Roof rack
Discussion in 'Prius c Accessories and Modifications' started by 14PriusC-NH, Apr 2, 2016.
  1. 14PriusC-NH
    14PriusC-NH New Member
    Pembroke, New Hampshire
    2014 Prius c
    Anyone put rails on the roof of the car? I'm thinking of putting custom one on, but I'm curious if anyone had done it yet, and has pictures, suggestions.
  2. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    I am picking up my new '16 C today and am wondering the same thing. I am downsizing from a '14 ford escape and love to travel but I have been googling for a roof rack and have found pictures but thats it.
  3. Slolane
    Slolane Junior Member
    45
    Maryland
    I went with the Rhino Rack, here are the details...
    - Rhino Rack DA106B-DK351 (2500 AERO Roof Rack System, 41" Bars)
    - Wind Fairing - 32"
    LnG and Squeakasaur like this.
  4. Will N
    Will N Junior Member
    Southern California
    2014 Prius v wagon
    I've got a 2015 Prius V with an old Yakima rack,
  5. Will N
    Southern California
    2014 Prius v wagon
    I've got a 2015 Prius V with a Yakima rack, Q-towers.... (I don't like Yakima and Thule, over priced, over hyped.... I realized that I'd just slapped them on, tightened them down, loaded up a kayak (50 pounds with a little water still inside...) 19' long. A pretty good drivability acid-test. Drives fine, done it probably 30 times in the past year. So a Prius can handle it. You've got a C, so that's another issue. Only recently did I go back and re-adjust the rails to the company specs. Now they're solid....
    Roof racks are not 'normal': properly installed with a kayak on them and no tie downs at the front and back.... you will lose the kayak. Guaranteed. I know enough people.... Loose, as mine were, but properly tied at the ends.... I don't recommend it, but I got away with it.
    TIP: A great trick for front tie downs on any vehicle, not just a Prius that doesn't seem to have anywhere to tie to is: 1. Raise the hood. Find the forward most bolt attaching the fender to the frame. Remove it. 2. Two loops of webbing. ( I think I used about 12" of 1" web that was very old) 3. Using a soldering iron or a bolt held in pliers heated up over a stove burner, melt holes near both ends of each piece of the webbing. Make them as close to the diameter of the bolt you removed. 4. Then just rebolt through the webbing. now you have loops on both sides of the hood to tie to and you can just fold them under the hood if you want to hide them. Done this for a few years--works great. (The fender bolts are I think more sheet metal with a flange, so you you don't need a washer. If you're nervous get a bolt 1/4- 1/2" longer.)
    Also: An inexpensive rack is as good as an expensive rack so long as it's attached correctly. Brand new Yaks and Thuls need locks or they'll get stolen. I loathe the round poles on the Yakima, all that expensive nonsense that connects to it just twists around. There's not enough money or torque to keep that from happening. (I guess Yakima dropped round poles)
    Gas mileage. I get between 40-43 mpg, driving around with the rack on with some overpriced and not very good kayak brackets I don't think I drop more than 1 mpg. It works pretty good. In a Prius C? something high profile like a kayak, with a large crosswind? Find out before you go tornado chasing in your C...
    Central Virginian and LnG like this.
  6. Zeb Bravo
    Zeb Bravo New Member
    los angeles
    2015 Prius c
    l had a Yakima Rack with a 4 foot sign strapped to it. It flew off at Freeway Speeds. I drive fast! but lost another load driving slow but with fierce cross winds. Now I have replacement bars and strap them down good. As a final safety I open both rear doors and run a racket strap over the load and threw the inside of the car. Racket it down tight. Doors will shut and work normally. I haven't lost a load since.
  7. Cycle M5
    Cycle M5 Junior Member
    Jersey Shore, NJ
    Here is an adjustable aerodynamic rack on my 2006 Prius sport. No strange noises at highway speed. Strong and fits well. A little drilling involved, but gasket and silicone prevents leaking.
    Great for transporting everything from pipes to a top carrier. $26 at my local auto salvage.
