Warning Lights, Hyper-Charged, Loads of Codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Eleanor S., Jan 6, 2018.
  1. Eleanor S.
    Eleanor S. New Member
    Pocahontas IL
    Hello,
    My 2004 Prius (240,000 miles) has always had issues. Notably, the console didn't work for a while. I had a new 12-volt battery put in, and the console still didn't come on.
    Recently, the console did come back on, and a few weeks later, it seemed there was a battery drain I couldn't find. On weekends, if I went a day without driving my car, I'd have to jump start it. I also noticed at this time something that sounded like a transmission issue - if I was driving 50 mph, and I let my foot off the gas, the engine would rev. This happened off and on for a few days. Then my warning lights all came on (red triangle, red car with exclamation point, VSC light). I noticed the battery monitor showing the battery always charged at full capacity. Yikes!
    Today I took it to get scanned. Here were the codes:
    C1241 - Low Battery Positive Voltage or Abnormally High Battery Positive Voltage
    C1242 - Open Circuit In IG2 Circuit
    P0A80 - Replace Hybrid Battery Pack
    P3016 - Battery Block 6 Becomes Weak
    P3017 - Battery Block 7 Becomes Weak
    Reading all this, I just went on Craigslist and bought myself a different car to use, to give me time to figure out what to do with this Prius. The car has lots of other issues:
    * Cosmetic damage - may have been in an accident before I bought it. Creepy smell sometimes too...
    * All the fancy bluetooth, telephone connect, maps etc - none of it works right.
    * Hatchback is goofy - doesn't always open
    * Key fobs are goofy - don't always work (so I never lock the car)
    * Radio barely picks up signals...
    * The console not always working...
    With all this, I still like the car. But I don't know how I could get all this fixed. Not sure how to sell a car with this many problems. Either. Suggestions?
    49,709
    welcome!
    are you a diy'er? who pulled the codes? the car has little to no value if all the codes are right.
  3. JC91006
    JC91006 Senior Member
    16,495
    8,404
    Try to put it on craigslist for $1500. See what offers you get.
    You'll need at least check the 12v battery and replace the hv battery.
    #3 JC91006, Jan 6, 2018
  4. Eleanor S.
    Pocahontas IL
    OK - this is all good to know. Bisco - I took it to O'Reilly Auto Parts, and they read it for me.
    Guess I'll put it up on Craigslist and see what I get. Thanks!!!
  5. bisco
    49,709
    all the best!(y)
