Very Occasional Auto Climate Control Issues - buttons inoperable
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by WiscPriusc, Jun 30, 2013.
  1. winnertakesteve
    148
    45
    Toronto ON
    2025 Prius Plug-in
    SE
    i'd be inclined to agree since the ac and fan have been functional since the incident and don't seem to be struggling at all when they're running. that said, if it happens again, i'm hoping i'll be able to compel my dealer to get to the bottom of things. no matter where the problem is originating, unreliable climate control isn't something i want to just "live with"!
  2. HotDogWater
    HotDogWater Junior Member
    70
    17
    Try taking a video of it the next time it happens and show it to the dealer
    Scrittibear likes this.
  3. Scrittibear
    Scrittibear Junior Member
    67
    I
    I will have my iphone video at the ready - that's a great idea!
  4. Sterferg
    Sterferg Junior Member
    You're in the ECO mode. Take it out of ECO mode and it well work normally.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Wrong. Eco mode doesn't turn off the AC, just turns it down.
    Scrittibear and minkus like this.
  6. Sterferg
    Sorry, maybe you've got a problem.
    ztanos and minkus like this.
  7. Scrittibear
    67
    I
    SOLVED: I had the "A/C won't start when the car is in ready mode" problem today and I took a video so I have proof - and while reviewing the video, I discovered what is happening - it's very difficult to detect this visually but if you look closely, the OFF button located between the AUTO and A/C buttons gets stuck down in a flattish, permanently off position - and then of course if you try to select the A/C or AUTO buttons to turn on the A/C, the A/C and AUTO buttons illuminate but never engage -- nothing happens.
    Eventually the OFF button unsticks itself and pops back up into full position - and vwahla, the A/C and AUTO buttons are once again operable.
    So now I can take my car back to the dealership and see if they can fix the sticky OFF button. Clearly this is an issue for other folks - I have a 2012 Prius C One by the way.
  8. Scrittibear
    67
    I
    And here's a link of the inoperable A/C issue in action - look closely at the OFF button (which I never touch in the video) - The OFF button is slightly depressed and sticking.
    Prius Sea, winnertakesteve and minkus like this.
  9. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    Yup - same thing that happened to me. Except I rarely use the AC and have always noticed the off button being stuck before trying to turn the fan on. Let us know what the dealership says!
  10. winnertakesteve
    148
    45
    Toronto ON
    2025 Prius Plug-in
    SE
    Amazing thank you! That video is the exact behaviour I experienced! And your explanation sounds right too. I'm pretty sure mine fixed itself when I was tapping the various buttons including the off button, which probably dislodged it from its stuck state.
    Humorously I had the same issue with my ipad home button recently, and the same solution of mashing it till it became unstuck seemed to resolve the problem. It's the new "did you try turning it off and on again?" :p
  11. col127
    col127 Member
    345
    Illinois
    I've had the same issue with my car about two weeks ago - did you bring it into the dealership? What did they say? I thought something was wrong with my a/c unit, but maybe it's this stuck button situation ;)
  12. kevtan
    kevtan Member
    Problem solved it the design ,after adding the yellow padding now no more sticky button defect[​IMG]
    minkus likes this.
  13. mdgates
    mdgates Junior Member
    67
    Buffalo, NY
    Kevtan, did you see what they're using to make the buttons spring back out? And is that yellow pad a thin sheet of silicone, or what?
  14. kevtan
    kevtan Member
    It use the tiny onboard switch to bound back the buttons which not have enough power to bounced it back , the yellow pad is just some foam padding from some toy battery compartment ,
  15. WiscPriusc
    WiscPriusc Member
    63
    37
    Wisconsin
    p.s. Update years later. This is caused by the "Off" button sticking, seems to be fairly common. Has not been a huge issue. Just wiggle the off button enough for it to pop out again and the system always works. Likely fixed by the newer, larger, and more sleek hvac controls offered from '14 on I believe.
  16. jimnjo
    jimnjo Member
    117
    2015 Prius c
    In a previous "regular" Prius we had something like this happen, but with the audio system. From time to time it would either not turn on, not turn off, or the volume control would not operate. Rare, and always ok after the next time we got in and started up the system...after 10 years it did not get worse...or better. Bears watching...
