185 65 r 15 snow tires on gen 3?
Discussion in 'Gen 3 Prius Main Forum' started by alexmessinger, Dec 3, 2017.
Tags:
  1. alexmessinger
    alexmessinger Junior Member
    vermont
    I have a gen 3 2011 prius. it came with 195s, but I have leftover 185/65/r15 snows from my old gen 2 prius. Any reason not use the 185s?
  2. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
    Your speedometer reading will be slightly off. Google 195/65 r15 vs 185/65R 15 and several sites will reveal the difference in size and speedometer reading.
    SCH-I545 using PriusChat mobile app
  3. Mendel Leisk
    41,925
    What's the tread depth remaining on the snow tires, and how many years back did you buy them? If it's toss up, I would let go, get the proper size, new snows . Actually, I would get the right size period, but that's me.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Check the load rating on the tire sidewall. Compare the smaller snow tire rating to the stock tires. If it's very close there is no problem. The difference in diameter is very small.
