New prius Prime with dead 12v battery this morning
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by mcecere, Dec 12, 2017.
  1. mcecere
    mcecere Junior Member
    san jose, ca
    very surprised to find a dead battery this morning, the second week we've had the car. plugged it in last night, everything seemed normal. this morning wouldn't start, said low 12v battery.
    jumped the battery and started fine, no charge in plugin battery, traction part of battery seemed charged though.
    still have our 2005 prius (240Kmi) and battery only died from old age, pretty much.
    do i have to bring it in for a checkup? what could we have left on that would do this?
    expect a smart car to not kill itself, but i guess not.
    thanks,
    michael
    rascalle likes this.
  2. Prodigyplace
    12,516
    11,739
    Central Virginia
    It could be a defective battery. That is why there is a warranty. I believe there was one other Prime here that needed a battery too.
  3. mcecere
    san jose, ca
    thanks, i'm perplexed by this. new car shouldn't be dead in the morning, no matter what.
    second week and i have to bring it in already? wasn't going to get serviced where i bought it but someplace closer, but maybe i should go back there anyway.
    the misses was not a happy camper this morning....
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Yes. That is what your warranty is for.
    IIRC, the 12 V should be charging slightly any time it is plugged in.
    But something is definitely amiss. You would have to leave a large current device turned on to draw down the battery if the charging was working.
  5. mcecere
    san jose, ca
    can you leave the headlights on?
    they were not on Auto this morning when the battery was dead. they were on when we left the car but i assumed they went off in 60 seconds or so.
    i demand a good warranty and i also expect to never use it.
    another reason i buy Toyota.
    thanks all. gonna call the guy who sold it to me first.
  6. Mendel Leisk
    41,211
    Check the car's build date, on the decal in driver's door threshold? Maybe it's been sitting on dealership lot for months? I kind of doubt it with the Prime though.
    I'm guessing the battery took some abuse at dealership, maybe door's left open for multiple hours during dealer prep, and/or the workers running the radio in accessory mode, something like that. Phone them up, see what they can do, considering how new it is.
    Hey: when you showed up to take delivery, did they have it running...
  7. mcecere
    san jose, ca
    i drove this same car the day i took it home. i had already test drove one someplace else, but might as well drive the one before driving. and it worked fine for two weeks. i'm wondering if there were some issues starting sometimes. chalked it up to maybe not pressing the brake "properly" , but we've owned a prius for 12 years....
  8. bisco
    51,782
    since you plugged it in, but it didn't charge, i have to assume you did something wrong. do you use the timer function, or charge right away?
    not sure if gen 4 shuts out all the lights if you mistakenly leave them on, but i thought so. dome light has always been the 12v killer on previous gen's.
  9. mcecere
    san jose, ca
    true, what's the connection with the dead 12v battery and not having a fully charged plugin battery the next morning.
    i set the car so it starts charging after 7pm, but that seems to have been working for a week or so.
  10. bisco
    51,782
    maybe nothing, hard to say. i'm thinking you left a door ajar or something. but if it is a defect, you don't have to go back to the seller, you can take it to any toyota dealer.
    remember, you have a free tow with toyotacare.
  11. mcecere
    san jose, ca
    well, hope i don't ever need it but forgot about toyotacare. would save on my AAA benefits.
    maybe the door was left slightly unlatched. i've noticed it takes more effort to close then i would think. figuring it will brake in over time, and we get used to it.
    but would an open door kill the battery? but why didn't the plugin battery charge?
    well, will get it to toyota soon, seems fine now anyway.
    i need to find out how to access the maintenance menus to check on what i can also.
    would like to record any trim settings if possible, see how they change over the miles.
    thanks all
    will update this thread when i learn something concrete
  12. bisco
    51,782
    generally, when the timer charge doesn't start, it is a user error, but i can't speak to your specific instance.
    they have probably increased the door casketing to reduce wind noise.
  13. Trollbait
    12,482
    If the door didn't fully close, wouldn't there be a visible warning about a door being ajar? The Camry shows the graphic for that even when the car is off. It is possible the car simply won't charge if a door is seen as open.
    Wasn't there warnings that the 12volt could discharge if the car is plugged in for too long?
    My father had a defective battery in a new car, so that is entirely possible.
    Toyotacare will only tow you to a Toyota dealer.
  14. rascalle
    rascalle New Member
    san francisco
    I've just experienced nearly the same.
    My Prime had a full charge two weeks ago. I heard the half din of the aftermarket alarm, and, after stopping the alarm, all went dark. The plug-in would not initiate the charge, so AAA got it jumped in a second. But, again, the plug-in would not charge. I then tried my 3A battery tender but presumably the battery's voltage was below 3V and could not initiate the trickle charge. A second AAA jump, a few-hour joy ride later (without risking turning off during), and the plug-in began charging as normal. As well, after the hybrid battery was fully charged, the battery tender charged for less than a half-hour before going green. All's normal, now.
    I'm sure that the only possible discharge is from the alarm, but to deplete the hybrid and 12V battery in two weeks is inconceivable.
    I thought that at least I could begin the plug-in charge but, evidently, it requires nominal juice to detect and proceed-to-charge??
    What gives?
    Seems a 400A portable jump starter is a nice-to-have when in a pinch.
    LongStrider likes this.
  15. Mendel Leisk
    41,211
    Sounds like your alarm is draining the battery somehow?
    Try your battery tender again? Is that the brand name?
  16. bisco
    51,782
    any news?
  17. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    I'm pretty sure the lights only time out when the switch is in Auto. Should be a simple check in the owner's manual. I came upon a Gen 4 with the lights still on in a parking lot once, and the switch was in On, not Auto. So, that makes me think it is so.
  18. rascalle
    rascalle New Member
    san francisco
    I guess the alarm is drawing some battery but I can't imagine it discharging both batteries in two weeks time. I've had the car since July and, since it's still a backup to my 2004 Prius, it sits in the garage for weeks at a time. Regardless, my discovery is that you can't plug-in charge your depleted hybrid battery if your 12V battery is depleted.
  19. Sam Spade
    2,036
    1,023
    2017 Prius c
    It won't. You are operating under a mis-conception here.
    Unless there is a really strange failure at work, NOTHING will discharge the HV battery when the car is OFF.
    But many things can discharge the 12 V battery......including the battery itself when it gets old......and without a working 12 V, they system cannot determine the condition of the HV side.
    An active after-market alarm can definitely drain the 12 V down below a usable level in two weeks; sometimes within a few days.
  20. Prodigyplace
    12,516
    11,739
    Central Virginia
    On the Gen 4 withhout Auto, the default timeout is 30 seconds, IIRC. I changed mine to turn off immediately. This is documented in the owners manual.