    As you can see, my little car is broken in, which makes it perfect for me.
    kcallowai and Scarface2005 like this.
  8. audiodave
    audiodave Active Member
    787
    268
    US
    Looks good!
    scona likes this.
  9. BergeReyesRacing
    BergeReyesRacing New Member
    Orange, CA
    0EB00E53-BD3F-44D6-AA69-82D6E4E56B21.jpeg FC68A675-604E-43D2-B54F-5202101EE122.jpeg F180F40D-781F-4223-85E1-45A6DFB3524B.jpeg 83B655F4-F5ED-4CC4-9CE8-3B116D24FC28.jpeg
    I just finished the prototype rack.. let me know if anyone is interested..
    949-466-1628
  10. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I like the prototype, but what keeps the middle from rubbing when it has anything in it?
  11. BergeReyesRacing
    Orange, CA
    It is very rigid, there is about 1" between the car roof and the rack.
    ztanos likes this.
  12. michael.sfo
    michael.sfo Member
    52
    42
    San Francisco
    2015 Prius c
    hey, those are sweet rims. do you know the make & model?
  13. BergeReyesRacing
    Orange, CA
    I think they are the wheels that come on the 2013 standard Prius.. he just took the hub caps off.
  14. jimnjo
    jimnjo Member
    117
    2015 Prius c
    <<<I went with the Rhino Rack, here are the details...<<<
    Couple years ago, when we needed a rack for the new C, Rhino was the only one that had a model made to fit (the Thule, I think, from our regular Prius was not compatible). It is a fairly pricey rack, but of all I have used over the years the best yet.
  15. MichaelJai
    MichaelJai Junior Member
    toronto
    2017 Prius c
    OP has a really nice bull bar with rally light setup. Anyone know where to get that from?.
  16. AndrewsPriusC
    AndrewsPriusC New Member
    San Francisco, CA
    2016 Prius c
    I've been super happy with a Rhino Rack setup, and on top of that a Yakima cargo bin. I also got the Rhino Rack during a seasonal sale 2 years ago, and the Yakima bin from REI during their annual anniversary sale this past spring. :) If you're not in a rush, wait for sales to save a lot on the cost.
    I personally went with the Rhino Rack Vortex "RS" bar design, looks more svelte than the square bars that stick out.
    I haul weird loads on top of the rack more frequently than I use the cargo bin. And with any weird-shaped loads on top of the rack, and which might catch the wind, I use simple winch-straps through my door jam to pin the load down onto the car. The door closes onto the thin strap no issue. I can add a picture if you'd like the visual, but its' been amaaaazing having the rack.
    Agnes Nutter likes this.
  17. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    I’ve been looking into roof racks also. I’ve found a used set from japan that’s cheaper in price but still on the bridge about putting one on the c
  18. LnG
    LnG Junior Member
    73
    Northern Hemisphere
    2016 Prius c
    is it the 2500?
  19. skayaks
    skayaks Active Member
    123
    107
    Massachusetts
    I installed a Rhino rack on my 2013 C this past summer:
    Vortex 2500 towers (used) + (used-like-new) fit kit DK351 + new 41" Vortex 2500 bars (black).
    It's a nice solid setup, but the initial installation is a little finicky.
    The fit kit pads need to be positioned per the instructions (duh) and you'll need to set the angle just-so on the clamping brackets to get everything aligned to the roof. But now it goes on and off with ease.
    LnG likes this.
  20. 2014 White Whale
    2014 White Whale New Member
    Davenport IA
    Hey Cycle M5!
    Re your roof rack: "Here is an adjustable aerodynamic rack on my 2006 Prius sport. No strange noises at highway speed. Strong and fits well. A little drilling involved, but gasket and silicone prevents leaking.
    Great for transporting everything from pipes to a top carrier. $26 at my local auto salvage."
    Could you provide more info on how you did the work? I'd like to do something very similar on my 2014 Prius. That is, drill in to secure a roof rack that I acquire on the cheap. Thanks much!
    Scarface2005 likes this.
