Installing a sub questions
Discussion in 'Prius c Audio and Electronics' started by Slabagel, Nov 23, 2017.
  1. Slabagel
    Slabagel New Member
    Michigan
    2015 Prius c
    Hello, so I recently bought my 2015 Prius c from my brother and I want to put a sub in but he is saying that it isn't possible because of the factory nav and don't want to replace it.. So I was wondering if you can actually put one in??
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    wrong forum/
    Grit likes this.
  3. Slabagel
    Slabagel New Member
    Michigan
    2015 Prius c
    where else would it go tho its under 3rd gen + audio
    #3 Slabagel, Nov 23, 2017
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  5. Mendel Leisk
    41,256
    Prius c, not 3rd gen. Report your intitial post and moderators will move it.
    BTW, the one thing that raise my fur? An obnoxious sub. The ones that rattle your fillings in the next car, or just walking, you can hear them a block away.
    Grit likes this.
  6. Slabagel
    Slabagel New Member
    Michigan
    2015 Prius c
    ahh okay thanks xD I dont want anything big I just want it to actually sound good because it is quite trash right now
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The good news is that the DC to DC converter will only produce 100 amps, so he is limited to a 'small' audio experience.
  8. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    You can install one. You will need a line out converter.
    iPhone ? Pro
  9. Fester
    Fester Active Member
    201
    198
    Ohio
    Being a cranky old curmudgeon and having the woeful experience of having to endure these mobile Boom Boxes, and if I had the magical abilities to give them all of the volume they wanted. I think that certain of these offenders would suddenly experience (when far away from others and driving with no other traffic) the volume turned up to about 180db. The local coroner would be a bit puzzled when the car was found...
