved a solid third the width of the belt. The timing compartment was packed full disintegrated timing belt. Tension was disturbingly low but the belt hadn't actually jumped any teeth. My point with all of this is that I'm betting you're ok, although I'm also betting you're pulling the timing cover again...
    Also, there have been some cases of P0011/P0016 in the Gen 2 forums over the years but no reports of damage that I recall, mostly just "runs fine with the code."
    Awesome work!!
    Raytheeagle and danlatu like this.
  2. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Finally got around to fixing it. I hope the valves are not bent since I can't tell from looking in the cam area and not able to see inside the valve spring. Anyway, the intake cam is 2 teeth off from what's it supposed to be. :( So I just loosen the cams and wiggle the chain around to get to where it's supposed to be as I don't want to remove the chain cover again to do it. All the code are cleared and stay gone for now and engine runs smooth now with oil change. I'll have to see how the fuel economy goes and maybe do a leak down test in the future. Other than to install oil catch can in near future, I have enough of working on car for a while. :)
    If anyone need some copper spray or grey RTV, let me know along HWY 101 between SF and SJ. :)
    kc410, RMB, SFO and 5 others like this.
  3. leeb18c
    272
    202
    SF Bay Area
    One thing I forgot to mention, the crankshaft oil seal that comes with the head gasket kit is no good. It doesn't have metal frame like the original Toyota parts and it's wobbly and leaking oil. I shouldn't have pull the original out since it wasn't leaking oil before. Anyway, I've ordered the Toyota oil seal and will install that when I get it.
    Also installed the oil catch can today while the car was jacked up. I installed it under the intake manifold easily since I don't have the plastic pan below the engine anymore. My only worry is, since it's mounted to engine mount, I hope it doesn't come loose from vibration. Sorry, I forgot to take the last picture with everything connected. I'll do it when I'm down there when I have the car jacked up to install the crankshaft seal.
    #43 leeb18c, Nov 13, 2017
    amos, RMB, Mendel Leisk and 1 other person like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Looks like we may have inspired the catch can install after the meet up on Saturday with @RMB ’s OCC :whistle:.
    Good location:). Being below the PCV valve will help ensure no pooling of oil will sit on the downstream side of the valve;).
    Good to talk to you on Saturday and thank you for sharing your experience through the head gasket process (y).
    leeb18c, RMB and Prodigyplace like this.
  5. fneil
    fneil Member
    71
    52
    Carrboro, NC
    So is the conclusion the original misfire problem was indeed the head gasket, even though I don't believe there was any obvious damage to it visible when you pulled the head? I don't think there was anything else you did that could have corrected it? Are coolant fluid levels confirmed stable now?
    I assume you put in new spark plugs, but I doubt that could have been it...
    leeb18c likes this.
  6. leeb18c
    272
    202
    SF Bay Area
    Ray, it's great to see you all there and Thanks to you for arranging and Marc for hosting it. Yeah, I got the bug from you guys and don't want oil puddle in my intake after I've cleaned it. I'll probably get black hose to further conceal for smog check but for now I'm using the clear hose that comes with the catch can.
    At this point, I've only driven it about 20 miles and 2 heat cycles(with coolant circuit back to normal pressure) and no coolant loss or misfires at all but cannot conclude till I've driven for couple of weeks. I looked for any defects/damage to the block/head/gasket but couldn't find any that jumps out to say so only time will tell.
    amos and Raytheeagle like this.
  7. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    If you want to keep the lines you have, there is a member here who works in San Ramon that could help out and avoid changing the lines out ;).
    Joele3, leeb18c and amos like this.
  8. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Thats why I chose the blue can and blue hoses :D:D
    leeb18c and Raytheeagle like this.
  9. leeb18c
    272
    202
    SF Bay Area
    So I replaced the crank oil seal (part number 90080-31049) today and no more oil leak. I can start driving tomorrow. Yay. :) Hopefully, no more problems or I'm going to push it off the cliff. :)
    Here is the pic of my catch can install from the bottom. I'm now worried that those clear hose will collapse at the bend with heat even though I only bend in as big radius as I can. I had problem with my old Honda that those type of hose collapse with heat and I have to replace with black gas hose with thicker wall and more heat resistant. More work. :(
    mjoo, danlatu, Mendel Leisk and 3 others like this.
  10. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Is still can't figure out where is this oil catch can mounted on the engine. Is it at the intake manifold at the rear just close to the exhaust manifold, or where?
    Nice pictures though
    Mendel Leisk and amos like this.
  11. Mendel Leisk
    41,628
    Yeah heavier, black rubber fuel lines seem more solid, either SAE-30R6 or R7. I see the latter available at a local automotive store for $1.69 per foot, not hard to get.
    Picture taking looking up from underneath, looks like original U-shaped hose left connected a manifold end.
    amos, leeb18c, JC91006 and 1 other person like this.
  12. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Thanks for the explanations sir!
  13. mjoo
    mjoo Senior Member
    1,160
    1,329
    Michigan
    Depending on what threads those hose barbs have you may be able to do something like:
    OR
  14. Mendel Leisk
    41,628
    Maybe overkill? Just going to better spec fuel line, no risk of tube collapse, and more adjustable.
    leeb18c likes this.
  15. amos
    amos Active Member
    373
    283
    los angeles
    @Mendel Leisk wanted to ask you bout the inner diameter of those gas pipes you used with your OCC compare to tube diameter that connects pcv valve to IM.
    leeb18c likes this.
  16. Mendel Leisk
    41,628
    I've got this:
    inside diameters of the hose between PCV valve and intake manifold:
    valve end: 3/8"
    manifold end: 3/4"?
    hose part number: 12261-37060
    You can readilly easily check that question marked ID, if you take the air box off and pull the hose off. I believe it's 3/4", and of course I didn't measure it when I had the manifold off the car. If you get a more definitive number please post.
    All of the measurements should be behind the nub at end of spigot I think. The nub is a little bigger, helps lock the hose, but it's the OD further along the spigots that count, should correspond with the ID of hose.
    #56 Mendel Leisk, Nov 19, 2017
    leeb18c, danlatu and amos like this.
  17. Mendel Leisk
    41,628
    I found the easiest way to check was to have a collection of hoses, various diameters (if you can swing it): try pushing a possible hose on, see if it goes. I had a hose that was 5/8" dia, and it looked like it would go, but way too tight. Which is why I guestimated 3/4".
    amos and leeb18c like this.
  18. leeb18c
    272
    202
    SF Bay Area
    I measured them and they are 0.743" on the IM and 0.361 on the Engine side. Essentially, 3/4" and 3/8" as you mentioned.
    I didn't get a chance to stop by local store where I got some several years ago but just going to order this 5' one from Amazon. This should be good enough.
    Mendel Leisk, amos and Raytheeagle like this.
  19. fneil
    fneil Member
    71
    52
    Carrboro, NC
    Everything still good?
  20. danlatu
    danlatu Senior Member
    533
    1,363
    maryland
    Any straight hose will collapse if bent too much unless it is molded that way. I have seen hoses use springs inside or out to apply pressure on the walls to prevent collapse. Jegs <-------- click
    Screen Shot 2018-01-10 at 8.04.10 PM.png Screen Shot 2018-01-10 at 8.04.33 PM.png
    leeb18c likes this.
