mswtoyota's 2006 Black Prius mods
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mswtoyota, Feb 1, 2015.
  1. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    First mod: shark fin from PriusChat shop: CAM00107.jpg
    I get comments about this all the time from fellow Prius drivers (esp 3rd gen). Apparently the 3rd gen "limp" look is unflattering.
    #1 mswtoyota, Feb 1, 2015
  2. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    My own version of EV button mod: CAM00098.jpg
    I installed a button into an old lighter plug (just need the ground to activate EV mode) and plug it into the lighter socket. Handy for moving the car around the driveway without starting the engine, and being a ninja.
    #2 mswtoyota, Feb 1, 2015
    Prius_Angie and Justdidit like this.
  3. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Interior LED upgrade:
    So much better than stock. Also did the rear tails and license with LEDs.
  4. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    New seat covers:
    I've got port installed leather, but I like to keep it covered to protect it.
    I like the quality of the Coverking covers, but I have contacted them about the misaligned headrest velcro and fitment. I can't get the velcro to stay shut.
    Prius_Angie likes this.
  5. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Just tonight, I figured it was time to defeat the Nav and phone lock out when traveling more than 3 mph.
    I really like Bronson's automatic circuit, but I wanted something NOW, so I put the 1/4" DPDT switch in the upper glove box.
    SFO, Prius_Angie, Justdidit and 2 others like this.
  6. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Set up a custom PID in Torque (paid version) to run the battery cooling fan on high:
    Name: BatteryCoolingFanSpeed, Short name: SFS, Mode&PID: 3081000X, Equation: A, Min:0, Max:0, Units:No reply required, Header: 7.00E+03.
    Enter the fan speed (1-6) where the X is in the above PID (Eg 30810006 is speed 6, or high) and add the gauge to a screen in Torque. Whenever you are on that page, the fan will run on the speed you set. When you scroll off that page, the fan will revert to being controlled by the car as usual.
  7. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Sorry for the poor focus. Best $14 I've spent so far. They even had the polarity correct (I figured there was no way they would get it right). They literally just plugged in where the stock light was and snapped into place. Awesome at night!
    #7 mswtoyota, Sep 6, 2016
  8. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    And then to something a little more serious: 20160614_185619.jpg
    Alpine PWE-S8 to fill in the missing lows. It is a powered 8" sub that takes high level inputs, so the stock JBL amp and speakers stay. I'm use to 2x12" Alpine type R subs in the truck, so the stock JBL system left a lot to be desired. I didn't want to take up room with a big box and amp, so self powered and able to fit under the rear floor were the requirements. It won't win any SPL competitions, but it sounds 110% better than it did stock! No one knows it is there until I turn it up and it takes no cargo space. Easy to wire in since the 12VDC battery happens to be right there in the back....
  9. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Installed a 34 inch LED light bar behind the billet front grille. Grille was mounted with leftover fence brackets and rivets to the bumper cover; light bar drilled and tapped into the aluminum bumper behind the bumper cover and styrofoam. Wired into the factory fogs using a 40 amp relay and fuse. My factory HID highbeams suck, but now I can see everything including the damned kamikaze rabbits every morning. Prius.jpg PriusOn.jpg
    Data Daedalus and Prius_Angie like this.
  10. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    I may have gotten carried away. The mower got one too. Mower.jpg LightOn.jpg
  11. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Replaced the stock (hollow?) swaybar with a 24mm from a 2004 Pontiac Vibe. Time to autocross! 0802171922.jpg 0802171921.jpg
    Prius_Angie and gta_ like this.
  12. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    oh yeah! now you got to get the progress or TRD rear bar, or even a oe corolla bar to replace the piece of conduit that Toyota used. its like a whole different car.
    SFO and gta_ like this.
  13. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    I'm gonna try it with just the upgraded front for now, would you happen to know how much larger the Matrix\corolla\vibe rear bar is from the stock non-touring prius rear is?
    SM-T230NU ?
  14. 69shovlhed
    2,170
    748
    Delaware
    I don't know how thick the corolla/ matrix rear bar is, but its a forged bar, not a piece of cheap welded mild steel tubing like the oe prius bar. from looking at the corolla bar, I'm certain it will make a big difference, and its a 5 minute job, 10 if you take your time and work very slowly.
  15. plastermaster
    plastermaster Junior Member
    43
    Alameda
    There is another old thread about the TRD rear bar and installation instructions. However I emailed TRD about it and they said that the part number was not a valid toyota part number, and that there are no rear bars for the base Prius. Do you (or anyone know the part number for the rear TRD bar?
    Also wondering if I would be able to use it on a Gen 3 if I were to replace my PriusII.
    Thanks
  16. 69shovlhed
    2,170
    748
    Delaware
    I don't know the trd number cause I bought a Progress bar from th motorsports. it cost less, but its still a beefy forged bar. a lot of folks have used it and no one has ever regretted installing one. it won't fit a gen 3.
    gta_ likes this.
  17. ex-VAG
    ex-VAG Junior Member
    Perth
    i-Tech
    Mate, did you connect this sub up to the under seat amp? How did you do this? Very keen on this solution, you'll see from my other thread that I've been looking for some lows but nothing happening, this may make me happy depending on how difficult it is to wire up.
    Cheers
  18. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Yes, it has speaker level inputs and auto turn on, so I routed two small twisted pair wires under the carpet to the JBL amp under the passenger seat. I used 4 T-taps to tap into both rear speaker outputs. It adds just what the stock system is missing, but I didn't want to take up any cargo space.
    SFO and ex-VAG like this.
  19. ex-VAG
    Perth
    i-Tech
    Nice one, what a result!! Sorry, just to understand the simplicity of this connection, you simply connected the 4 rear speaker wires from the amp to the 4 speaker inputs on the back of the sub, highlighted in yellow below, and that's it? Obviously with the power and ground connected too.
    SFO likes this.
  20. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Yup
    ex-VAG likes this.
