Camber Adjustment Front and Rear
Discussion in 'Prime Accessories and Modifications' started by JamesBurke, Dec 27, 2017.
  1. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    MIRACLE CAMBER ADJUSTER / MIRACLE STROKE ADJUSTER | BLITZ
    Listing Prime parts.
    "The camber angle of the rear eccentric cam mechanism of the knuckle connecting portion can be fine-tuned."
    https://www.blitz.co.jp/wp-content/uploads/2017/12/2017-0314.pdf
    DAMPER ZZ-R
    プリウスPHV (PRIUS PHV) ZZ-R 17/02- ZVW52 2ZR-FXE ¥170,640
    (¥158,000) 92368 [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] フロント延長ダイヤル取り付けにアッパーマウント上部鉄製パネル、樹脂製サービスパネルに要穴あけ加工,
    リア減衰ダイヤルはホイールハウス内
    MIRACLE CAMBER ADJUSTER/MIRACLE STROKE ADJUSTER
    プリウスPHV (PRIUS PHV) MIRACLE CAMBER ADJUSTER
    Front 17/02- ZVW52 2ZR-FXE ¥43,200 (¥40,000) 92007 [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    プリウスPHV
    (PRIUS PHV) MIRACLE STROKE ADJUSTER
    Rear 17/02- ZVW52 2ZR-FXE ¥51,840 (¥48,000) 92107 [​IMG] [​IMG] [​IMG] 2018年2月発売予定
    Also found this for HB. Prime pending
    Cusco 【1A1 474 L】Adjustable Rear Upper Arm -Toyota Prius
    davebernier and bwilson4web like this.
  2. Mendel Leisk
    41,384
    In pictures of the rear suspension there a flanged bolt with increments around the circumference: Some adjustment?
  3. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    @bwilson4web has already experienced the Toyota non adjustable rear camber problem shortly after he got his Plus home. Rears sit on the inside edge a little to much. Some where in his Prime in my hands thread I think.
    Cusco part looks like something that could be fabed from the OEM part if it works.
    All of them are pricey.
  4. bwilson4web
    16,201
    Old school, I used metal shims:
    • -1.5 deg - 1/64 on driver side rear
    • -1.2 deg - 1/32 on passenger side rear
    • specs: -1.7 to -0.2 degrees
    I'm happy but I appreciate the eccentric cam approach because it means not having to blackout 2 of 4 hub mount bolts by the width of the shim. Current mileage 8800 mi and sad to say, I let Toyota do their 10k service. My proof will be tread depth in another year.
    #4 bwilson4web, Dec 27, 2017
  5. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    @Mendel Leisk
    Bolt #9 Rear lower control arm to frame has a cam for adjusting toe so says the parts descriptions online. Is this the one you seen a picture of? Aftermarket parts all adjust at the knuckle, upper or lower. Trailing arm is such a pain. Just watched on youtube a kid do his Honda multi link with all aftermarket turnbuckle rods and bushings. Bolt right in place of the OEM parts and so easy to adjust.
  6. Mendel Leisk
    41,384
    This is what I noticed, at right end of the arm:
    For toe you say?
    Close-up:
    #6 Mendel Leisk, Jan 2, 2018
  7. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    @Mendel Leisk
    Yeah that's cam bolt #9. Washer on the nut side looks to be cam'd 180 from the bolt head cam for toe adjustment. Looks bigger in person than on paper.
